Question about Roper RGX4634KQ Gas Dryer
My dryer is not turning on when I press the start button. For a couple weeks, now and then, the dryer did not always turn off when I opened the door. I notice the safety tab inside the door is not stiff any longer. It moves freely forward and backward so there's no resistance against the dryer door. There is a screw on either side of the safety tab. Can this tab be replaced?
  • ncurran321 Sep 30, 2010
    Prompt answer! To whom do I give the dryer number to?
    President:
  • 1,554 Answers
You must be referring to the door switch and it can be replaced easily. Indicate the exact model number of the dryer for the exact replacement part and the specific procedure in replacing it. You don't have to accept and rate this in order to post follow-up questions and additional information. But accepting a solution will not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 30, 2010
  • Jahn27
    Jahn27 Sep 30, 2010
    Post the exact model number here.
My dryer quit working one day last week. We unplugged it and flipped the breaker it still would not turn on. The very next day I pushed the buttons and it turned and worked for about four days. I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 14, 2011 | Whirlpool GEW9250 Electric Dryer
Start button buzzes when pressed, dryer doesn't start.
I assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Apr 26, 2011 | GE DVL223EBWW Electric Dryer
The dryer won't run and no power when you press the power button but the lights inside will turn on when you open the door what is the problem to it?
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 16, 2011 | LG DLE7177 Dryer
My dryer is not drying and/or spinning
there could be a couple of thingsthat would cause this,,,,,One a bad door Switch.2 bad start switch.3 a bad thermal fuse.open the door and hold the door switch in by hand have someone press or turn the start button while you try and turn the drum by hand.If it starts then you may have bad contacts in the motor and needs to be cleaned out.
Nov 13, 2010 | Frigidaire Dryers
LG DLGX2502V not turning on when start button is pressed. The light comes on when the door is open so I know it can not be a power problem.
heatman101 ..
Oct 20, 2010 | LG DX2502V Dryer
Dryer will not start when I push the start button. All I get is a loud buzzing.
The buzzing is a good sign that the motor is bad...
heatman101
Oct 11, 2010 | Maytag MDE9700AYM Electric Dryer
Whirlpool Super Capacity Dryer Front Loader 7kg : Drum does not want to tumble after push-button start. I opened the door and held the door switch in position as if door was closed. Then turn the drum into...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The motor is going bad...
heatman101
Aug 24, 2010 | Whirlpool Dryers
My dryer is making a buzzing sound when trying to turn it on. Not working. Cleaned lint in machine. Also made sure the door is closed. This happened a few weeks ago, didn't work for a few days and then...
the buzzing noise is the motor trying to start try a test leave the door open with one hand press the door switch with other hand spin the drum at the same time have someone press the start button if your dryer starts then and when it is cool it is the motor replace the motor
Apr 05, 2010 | Dryers
Kenmore Elite HE4 beeps three times when start panel is pressed and wont turn on
FWIW ... the Sears guy came by yesterday. The problem was apparently that the door latch was not operating to the extent that the sensors thought the door was open. He is replacing the latch next week. He adjusted the old one in the mean tiome and it appears to be working fine.
This kind of stunned me, since my wife reported an electric zap and the interior light burned out as the dryer went dead -- so I was sure it would be a fried circuit board -- but, no, a little jiggling of the latch seemed to clear it up....
Jun 24, 2008 | Kenmore Elite HE4 Electric Dryer
Roper RGX4634KQ Gas Dryer Logo
292 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
