Question about Nintendo DS Console
My screen wont calibrate
I try and calibrate my screen.. but the squres keep coming
how do i reset it
    Problem Solver:
  • 10 Answers
Do you mean you calibrate the screen and you can never accept the changes?
The lower screen in the DS Lite is actually 3 pieces. The lower screen, then the touch screen on top of it and then a clear plastic cover on top of that. If you are very rough with stylus on the clear plastic and leave dents or gouges this will damage the touchscreen.
From your basic description the touch screen needs to be replaced.
Posted on May 26, 2008
I have a icoustic mp3 player which i downloaded music to but i deleted the music
The blue screen is a screen calibration. Just touch the screen exactly in the center of the little boxes in the corners of the screen for about a second and remove your finger. Do this until it says success and you should be good to go.
Feb 09, 2013 | Coby MP828 MP3 Player
My ds lite calibration seems to be off .when i start a game the touchscreen cursor wont move from right of screen but will move up and down .when i calibrate, it does hit the individual boxes. any help plz
The touch screen membrane is made up of two layers one controls the left to right axes and the other the up and down axes with the small ribbon cable in the middle, i cant remember of hand which is which now but you get the gist, there is a fine track going around the surrounds which keep the two together and it somtimes comes slightly unstuck, a quick tip is to run the stylus around the screen applying a bit of pressure somtimes this helps to make the screen more responsive, give it a try and then recalabrate it if you still have the same problem try taking the battery out and reseting the ds and calabrate it. Worst case the touch screen may need replaceing. i hope this helps.
Jan 18, 2010 | Nintendo DS Console
Touchscreen wont work
touch screen wont work,
what is it doing ?
if the touch screen feature is not working, and you cant navigate to the calibrate screen, push the off switch but release right away, so it dont turn off, it will bring up the calibrate operation, its a default to access the calibrate when you cant navigate the screens.
Aug 14, 2009 | Sylvania SMPK8854 Digital Media Player
Cant calibrate screen on i900 omnia.
put a blank file called welcome.not (make using notepad) onto the removable storage card this will bypass the startup screen and mean it does not jam into this look on startup
down load a file phm registry edit... (search on internet) put the cab onto the phone... in stall.. and run
set the sensitivity on this to 20, you can then calibrate the screen... you can try stepping it to 18 16 14 and 10..
this will cure the problem
Jul 22, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Calibrating wont work.. i want to reset it.ive cleaned the screen n taken out the battery...help!!!!
You need a new Touchscreen. FAIRLY EASILY to replace.
http://site.powergamingparts.com/RepairNdsl.html
May 27, 2009 | Nintendo DS Lite Console
I just got a new i68 and it wont unlock.
try calibrating your touch screen. Please use the stylus to calibrate!
The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until
"Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions
on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first
see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and
eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen,
immediately press the side volume button in the down position. A white calibration screen should now
show & you can calibrate the touch screen using the stylus. Try to tap as close to the center of the little
pulsating icons as possible, as this will more accurately calibrate your touch screen. If the calibration
screen didn't come up using that method, then you can get to it from the Main menu screen.
Select "Settings", then select "Pen calibration", & follow the previous instruction.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
May 07, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I9 Phone Unlock wont move
Try Calibrating the touch screen. Listed is the instructions how.
Apr 22, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Garmin Nuvi 350 Calibration Issue
Turn the unit off. Press and hold down the power button and keep holding it. You will see the screen light up and it will say "pre-boot mode". Keep holding down the power key. It will then say "booting". Keep holding the power button down. You'll then come to the calibation screen. Select the dots and you'll be back in business.
- Jim
Oct 20, 2008 | Garmin Nuvi 350 Car GPS Receiver
Mtusbubishi Diamond Pro 900u-I cant seem to adjust to screen in a perfect squre
the best way to adjust is first of all you reduce the height or make picture cinemascope. now from select button agjust vertical & horizontal geomatry now you increase the height as a whole. I think this will solve your problem. you can also refer owener manual if you have it.normally it comes with monitor. good luck/
Sep 29, 2007 | Mitsubishi Diamond Pro 900U 19" CRT...
Nintendo DS Console Logo
215 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
