Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Keyless entry on outside of garage does not work. I have changed the batteries. I have tried to change the code and set a temporary code. Nothing works. Also, I can't get it off the side of the garage to replace it. It is held on by just sliding over a couple of screws? Don dondana58@sbcglobal.net
    President:
  • 3,197 Answers
The bottom screw that is located in the battery compartment must be removed and then using the heel of your hand hit up on the bottom. You will need to replace it.
Posted on Sep 30, 2010
How do I change the keyless entry code to another number
How to change the code on a Chamberlain Keyless Entry Garage Door opener
How do I add, program or change a Keyless Entry PIN?
Your new Keyless Entry must be programmed to operate your garage door opener.
Program using the "Learn" Button
  1. Press and release the "learn" button on the motor unit. The learn indicator light will glow steadily for 30 seconds.
  2. Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
  3. Release the button when the motor unit lights blink. It has learned the code. If light bulbs are not installed, two clicks will be heard.
Program using the Multi-Function Door Control
NOTE: This method requires two people if the Keyless Entry is already mounted outside the garage.
  1. Enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold ENTER.
  2. While holding the ENTER button, press and hold the LIGHT button on the Multi-Function Door Control.
  3. Continue holding the ENTER and LIGHT buttons while you press the push bar on the Multi-Function Door Control (all three buttons are held).
  4. Release buttons when the motor unit lights blink. It has learned the code. If light bulbs are not installed, two clicks will be heard.
Change a Known, or Existing Pin/Code
If the existing PIN is known, it may be changed by one person without using a ladder.
  1. Press the four buttons for the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
  2. Press the new 4-digit PIN you have chosen, then press ENTER.
The light on the motor will blink once when the PIN has been learned.
Test this by pressing the new PIN, then press ENTER. The door should then move.
I hope you find this helpful. If you need further assistance please let me know!
Have a great day! :)
Carrie
May 22, 2011 | Chamberlain Keyless Entry
Some reason keyless entry won't open my garage door. I have directions to change the code but, there is nothing in the manual if your code no longer works. I have changed the battery, pulled the plug on...
If that keypad quit after working since 1997 and a new battery didn't get it going it has just gone bad. The model number listed for your opener is now 53876.
Oct 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
We have installed a chamberlain wireless keyless entry. The problem is that when our neighbors house uses their keyless entry our garage door opens without us using our code. We have checked this seveal...
We have a Chamberlain Whisper Drive Plus. The keyless entry stopped working, suddenly. I have changed the battery, not the problem. I cannot get it to work, and cannot get it to reprogram. The keypad lights up when buttons are pressed, but when I press "Enter" the whole keypad flashes for about 30 seconds and then just goes dark.
May 10, 2010 | Universal Garage Wireless Keyless Entry...
I need KLIK2 remote instructions
How do I connect KLIK2 to a linear with a learn button
Feb 17, 2010 | Universal Garage Wireless Keyless Entry...
Craftsman Model 139.53684 Keyless entry doesn't work
The remotes and keypad use the receiver which is part of the logic board.'t The button on the wall is hardwired and doesn't use the receiver. You might pull the logic board and check for bad connections on the printed circuit.
Nov 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
I changed both batteries in the car remotes. I can program one remote but cant seem to get both remotes to program at the same time. I reset the srt button on the back of the opener. Also I some how...
Hold the button down on your remote and then press and immediately release the smart/learn button. Do this for each remote.
Press and immediately release the smart/learn button and then walk over to your keypad and key in your 4 digit code and press enter.
The key to this is to immediately release the smart/learn button. If you hold it in you will erase what you just did. If you still have a problem please post back.
Oct 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keyless Entry Problem
First try changing the battery in thh keypad 9V. if that dos not work just moving the wire coming from your opener towards your keypad. DONT CUT THE WIRE OR ADD TO IT. That should take care of it
Feb 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
I want to change the personnal code on the keyless entry on my garage door
Press the learn code button on the back (or side) of the operator. with in @ 40 secs. press in your 4 digit code on your keyless and press the enter button @ 2 secs.
Sep 28, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Trouble changing passwordon model 940CB wireless keyless entry
easyer then that , you die! Open your garage door, take out the step ladder, a chair or get up on *********** in law's back, (here's your chance to be on her back for a change) press the read button of your unit (motor) a led should light up and on the key pad, key in the new 4 digits code and press enter, the light of the unit should blink javascript:; Post Solution
May 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
75 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
