Question about ViewSonic VX1940w LCD Monitor
How do you disassemble a viewsonic vx1940 lcd monitor
nileshsingh2
  • 246 Answers
SOURCE: instructions on how to disassemble and fix a Viewsonic VX2235WM
Picture tube is not major problem. It is the main board, having damaged capacitors, could be more then 1. Other components to look at is, high voltage tranisitor, which gives up in most cases. Most cases in my career, i found that monitor tubes are good, unless the are dropped. So resolder the main board and check out for the components i mentioned. Careful while repairing, it has high voltage, take all precaution while openining the panel. Unsrew all the screwsat the back, also the stand, take a flat screw driver and lever the panel from one end till you open all the 4 sides. Thanks, and don't giveup.
Posted on May 19, 2010
rulds2008
  • 3866 Answers
SOURCE: Viewsonic VP2030b LCD monitor - No power
There should be one fuse in the power supply inside. You can check and replace that if its dead. now if its not dead and you got power to that point you do need to rule out any capcitors at that time but if the fuse is gone it will not hurt to check the rest of the supply for the fault.
Please rate and accept the answer if it did help.
Posted on Aug 18, 2009
  • 47 Answers
SOURCE: ViewSonic VA703m 17'' LCD monitor Issue
I would make sure that all the cables are securely connected to both the monitor and the pc computer (screwing the screws from the cable to the port will help hold the cable in). Beyond that, the issue is likely with the monitor and not something that can be fixed by the end user.
If the device is still in warranty (and checking the cables don't work). I would recommend sending it back to ViewSonic to have it fixed.
Posted on May 16, 2010
  • 2666 Answers
SOURCE: I have 17" LCD viewsonic
Yes you can if you can source one however it may be more cost effective to replace the monitor.
Posted on Nov 03, 2010
budmrtn
  • 11361 Answers
SOURCE: ViewSonic VE170b 17" LCD Monitor Faulty power
You need to check the fuses on the backlight inverter board, also the logic board may be damaged by the AC voltage.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Dec 02, 2010
How do I remove the back of my ViewSonic VX1932WM-LED monitor
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Oct 03, 2014 | ViewSonic VX1932WM LCD Monitor
How to disassemble?
pankaj29, A 1 to 2 hour visit to YOUTUBE may help!!!! Search using "lcd monitor disassembly" and "lcd monitor repair" just for starters. Lot of video clips that will help you "part" the fromt "bezel" from the rear "cover". Do not use sharp cutting instruments for prying!!!! One careless slip and it's off to the local hospital "ER" or maybe call a mortician!!! 12fixlouie
Oct 24, 2010 | ViewSonic VX2235WM Monitor
I have two Viewsonic VP2030B monitors that both died together. Possibly a resolution or scan rate problem but I need a bit of help disassembling the things. The main chassis seems to be held in place...
wa7tuv, If the plastic front "bezel" is very thin and the monitor control and setting buttons are located on the verticle sides of unit, it just may be that the "bezel" will need to be parted from the rear cover, with the glass lcd panel left in the rear panel. Then you will need to remove screws so you can get lcd panel out of the rear cover. You might just get lucky and find a video of some owner/technician doing a tear-down if you search YOUTUBE using "lcd monitor disassembly" or "lcd monitor repair" as search terms. Be very careful and protect the glass lcd screen at all times. It is the most expensive part of the unit. You CRACK the glass, It's you bought it, you own it, Toyota!!!! You could also check with Viewsonic to see if they have a cash+old unit exchange program for out of warranty,but prematurely failed units that will be swapped for same model "refurbished units????? 12fixlouie
Sep 16, 2010 | ViewSonic VP2030b 20.1" LCD Monitor
ViewSonic VP201b with a black screen
hramirez, Retevo. com says time to retire this old monitor. Its that or you will need to do some extensive reading here on fixya on how and what to look for inside the unit that could be causing your black screen condition!!! Then you will go to YOUTUBE and view some of the many video clips that deal with "lcd monitor repair" and lcd monitor disassembly". Have you noticed any bad, swollen top, elcetrolytic filter capacitors on the units "switch-mode-power-supply/CCFL inverter printed circuit board?? How about any "cold" frosty looking solder joints around the component leads of the power transistors and ferrite inverter transformers? May need to get large magnifying glass to find those pesky little cold solder joints. 12fixlouie
Jul 26, 2010 | ViewSonic VP201b 20.1" LCD Monitor
What is the procedure for disassembling the VA712B monitor?
mercoman, Do not use any sharp cutting instruments. See disassembly VIDEOS on YOUTUBE of typical PARTING of rear cover from front bezel. Start at bottom edge looking for place to insert dull flat-blade screwdriver. Use caution. 12fixlouie
Mar 04, 2010 | ViewSonic VA712B 17" Flat Panel LCD...
Dead on arrival need to open back cover
emtv_satc852, First visit YOUTUBE and watch some of them being pried apart at their perimeters around the four edges. That's how most of them are opened. Some people use an old CD or DVD disk, while some use thin blade screwdrivers. Try "lcd monitor disassembly" or "lcd monitor repair" on YOUTUBE. Good luck. Hope this helped. 12fixlouie
Feb 25, 2010 | ViewSonic VX2433WM 23.6" Monitor
How to open lcd cover on monitior
abhishekrath, You can possibly see video clips at YOUTUBE that demonstrate typical "monitor tear-down" if you do search for LCD monitor disassembly" and "LCD monitor repair". Let me know if this info was of some help to you. 12fixlouie
Feb 23, 2010 | ViewSonic VA1912wb 19" LCD Monitor
I have a ViewSonic VA703B, I need to get it working but I cannot get the back of. How can I get the back of.?
gregmclure1, Most rear covers kind of snap-apart from the front plastic bezel. need to remove pedestal first. Best thing to do ,go visit YOUTUBE view typical "LCD monitor disassembly" and or "LCD monitor repair" videos FYI. PROTECT THE LCD PANEL AT ALL TIMES!! You may even find a video of someone working on a VIEWSONIC monitor. Hope this helps. If it does, then rate this on fixya.
12fixlouie
ps What will you be working on once the back is removed? Do you know what to look for?
Dec 04, 2009 | ViewSonic VA703B LCD Monitor
ViewSonic VX1940w LCD Monitor Logo
576 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
