Question about Epson Stylus C48 InkJet Printer
Printer will not feed/accept paper.
Front LCD reads error "Check Paper & Retry" When paper is inserted and loaded correctly and machine is reclosed the printer then initializes then reverses the feed of the paper and is ejected and error continues to reappear.
(Thank you for any help or insight you might have)
  • detroitzoo May 25, 2008
    this is for a sony up-dr150 digital photo printer
  • Anonymous Dec 04, 2008
    my epson c48 printers light keep flashing and it says printing but it doesnt tak the paper in or neither does it print it jus makes a sound and moves back wards any suggestions?
Hello my C48 epson printer is acting up when I try to print it wont let me the box flashes and i quote "please reload the paper correctly" what is wrong or how is it done?
Posted on Oct 02, 2008
Opikn
Posted on Jun 11, 2008
I had this problem. firmware upgrade is needed.
mine is fine now.
Posted on May 25, 2008
Remove paper from sheet feed when no paper loaded
It is possible that the genuine replacement HP sensor is defective.
Jan 09, 2014 | HP DESIGNJET T770 Printer
Please describe your cannon laserbase 5630 showing paper check error after printing one print problem:
Hi mani4u58,
After the print,does the alarm indicator show?
Are the papers loaded and aligned in the correct way in the printers cassette?Please align them well and also note that the cassette can hold only around 250 sheets at a go.Remove the cassette completely when loading the papers and after paper load,insert the cassette as far as it can go.Does the printer feed paper correctly?If not,there may be a paper jam.To clear the jam,open the front cover by pulling it towards you.Remove the cartridge and inspect the compartment.Also make sure the orange adhesive tape around the cartridge is full removed to free its connections.You can also unplug the printer and leave it for a while and then plug it back to clear jam.
Hope it helps.Thanks!
Mar 27, 2011 | Office Equipment & Supplies
How to print with the legal paper?
follw the given step and check-
1-Before printing your document, be sure the page size is set to legal paper. Go to "File> Page Setup" and then click on the "Paper Size" tab. Select "Legal" from the drop-down menu.
2-Go to the printer and take out the paper tray. Remove the letter size paper.
3-Insert about one half of the package of legal size paper into the tray, depending on the depth of your tray. Larger printers can accept an entire package, while smaller ones cannot.
4-Make sure that the paper goes underneath the metal clips located at both the front and back of the tray.
5-For printers that don't have a tray, you'll have to manually feed the legal size paper. Locate the paper feed either on the front or rear of the printer.
6-Put a few sheets of legal size paper into the paper feed. The paper should be placed as close to the rubber spindles as possible. These spindles will draw the paper into the machine and feed it through the printer.
7-Print a test page.
Thanks,
Dec 03, 2009 | Brother HL-2040 Laser Printer
The printer will not feed the paper into the machine
Hmm, this is too general symptom too troubleshoot. But never mind. Printer cannot feed the paper for several reasons:
Auto sheet feeder (paper feeding mechanisme) is faulty;usually generate error message on the monitor or/and error code on LCD display
Paper end did not reach paper sensor because the paper not set properly or another material block the paper path.
To find out more about this error,please check the following article exclusively for Canon printer.
Paper feed error
Paper jam error
Source: Canon Inkjet Forum
Oct 10, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Leading edge detection error When loading paper into printer this is displayed on the lcd scren
This is caused when the size paper loaded into the machine does not match the size the machine expected. Check the paper size settings to ensure you are using the correct paper setting. This also can be caused if paper loaded does not align correctly.
Jul 09, 2009 | Canon imagePROGRAF iPF8000 Printer
Single blank disk inserting wont work (Mircoboards PF2)
You may have a disc loading error. To correct this follow these instructions:
Disk Loading error:
If a disc is not loaded correctly, it could cause the out of paper indicator to come on. Press the out of paper button on the interface. The printer will attempt to load another disc. If this does not clear the error, remove the discs from the input bin. Check to see if there are any discs on the belt. Remove any discs that are left on the belt.
Lift the cover and check for any discs on the front part of the printer. Remove any discs found on the belts. Close the cover.
Next, reload the input bin and press the out of paper button. The system will load the next disc and continue printing the remaining discs for that job.
If that doesn't work, and there are no obvious jams in the transport system, I'd call support and see if they can walk you through a fix. They can be reached at:
For technical questions or support issues, please contact Microboards Technology technical support at PH: 952-556-1639, FAX: 952-556-1628, by email at support@microboards.com or on the web at http://www.microboards.net.
Mar 19, 2009 | Microsoft Windows XP Home Edition
Cassette error
On the control panel for the printer, there's a Feed Switch button that's easily touched by accident. Ensure the Feed Switch is set to the paper source you're using (e.g. either the back or front). The graphic of the printer next to the Feed Switch button will light up to indicate the paper tray it's attempting to use.
Dec 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
Papaer out error
Paper detection switch on tractor feed unit is probably faulty. Replace the tractor feeds.
Jul 15, 2008 | Epson DFX-9000 Matrix Printer
Paper feed problem
Check all this-----
1.check the printer paper feed roller jam.
2.check the paper sensor, It is working or not.
3.check the paper tray(clean it)
4.service the printer, (If possible).
Goodluck
Mar 10, 2008 | HP Photosmart 3210 Printer
Paper feeder not working
Are you sure the correct paper feed has the paper and the machine knows to pull from that feed?
There are two paper feeds on this unit.. one in the tray down front and one in the rear top. There is a switch on the left hand side of the front panel and whichever feed area you want to use should be GREEN...
Let me know.. we'll go from there if that's not it.
MaggieB
Feb 13, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Epson Stylus C48 InkJet Printer Logo
400 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
