Question about Kenmore Dishwashers
No water entering the dishwater. water supply is hooked up and water supply valve is in the open position. Could this be a water pump problem or is there a cut off valve entering the back of the washer that could be in the closed position?
    Sergeant:
    Champion:
  • 351 Answers
No cut off on washer check float switch make sure its free check water valve make sure wires are on it and water getting to it
Posted on Sep 30, 2010
Why is fresh water tank filling up when hooked up to city water?
Many RVs have the plumbing to fill the fresh water tank from the city water hook up. This valve is usually near the city water hook up and labeling is similar to "city water" and "tank fill". Another anomaly from leaving the valve in the "tank fill" position is that, when not connected to city water, the on board pump may run continuously and the water volume is very low.
Jan 25, 2016 | RVs
Ice maker stopped working
run service test with volt meter hooked up to the two terminals on water valve if you get a 110 volts to water valve when it is called for and water valve dose not open then the valve is bad. make sure the water valve screen in the end of it is not stopped up.
Jun 19, 2013 | Kitchen Appliances - Others
Water won't come into dishwater
Make sure your brass line or braided line is hooked up with no kinks or pinches, Then make sure water to valve is turned on.
Sep 05, 2012 | Whirlpool 24 in. DU920PW Built-In...
Problem is put the dishwater on ,doesnt seem to be enough water on the cycle ,dishwater goes through the whole cycle even drys, but has some water lying at the bottom at the end .Some said it might be a...
Check that your supply faucet is open, Check if there is a screen in the supply line, these can become blocked due to scale deposits from the mains. If there is no screen check that the inlet solenoid valve has not got blocked. If none of the above help, check that there is power getting to the solenoid valve when the machine is supposed to be on the fill cycle. If no power is betting to the valve, the timer might ba faulty. (You can try hand filling the machine and see if it goes through a cycle, at least up to the rinse stage, this will tell you if the timer control is working).
If you feel that there is water not being pumped out, remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Feb 18, 2011 | Indesit Dishwashers
I have an f3 and f4 error code on asko washing machine front loader. i know what the error codes are just dont know where they are anyone can help I need it thanks
F3 indicates a problem with the drain pump. At the bottom left of the machine, theres a square cut-out. This is where the drain pump is located. Using a flat head screwdriver or similar object, insert in opening on right side and gently pry open the drain pump cover.
Once the cover has been opened, be careful when opening the drain pump, as there is always a little water left in the drain pump. Before you open the drain pump, place a small container on the floor below the drain to catch the water. Pull the small black hose from the door and let the water drain into the container. You can now open the drain pump to clean it out. Also clean the pump rotor at the back of the pump housing. Replace the drain cover and reconnect the drain hose securely back to its position on the door. Close the cover.
F4 indicates a problem with the water inlet valve. Make sure the water supply is fully turned on. If no water enters the machine, then turn water supply off. Disconnect the hoses from the water inlet valve to see if the strainer in the inlet connection is blocked. Reconnect the hoses and turn on water supply. Hopefully this solves your problem.
Feb 14, 2011 | Asko W6441 Front Load Washer
Water keeps filling even if dishwater is off or if the door is open, the only way to stop it is from turning tap valve off below the sink.
Your dishwasher water fill valve is defective. Remove power from the DW. Remove the bottom toe kick panel. The water valve has the incoming water line connected to it.Remove the wires from the valve. If the water stops entering you have a bad timer. If it makes no difference you have a bad valve. The valve is a replaceable part. The timer is a replaceable part.
Dec 16, 2009 | KitchenAid KUDS01DJ - Multiple Color...
Water does not heat up
sounds as if the water supplied to your dishwater is on the cold side supply. Dish washers do not heat water themselves they have the hot water supplied to them from the hot side of the water supply to the house. Very few dishwashers have a water heater hook up built into them.. I would check the water supply to the dishwasher I think there is where your trouble is. Good Luck
Dave
Aug 07, 2009 | Dishwashers
I have a ge reverse osmosis filtration system and recently lost pressure and tank capacity. I have only had the system about a month and my water has been tested fine. I did leave town for 10 days, could...
Make sure that all valves are in the open position.
Try to recharge the water storage tank. Here are the steps to follow.
* In General: When any type shut-off valve handle is positioned so that it is parallel or in line with the tubing that enters the valve, valve is OPEN. When handle is turned perpendicular to tubing that enters valve, valve is CLOSED.
Necessary Supplies:
1) Tire Gauge marked in 5psi increments (ie 5, 10, 15, 20psi, etc.)
2) Bicycle tire pump for standard type bike tire valve
To recharge RO system tank:
1) Close cold water feed valve (valve located at some point along the cold water line from street plumbing).*
2) Leaving RO tank valve on, turn tank on side & locate valve stem on bottom side.
3) Remove stem cap.
4) Drain all water out of tank through open RO faucet into sink. (Continue to leave RO faucet open throughout procedure)
5) If current tank pressure is insufficient to empty tank, apply tire pump to valve stem and pump 10 – 15 times. Exit flow will increase and then gradually decrease as pressure equalizes. Do not overcharge internal bladder of tank during this
procedure.
6) Repeat step #4 until tank is completely empty. (Tank is empty when additional pumping produces no more water)
7) At this point, adjust EMPTY tank to exactly 7psi. (Gauge reading midway between 5 & 10psi is sufficient)
8) Turn off RO faucet.
9) Replace cap on valve stem and reposition tank in upright position.
10) Open cold water feed valve.*
11) System water is useable immediately, however, tank will take 3-4 hrs to completely refill.
www.FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Apr 27, 2009 | General Electric Profile Smartwater Ultra...
Have a kent r/o system dont know how to hook it up is there any way someone can help
Necessary Supplies:
3) Remove stem cap.
procedure.
Apr 13, 2009 | Culligan Under Sink Water Filter
WATER IS RUNNING EVEN WHEN IT IS OFF
yes, a broken valve which is a stuck-open valve...to test, remove power and slowly open main water supply and observe...no water should flow.
Nov 07, 2007 | Bosch SHU4006 Dishwasher
Dishwashers Logo
65 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
