Question about Roper RTW4100SQ Top Load Washer
My washing machine will not spin the water out after washing
  • Roper Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 30, 2010
parjee
  • 83 Answers
SOURCE: my hec washing machine is not spinning and the water wont empty
Try turning the spin basket, something may have jammed itself inside the tub. You can remove the front kick panel and remove the tub to pump hose to clean it out.
If ok, you might have other problems like a broken belt in the back.
Posted on Sep 28, 2009
SOURCE: washing machine not spinning or draining water
I have the same washer, WT-R801. Does the machine stop all together when the spin cycle arrives?, if so check the pump on the drain. Mine was burnt out. Its available for $61.00 delivered from Adelaide. Steve.
Posted on Mar 31, 2008
jtbjtb
  • 135 Answers
SOURCE: WASHING MACHINE WON'T DRAIN ALL THE WATER
Check the drain hose for a kink, or inspect it for plugging with lint. Hope this helps!
Posted on Feb 16, 2009
canbruce75
  • 1776 Answers
SOURCE: machine spins but water stays in machine
I would check for a clog somewhere. Make sure the drain hose is not kinked or clogged. Take a flashlight and look into the suction port on the pump. Make sure it is not clogged and check the pump impeller. Make sure no blades are broken or missing and that the impeller turns freely. If any blades are broken or missing or if the impeller won't move freely, then the pump will have to be replaced. Hopefully it is just a clogged pump or drain line. Hope this helped and best wishes.
Posted on Aug 09, 2009
  • 272 Answers
SOURCE: water does not spin out of the washing machine
Greetings,
If this washer is letting the water out, but its just the clothes are really wet and not spinning. Its probably the drive coupling...if the tub is full of water and its not making any noise during the spin period...Its possible you have a defective lid switch....its always possible with a full tub of water you have a stuck or bad pump. Remove pump from motor and see if you can turn impeller and at this point you can also see if your coupling is defective..Bruce
Posted on Oct 10, 2009
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Spin cycle not working properly. A little water (1 inch) is left and clothes are heavy with water. I tried the spin cycle repeatedly - water still at bottom of tub.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Aug 10, 2011 | Maytag Centennial MTW5800TW Top Load...
Wt you mean by spin in washing machine
its a separate cycle all by itself.
Say U hand wash something in a sink and instead of wringing it out by hand U can put it in the washer and press this SPIN cycle.
So U can also use it to spin more water out of your garments after the regular wash and spin cycle.
Slower spin speeds mean -
  • Cheaper washing machines
  • Quieter washing machines
  • More stable washing machines
  • Longer lasting washing machines because there's less wear and tear on the bearings, motor, carbon brushes, suspension etc.*
  • Gentler on laundry
  • The drum spins for approx 4 or 5 mins. No water is added and you dont add detergent or fabric softener for the spin only option. The object of the exercise is to centrifugally remove excess water from the garments in the drum. They will still be damp but not sopping wet after the spin cycle
  • Spin takes the water out, extract is even better
May 17, 2011 | Frigidaire ATF6000ES Front Load Washer
The wash machine washes but will not allow the water to go out, it just constantly spin and then slow down and start to spin again and again and the water stay in washer. It has a new timer.
heatman101
May 16, 2011 | Washing Machines
Water does not drain automatically wahes and spin
heatman101
Mar 04, 2011 | Washing Machines
Water drain open even washing mode and during spin water not drain
heatman101
Aug 29, 2010 | LG Washing Machines
Crosley CW6000 Washing Machine. When my washing machine is in the spin cycle, it shakes severely and the machine on the floor
My Crosley Cw6000 wash will not spin the water out, I lift the lid to watch the spin cycle, it spins but the water does not drain..
Sep 02, 2009 | Crosley CW6000 Front Load Washer
My washing machine wont spin anymore
my washing machine makes a horrible noise while washing and retains water after spinning. what help can i get?
Nov 24, 2008 | Roper RAS6233KQ Top Load Washer
Washing machine is not spinnig out the water
Does your washing machine spinning? if the washing machine is spinning and the water won't out, the release valve didn't open.
If the washing machine is not spinning, the fin belt broken.
Jun 27, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
Aug 31, 2007 | Washing Machines
Roper RTW4100SQ Top Load Washer Logo
190 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
