Question about Nokia N800 Tablet PC
Lcd screen problem
I have a Nokia N800 and there are five lcd lights that shine through on right side of screen. Is this normal or should I return device for repair?
  • fperez01 May 26, 2008
    The term for the problem I found is Backlight Bleedthrough. I will be returning soon. thanks all
Strip problem
how to open N80
Posted on Jun 27, 2008
  • 24 Answers
If the lights didn't off, maybe your N800 is grounded. return it for repair.
Posted on May 26, 2008
Irulu displays dotted lines?
Such electronic devices from China generally aren't repaired under warranty--to be then returned to customers. Any such repair is not likely at a facility near your home in the US, anyway. If the fabricator or its importer contact here actually refurbishes these, it's likely performed at some single facility--the importer contacts (or perhaps the store--or another store) may then try to sell these again later, for a somewhat lower price, as refurbished units (perhaps not, though).
Once your return your tablet, the refurb process really has nothing to do with you. If you wait past the point of return and refund, the store then won't help you. The importer contact or company might instead send you another refurbished unit, after you ship your tablet--if it's still then technically under warranty.
It's far better to get the store to let you return it to get a refund, or to obtain a replacement--these are the best outcomes if it's defective. (People have trouble with refurbs, sometimes.)
If resetting to factory settings doesn't work, return it to the local store or follow the RMA process (return merchandise authorization) from the online store. If it's defective or broken after all, don't let your rights to return it to get a refund or replacement unit expire: Determine if it's defective in order to get return the process moving soon.
It sounds like a problem which likely may not be easily nor cheaply fixed. It's likely an LCD screen problem--perhaps the tablet was bumped around badly during shipping. (LCD screens really prove quite delicate. This is a larger tablet's LCD screen giving the problem now, after all--it's more likely to be damaged if it's not packed and shipped well.)
Aug 21, 2014 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
Hp entertaiment pc problem display STAYS BLACK BUT ALL LIGHTS COME ON
If the Video Controller fails, the screen will stay black when the rest of the computer runs as it should. To test this, look to the side of the computer and locate the external Monitor attachment. It is a nine pin male outlet. Take a regular computer monitor and attach it to the connection and turn on the computer. If the Monitor acts like your normal LCD screen, then the main LCD screen is bad. If Neither the Monitor or LCD works, then the Video portion of the computer may be defective.
Apr 15, 2014 | HP Pavilion Entertainment tx2500 Tablet...
My nokia n800 keep startin over and over what the hell happen to it?
remove the battrey and connect it again.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 24, 2010 | Nokia N800 Tablet PC
Scrolling desktop; scrolling programs
This was a common problem that N800's had. From what I've read, requires an lcd replacement.
Aug 12, 2009 | Nokia N800 Tablet PC
It was always difficult for me to switch on/off Nokia N800 as its button seemed too soft and fragile. And now I've been using Nokia N800 for 8 months and yesterday its button stopped reacting! It wouldn't...
Do you hear "clicking" when you press the power button? As if it registers the button but does nothing after the "click?" If not, then it sounds like the mechanical/electrical problem with the button. If you do hear clicking maybe if you simply do a battery pull it may reset what was freaking out the power button.
There is a way to reset the UI (rather than cycling the power) but it involves from shell commands:
the XTerm is in the utilities menu. Open that up and type:
/etc/init.d/mce restart
/etc/init.d/osso-systemui restart
Also in XTerm
shutdown -r now
will reset the N800.
Hope this helps,
Bill
Jul 11, 2009 | Nokia N800 Tablet PC
Nokia N800 screen problem
This is an issue the N800. You have to replace the LCD.
Nov 28, 2008 | Nokia N800 Tablet PC
Nokia N800 Tablet
I had the same problem with the n810. I was using a non-oem battery and the connections were a loose fit causing the battery not able to charge.
If you take the battery cover off, hold the battery firmly in place. Connect the charger and make sure battery is charging, then press the boot button. If it boots and stays on, then shuts off when you stop holding the battery. Then you probably have a loose connection or a bad battery. Also try cleaning the connector with a pencil eraser and alcohol.
I had to wedge tthe battery in place. You can find a spare battery with a desktop charger on Ebay for around $10US.
Oct 18, 2008 | Nokia N800 Tablet PC
Stylus replacement needed
I guess you need to contact the company directly. Check the link to 'Contact Us'. You can call them up or e-mail.
Try it. Good luck...
Oct 01, 2008 | Nokia N800 Tablet PC
Pictures
Navigate to the site with the pic's you want, hold down the stylus on the image, and select "Save.."
Dec 01, 2007 | Nokia N800 Tablet PC
Nokia N800 Tablet PC Logo
324 people viewed this question
Top Nokia Tablets & eReaders Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Nokia Tablet and eReader Expert? Answer questions, earn points and help others
