Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Salt not working through into the system
We have always regularly filled up our salt reservoir. But despite having not filled it up for ages the salt is now not ever needing to be filled up as it is full to bursting. Why isn't the salt working through the system? Is there a bit that's blocked that I don't know about? Any help and I'd be grateful!!
Finn
  • Finn Fordham May 25, 2008
    Thank you ! I like the idea of soft persuasion but I'm not sure what you mean by 'outside of the salt tank' - is that just the area around the hole into which I pour the salt? I can't imagine how this send enough of a tremor to break any salt bridge. The salt that's in there at present is not dissolved, but there's a lot of liquid around it. i/e it's not so dry, not dry enough perhaps to form a salt bridge ??
    I'll keep trying. THanks! But if you have any furhter illumination, other ideas, please let me know
  • 525 Answers
Salt will sometimes "bridge up" at the bottom of the tank.
Sometimes a "soft" persuasion to break up the bridge is required to get the salt to settle down where the water will dissolve it.
I generaaly use a rubber mallet to lightly tap on the outside of the salt tank. If successful, you can hear the salt bridge break up and fall to the bottom and the salt above will start to settle also. Once the salt has settled and it is using the salt, then keep the reservoir full to keep other bridging from forming.
If you are unable to break up the bridge, then the unit may have to disconnected and harsher means used to break up the bridge.
I would recommend that a technician perform this task.
Posted on May 25, 2008
Hi my kleenmaid silent system think it's a dw2 the salt button is flashing you turn it on it goes to start then stops we cleaned it all out and fix the problem once before but this time nothing works. I'm...
If water is soft in your area you can ignore the salt indicator light and operate the dishwasher without adding regenerating salt. However, you need to ensure the salt reservoir is filled with water to the brim. So add water into the reservoir and then put the cap back on.
Dec 26, 2014 | Dishwashers
Our water is soft and does not require salt. how do we stop the red light
I think it might depend on the model # and it should be in your manual.
Example for a G858 SCVI plus instructions (without pictures) are;
Bypassing the salt indicator
If your water is soft (below 8 gr/gal) the
salt reservoir should not be filled with
salt. The indicator will remain lit and
should be disregarded or bypassed.
Remove the salt reservoir cap.
Looking into the salt reservoir, you will
see the top of the float chamber on the
right hand side, a.
Using a screwdriver, carefully pivot
the float chamber towards the center
of the reservoir.
Using needle nose pliers, pull the
cap, b, off of the float chamber, and
remove the float, c.
Replace the float chamber cap, push
the chamber back into its upright position,
and replace the salt reservoir cap.
The "Salt" indicator should no longer be
lit.
Feb 17, 2013 | Miele Premier-Plus Built-in Dishwasher
Have an intex 16 x48" salt water pool generator
I checked the Intex web site and here is what they said:
There are several things you may need to check and do:
- Test the salt level first with Test Kit, and add salt as needed.
- Remove the electrolytic cell for inspection and clean it if necessary.
- If code 91 still appears despite the above steps, there might be a possible electrolytic cell
failure. Please contact Intex Service Center, and replace the cell if needed.
NOTE: Always turn the power off and disconnect power cord before cleaning and servicing.
I hope this helps.
Aug 24, 2011 | Intex Automatic Salt Water System for ...
My dishwasher says that it needs salt what sort of salt and how much?
HOW MUCH SALT DO I NEED TO ADD?
shim.gifYour machine may have a float indicator or a warning light to tell you when salt needs adding to the water softener. Often float indicators are difficult to see, and there is no accurate guide as to how much salt you need to add. Quite simply, just add granular salt to the reservoir until it won't take any more!
The softener will use the salt to replenish itself each time you wash. As an approximate guide, you should do a full top up about once a month. If your machine doesn't have a warning light, a good way to remember to check and / or top up is to do it on a regular day of the month (e.g. the first Saturday or the 15th)
CAN I USE ORDINARY TABLE SALT?
No. Table, cooking, rock and sea salts may contain additives that can actually increase water hardness. Also, the fine consistency of some of these salts mean they are likely to clog when wet. Always use granular dishwasher salt because it is very pure and is the right consistency for use in your machine.
Granular salt is the ONLY type of salt that should be used to regenerate the softener. Be aware that some varieties of 'dishwasher salt' use Dead Sea salt. This variety may contain minute insoluble organic matter that may adversely affect the resin within your softener over time. If you are in doubt about the origins of the salt, ask the retailer or manufacturer.
Sep 30, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Hard water, salt in in tank, what do i do
Make sure there is not a "Salt Bridge" in salt tank. Salt tank should always be at least 1/2 full of salt.
You may have just run out of soft water, run 2 manual regenerations in 24hr period. If no soft water still. The eductor assembly is plugged with iron or sediment and needs to be cleaned out. The eductor assembly is where the brine is drawn through to regenerate the resin.
RJ
Aug 12, 2010 | Culligan Sediment Water Filter Heavy Duty
Milky residue and a dry salt pot after each wash
It sounds as if there is a blockage in the salt matrix / inlet. This can happen if the wrong type of salt is used.
The simple answer is to use the expensive tablets/pods - that include salt. This will improve the wash and hopefully the blockage will free eventually.
Fill the salt container with water regularly to try and help dissolve it - no salt untill it's clear.
If it doesn't clear within a month - it may need stripping and clearing manually - or continue with the premium tablets untill something else breaks - requiring a service.
Aug 28, 2009 | Zanussi 18 in. DE4744 Free-standing...
Salt indicator light comes on?
Check the instructions which are freely available from www.miele.co.uk or the relevant site for your country. Browse to the current models and you should find the PDF for your model. For non-current models, instructions are under the link "Customer Support".
In general, the instructions are as follows:
If the water in your area is very soft and constantly lower than 0.7 mmol/l (4 °d) you do not need to add dishwasher salt. The water softener must, however, still be programmed to correspond to the water hardness level in your area. (The salt indicator light will still come on, but should be ignored).
Important: Before filling the salt reservoir with dishwasher salt for the first time, you must fill it with approx. 2 litres of water to enable the salt to dissolve. Once the dishwasher has been used, there is always sufficient water in the reservoir.
Inadvertently filling the salt reservoir with powder or liquid dishwasher detergent always leads to serious damage to the water softener. Make sure you have picked up the correct packet of dishwasher salt before filling the salt reservoir!
Only use special coarse grained dishwasher salt for reactivation. Do not use other salts such as cooking salt, agricultural grade or gritting salt. These may contain insoluble additives which can impair the functioning of the water softener.
To refill:
* Remove the lower basket and unscrew the salt reservoir cap.
* Fill the reservoir with approx. 2 litres of water (first use).
* Place the funnel provided over the salt reservoir and carefully fill with salt until the reservoir is full. The salt reservoir holds approx. 2 kg of salt depending on the brand used.
As the salt reservoir is filled, displaced water will overflow.
* Clean any excess salt from around the reservoir opening and then screw the cap on again firmly.
* Run the "Pre-wash" programme immediately to remove any traces of salt water from the cabinet.
For the Miele, the salt reservoir is usually under the bottom basket, the cap is usually grey in colour. [Only the latest models have the refill cap in the door itself].
You should be able to find dishwasher salt just about anywhere, I've even found it in Malaysia, sold at good ol' Tesco!! Brands of salt include Calgonit (Finish) & Somat.
Jan 05, 2008 | Miele 24 in. Novotronic G641 Plus Built-In...
Water in salt reservoir
I've had the same dishwasher for 2 years now and always had water in the salt compartment. Don't know if this is normal but disn't seem to be a problem til now. Just fill with salt as if it was empty.
Jan 03, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Salt Indicator Light Flashes Permanently On Indesit IDE 750 dishwasher
I think I have the answer.
On Yahoo Answers Blue Rizla Girl put up the idea that the sensor is some form of hydrometer. (i.e. floats in salty water sinks if not salty enough)
Based on this thought I postulated that the sensor is some form of hydrometer float in a tube with perhaps an optical sensor.
If this is correct why is it not working?
Is it because the float is stuck at the bottom of the tube, perhaps by some food debris? If so how can we fix it?
This is what I did on my Hotpoint FWD60:-
I took the salt filler cap off. There was no salt in the reservoir as it has been a problem for months, and I was only refilling it when dishes were not coming clean.
I poured 2 litres of hot water into the salt reservoir.
I then put the empty machine on the intensive 65 degree wash, half load and with the reservoir cap still OFF.
When finished I filled up with salt and HEY PRESTO the salt light is OFF!!!!
Just hope it stays that way until the reservoir really needs refilling.
While I was down on my hands and knees I took the opportunity to clean the filters in the sump. They do get full of bits!
I also flushed the sump by dashing a couple of cups of hot water into it and then bailing it out with a small yoghurt pot. I repeated this until the water in the yoghurt pot and the sump no longer had any signs of bits in them. (Dashing = vigorously pour)
I was amazed at how many bits I got out, especially considering I had given the machine a good clean in the past 6 weeks.
I even got part of a paper label!
So there we have it, try it out and report back.
Sep 14, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
908 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
