Question about Palm Treo Pro Smartphone
I dropped my treo pro in the toilet and got it out instantly and took out the battery and dry it. It worked fine but after a few mintues, the screen is just dark and won't light up. I can vaguely make out everything but it's like the back light is not working or something
  • 30 Answers
Even if it is a split second, liquid has a better than avaerage chance of getting to parts that liquid should never touch in electronics. If you turned in on after a few minutes and not putting in something to absorb the mositure for a day or two, better than a good patting down, it is possible that turning it on with liquid inside the phone could hace short circuited the display and/or other parts. Like I said, it does not take liquid long to get to areas you can not dry externally. It is possible that if there were more than water in the toliet, that it could hace left a reidue as well causing a short. Check with your cell phone store or repair shop for a diagnostic.
Posted on Sep 30, 2010
Dropped lg touch in toilet
its not dry enough... Blow dry it 1 to 1and a half meters away from phone a minute every 2 hours... with a minimum of 3 days...
Jan 19, 2013 | LG Dare VX9700 Cell Phone
My phone screen went blank after dropping in the toilet
You should have left it dry instead of turning it on, you probably have corrosion now, find a local place that works on phones to see if they'd work on it.
If you want to try to completely dry it, put it in rice for 24 hours minimum to draw out all moisture.
Aug 03, 2017 | Motorola Mobility RAZR V3
My samsung impression dropped in water and touch screen broke
I also dropped my Samsung Impression in the toilet, I immediately took the phone took the protective case off, took the battery cover off, and took the battery and my SIM card out and towel dried it as best as I could. Then I sat it on the floor next to my fan and let it dry until I got to my grandparents a little while later and I put it in a bowl of rice, completely covered the phone and battery with rice and left it sit overnight in the rice and all of the next day, so far i've had it on about 20 minutes and have had no problems with it so far, another solution is to sit it in the sun, to further dry it out. Water damage will void warranties on your phone and battery and your provider will know instantly if the damage was water related when they take your battery cover off, there is a small square sticker that when dry and hasn't touched water should be white, but as soon as it comes into contact with water it turns red, there is also one of these stickers on the battery. My stickers were red and after sitting in the rice they look like they got lighter in color considerably, I don't know if that is really possible but appearance wise it looks that way. I hope this helps anyone who has had this problem. Good Luck!
Nov 15, 2009 | Samsung SGH-A877 Impression Cell Phone
I dropped my cell phone in the water
http://www.fixya.com/support/r3771170-phone_water_damage
Oct 08, 2009 | Motorola Mobility RAZR V3
I dropped my phone in the toilet
take your sim card out and any memory chips. These can usually be salvaged. You might get lucky with the phone, but most likely, even taking it apart and letting it dry, it won't work correctly.
Oct 07, 2009 | Palm Treo 500 Centro
Screen doesnt work
if you have a screwdriver, you can open the phone up and check if it is still dry or wet and also look to see if there are any burnout marks (greeny-blue or white).air it for an hour or few and put it back together. try again. is it pos 5 or pos 6 bit. or is it tork 5 or 6, at jay=car or dicks or bunnings if you don't need advice on it.
May 30, 2009 | Lands Phones
I dropped my sidekick 2008 in the toilet
really the only thing to do in this case is to let it dry COMPLETELY before putting any power to it. if you let it dry completely now it may still work but if you tried it already and it failed i doubt it. try a new battery if it wont turn on. i dropped my nokia in the toilet and let it dry for 3 days then it worked; had a buddy spill his bottle of beer on my blackberry and after the defrost and over night it worked fine.... good luck
Apr 26, 2009 | T-Mobile Sidekick "Gekko" cellular phone
I dropped my LG enV into a puddle of water.
Sounds like you will need a new battery. My env2 would only work if plugged into the wall charger after I dropped it in the toilet. I got a new battery and it works fine now!
Mar 12, 2009 | LG enV VX9900 Cellular Phone
Sidekick 2008 got wet
I dropped a phone in the toilet once, a T-mobile phone. it took a couple of days for it to dry out completely. Then I snapped it back together, and it was fine. Being that yours just got wet, and not immersed is different though, so you may want to take it into T-mobile and see if they can check it out for you because then you will know for sure what is going on. Good luck.
Jan 12, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Dropped in Toilet
See if it will turn on when you remove battery and plug it into your charger. If it will you could recover the numbers with the Motorola software or the Carrier could.
Jan 12, 2008 | Motorola Mobility E815
Palm Treo Pro Smartphone Logo
56 people viewed this question
Top Palm Cell Phones Experts
Computer Repairing
Computer Repairing
fhonwizards
wayne chamberlain
Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
