Question about Harman Kardon Audio Players & Recorders
I have a Harman Kardon receiver which make me wait 5 minutes or so to have a sound. What seems to be the problem?
  • 4,234 Answers
This could be the amp circuit not turning on completely or the protection circuit not working properly. WIthout taking measurements inside the unit, I cannot state for sure what the problem actually is. I would suggest that this be examined by a service shop and that you get a detailed repair estimate. Post that info and we can walk you through the actual repair.
Dan
Posted on Sep 30, 2010
Harman Kardon 146 receiver not turning on.
Possible blown fuse inside unit, unplug and remove the top cover
fuse should be near the power board and transformer. replace with exact fuse, "Never remove covers with the unit plugged in" Always wait 4 or 5 minutes after unplugging to remove the cover.Replace cover before plugging unit back in.
Oct 06, 2014 | Harmon Kardon Harman Kardon Avr 146 5.1...
Working only after 10 minutes harman kardon
I dont know what to say bute it works bute i cant gett any sound from it it whas working and after i turnd it off then when i started it came no sound from it ?
Jun 18, 2014 | Harman Kardon AVR 130 Receiver
Harman kardon avr 151 stuck on tv speaker mode
Hi
Try this.
To reset the AVR's processor:
1. Press the front-panel Standby/On switch for more than three seconds to turn the AVR
off (the Power Indicator will turn amber).
2. Press and hold the front-panel Surround Modes button for at least 5 seconds until the
RESET message appears on the front-panel Message Display.
NOTE: After performing a processor reset, wait at least 1 minute before pressing any
Source Selector buttons.
Good Luck
Happy to help
Jan 04, 2014 | Harman Kardon Audio Players & Recorders
HARMAN KARDON AVR 130NO SOUND FROM SUB WOOFER
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Harman-Kardon-AVR-130-Receivers-manual/id/386ci155/t/2/
The receiver must KNOW it has a sub and you must decide how bass is managed among all your speakers and set up relative levels.
May 21, 2011 | Harman Kardon AVR 130 Receiver
No sound regardless of input. front panel lights up and functions as per inputs however also noticed pwr supply fan and internal heat sink fan do NOT turn on. Any debugging tips appreciated! Thank You...
The power supply has to be on to some extent or it wouldn't light up.
http://www.retrevo.com/support/Harman-Kardon-AVR-335-Receivers-manual/id/386bh133/t/2/
Does it tune FM? That would indicate some life.
No sound? Is it Muted or a tape Monitor selected inadvertently?
Page 53: Reset the processor...
Processor Reset
In the rare case where the unit's operation or the displays seem abnormal, the cause may involve the erratic
operation of the system's memory or microprocessor.
To correct this problem, first unplug the unit from the AC wall outlet and wait at least three minutes. After the
pause, reconnect the AC power cord and check the unit's operation. If the system still malfunctions, a system
reset may clear the problem.
To clear the AVR 335's entire system memory including tuner presets, output level settings, delay times and
speaker configuration data, press and hold the Tone Mode Button (5) buttons for three seconds. The unit
will turn on automatically.
NOTE: Resetting the processor will erase any configuration settings you have made for speakers, output
levels, surround modes and digital input assignments, as well as the tuner presets. The unit will be returned
to the factory presets, and all settings for these items must be reentered.
If the system is still operating incorrectly, there may have been an electronic discharge or severe AC line
interference that has corrupted the memory or microprocessor.
If these steps do not solve the problem, consult an authorized Harman Kardon service center.
Jan 28, 2011 | Harman Kardon AVR 335 Receiver
MY HARMAN KARDON GPS-500 WILL NOT CHARGER
If purchased in last 2 years will still be under warranty Harman Kardon support recommends Return to retailer for return to harman kardon for repairs.Seems that the battery and charger units for the gps500 models are not that reliable and as such may fail as fit for purpose.Contact retailer for returns policies in regards of warranty of units
Sep 10, 2010 | Harman Multimedia Harman Kardon Guide+Play...
My Harman/Kardon AVR 140 is stuck on stand by mode
I have the same problem on my AVR 1550 - its been bugging me for ages then it works again, then it doesn't ...
Aug 28, 2009 | Harman Kardon AVR 140 Receiver
Harman Kardon AVR325 stays in standby mode
Was a solution ever found for this? I have almost the same problem, except that mine makes a horrible sound through the speakers before it shuts off. However, after an attempt or two, mine usually starts working and sounds fine (I love how this thing sounds!). It seems to happen more when I've let it sit for a week or two. When I use it regularly, it usually works fine. It's almost like it knows when I'm about to give in and replace it... because it will start working again! Maybe I just need to make an effort to use it more....
Mar 22, 2009 | Harman Kardon AVR 325 Receiver
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Jan 11, 2009 | Harman Kardon AVR 130 Receiver
102 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
