Question about Whirlpool Duet GHW9150P Front Load Washer
Whirpool GHW9160PWO My door would not unlock on washer after load was finished washing. We pulled the door open very hard but now it won't close. Is this repairable without having to call repair man? I hope so!
  • Anonymous Mar 20, 2014
    The door won't open - washing is finished but can't get washing out.
  • 5,911 Answers
There is a manual release that you should have used. You may have potentially damaged the door latch assembly now. These door latches can take some punishment but usually don't survive being pulled open or slammed real hard. If you need to replace it, click on the following link for step-by-step instructions:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
This is an easy repair that anyone can accomplish, if you read and follow the instructions. This can save you the added costs of labor charges from an appliance repair company.
You can find a replacement door latch at searspartsdirect.com. Just type in your COMPLETE model number in the Search window and you can locate your part under the "Door Latch Parts" heading on the next page. The part you need is listed as Item number 7 (part #8181700). As I stated before, the purchase price is a far cry cheaper than paying a repairman, and you can repair this yourself.
For your reference: If your door becomes jammed in the future, simply remove the lower panel under the door and reach in behind the front of the cabinet behind the door latch. There is a small round pull tab at the bottom of the latch. Just pull it straight down and the door will open manually. Sometimes these doors will do this. Don't know why...call it a "glitch".
I hope this helps you. Please post back you have further questions.
Posted on May 25, 2008
I am getting an error it is as follows: finished, spin, and wash lights blinking plus 3 beeps. What does this mean?
Try restarting it, make sure the load isnt to heavy, if that does not help, call a local repair man.
Nov 06, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Electrolus front load washer door won't open
Hello - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
Nov 20, 2012 | Electrolux Eiflw55hiw Front Load Washer...
Washer won't unlock
These doors are usually on a timer and so won't be released for opening until a couple of minutes have passed by after turning the machine off.
Assuming you've already allowed for this, try giving the door a good firm push (closing) on the mechanism. It may just have caught partially closed.
Apr 28, 2012 | LG WM2455 Front Load Washer
LG WM3431 door won't unlock
did you unplug it,leave it unplugged for 5 minutes and plug it back in,if it's to hard to get to plug flip the breaker and leave the power off for 5 minutes or longer when you power it up again the door should unlock.here's a link to check hope it helps
https://www.google.com/search?q=lg+front+load+washer+how+to+manually+open+a+locked+door&oq=lg+front+load+washer+how+to+manually+open+a+locked+door&aqs=chrome..69i57.21935j0j8&sourceid=chrome&ie=UTF-8#kpvalbx=1
Dec 29, 2017 | LG WM3431 Front Load Washer / Dryer
I pushed the 'pause' button during the wash cycle of my LG WD-3274HD and now the door won't open.
Hi!
The machine knows it dint't finish the washing cycle, and, because it may be possible that water is still a lot inside, the door is locked.
If you are shure the door can be opened without the water coming out by the door, simply disconnect it from the electrical supply and wait a few minutes until the door unlocks. (you will hear the unlock click)
Aug 08, 2011 | LG WD-3274RHD Front Load Washer / Dryer
My Hoover 1600 AAA Vision HD 8 kg. Washing machine will not open the door after programs are ended. I can run all programs, but when finished the door will not unlock! What is wrong? I dont have the...
try pushing the door really hard if it opens check the door seal is on properly sometimes they pull off when removing clothes they can get trapped in hinges
Jan 17, 2011 | Hoover AAA160 Front Load Washer
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Door will not close
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Thank you !!
Jul 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity door will not lock when door is closed or register door is not closed when open
Apr 21, 2010 | Frigidaire ATF6700F Front Load Washer
Washer door won't unlock
im sorry to tell you but you may need to get a repair man out to fix the lock from the inside of the washer its sort of stoped half way through its washing cycel
i gess the drum suport springs have poped off and thats why it went for a walkys in the first place
Oct 25, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
370 people viewed this question
Dan Webster
Dan Webster
Sal De
