Question about Maytag MSD2756G Side by Side Refrigerator
Defrost for Maytag side by side
I think we are having the same problem with the thermostat/heater.  We have a Maytag side by side MSD2756GEB.  How can we figure out what we need to do figure out the problem than fix it.
  • 828 Answers
To access the heater circuit you must remove shelves from freezer, defrost the back panel with a hair dryer. Remove screws holding the panel in place and remove the panel. Defrost any ice on coil. This will give access to the heaters and defrost thermostat. If the defrost thermostat is deformed in anyway such as bulging at the molded part the chance is that that is your problem. Reading through the heater circuit with an OHM meter will tell you if the heater(s) are open. If you get an open reading replace the heaters. If this is above your capabilities call a service tech.
Posted on May 27, 2008
Maytag refrigerator MTB1504ARS runs continuously
It looks like you have a defrost problem. It could be blocked air vents but I think there is a problem with either the drfrost heater or defrost thermostat. It cound be the defrst timer or control but i would check the heater and defrost thermostat first.
Oct 04, 2014 | Maytag MTB1504ARS Top Freezer Refrigerator
Ice building up in bottom of freezer, of side by side maytag
Hello there,
When you are experiencing ice build up in your refrigerator, it simply is due to a faulty defrost unit. The defrost unit is composed o9f the defrost timer, defrost thermostat and the defrost heater. Once the freezer is building up ice, the defrost unit turns on the heater, then the defrost thermostat turns off the compressor while the defrost timer, settings the routine timing for the activity.
Once a component out of the three develops a fault, the routine is stopped and then ice begins to build up in the back of the freezer or at the bottom depending on the type of refrigerator it is.
The solution to the problem is for you to have the defrost timer, defrost heater and defrost thermostat tested, that way you will be able to tell the faulty component and replace it with a new one.
To carry out the testing and replacing of these components, please read this tips, it will guide you on testing the components and replacing them.
Defrost thermostat http://www1.fixya.com/support/r10513592-test_defrost_thermostat http://www1.fixya.com/support/r10513650-replace_defrost_thermostat
Defrost timer http://www1.fixya.com/support/r10523722-test_defrost_timer http://www1.fixya.com/support/r10523742-replace_defrost_timer
defrost heater http://www1.fixya.com/support/r10523771-test_defrost_heater http://www1.fixya.com/support/r10523754-replace_defrost_heater
Hope this was helpful to you. All the best. Elect_Comp
Sep 26, 2011 | Maytag MSD2756G Side by Side Refrigerator
My Maytag side-by-side is a MSD2655HEQ. The coils in the freezer compartment keep frosting over and the refrigerator side quits keeping cool air. I've defrosted the coils with a blow dryer and the...
The defrost circuit in you freezer has failed that is why you have to defrost the coils. The defrost circuit consists of the heater element, the defrost thermostat and the control module. The control module turns off the compressor and powers up the heating element to melt the ice on the coil, after the coil reaches 40 deg F the thermostat cuts off power to the heater. The heating element and thermostat is mounted to the coil. If you have a multimeter and know how to use one, you can check the thermostat and heater. You can check the heating element with a multimeter to see if it has electrically opened. If it has then you will need to replace it. Check also the thermostat, it should be in series with the heater. It should read close to 0 ohms if it is freezing and read infinite ohms if the temperature is above 40F. If the thermostat and heater check out, the problem might be with the control module.
Oct 05, 2010 | Maytag MSD2655HE Side by Side Refrigerator
My Maytag MSD2756GES freezer coil is completely iced over and fridge is not cooling. I think the defrost element is not working. Need a part #.
Defrost problems can cause the fresh food section not to work. You need to find out why it’s not defrosting. There are three things that cause a defrost problem: defrost heater, defrost thermostat and defrost control.
If you have an older refrigerator, it probably has a mechanical defrost control. Find it and turn it clockwise until the refrigerator cuts off. (Note that the defrost control is normally located either in the refrigerator near the cold control or at bottom behind the kick plate). If your refrigerator is newer it will have an electronic defrost control and you won’t be able to turn to defrost so just continue without doing so. Now that it’s in defrost, wait a few minutes. If the defrost heater gets hot, replace defrost control. If it doesn’t get hot, then the problem is either the heater or the thermostat.
At this point, you need to melt the ice. The best way to melt the ice is to use either a hair dryer or by using hot water (this will be faster but will make a mess).
Once the ice is gone, you can check the heater by unplugging wires and using an ohmmeter to check for continuity. If you have continuity, the heater is good and you should replace thermostat. If you don’t replace the heater, at this point you won't be able to check the thermostat but if the heater is good replace it. Defrost parts can be found at AppliancePartsPros.com
If you have a GE refrigerator made after the year 2000, do not replace the defrost thermostat. Trust me the thermostat is not your problem. 99.9% of the time it will be the heater. Sometimes it is the main board or the thermistor.
Also note that
It's possible that the defrost terminator is bad.
If it doesn't have an electronic adaptive defrost control, then the mechanical defrost control is bad.
In the future, avoid ALL appliances that use electronics. They fail very very regularly and are expensive to replace.
Just think if you had a fridge with a TV in it, and the tv went out. Who would you call? A TV repairman or an appliance repairman?
Buy a Whirlpool refrigerator with the least amount of electronics you can get.
Also, there is a door switch that goes to the freezer section. It controls the light and the adaptive defrost. If the switch is bad, that too can cause the problem.
Lastly, do not buy anything made by electrolux corporation (frigidaire is one of them for example).
They have cheap evaporators that leak and can't be fixed, thus causing you to buy a new fridge every year or so.
Hope this helps your problem......
Jul 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
MSD2756GEB maytag. freezer is working properly.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jun 21, 2010 | Refrigerators
How do I check the heater under the evaporator in my Maytag wide bt side and how do I replace the heater unit?
I am sending the manual and on page 45 at top of page ans section 2-17 tells you the way to change or test the defrost controls. All refrigerators that have auto defrost begin with cotrol/timer/adaptive defrost or Adaptive Defrost made into motherboard, Then you have the defrost heater and defrost thermostat. When looking over your manual you may see things that are not on you model. That is normal or we would have a manual for every difference.
Mar 21, 2010 | Maytag MZD2752G Side by Side Refrigerator
MAYTAG MZD2766GE makes a loud buzzing noise coming from the top of the refrigerator side I think it is when the defrost cycle begins
OK I'm going to ask you some questions about your ice maker. No Problems? You said you noticed this sound around defrost time and have you ever had problems with defrost on this refrigerator before? The way it sounds from here is something related. So I will list them in order of most likely. That would be the adaptive defrost control part number Click Here=> 61005988 then the other two less likely are the defrost heater part number Click Here=> 61006199 When the ADC begins to go bad strange things may happen, The compressor and fans are surposed to shut off and then the defrost heater comes on. Afte defrost begins to reach 50 degrees inside back wall of freezer the defrost thermostat opens to keep the defrost heater from remaining on and defrosting the complete freezer. This for me is a guess and go situation because I am not there to see and hear what you do. So to insure we both are well informed I will leave you with a Service Manual Click Here=> MZD2766GE Your manual covers several models and on page 42 shows a defrost timer and that would be less likely to create strange sounds. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
a0d03ed.jpg5e9645a.jpg Defrost Heater Assembly used on some Maytag brands appliances. Include defrost thermostat.
Mar 15, 2010 | Maytag MZD2766GES Side by Side...
My Maytag msd2756geb freezer is too cold.
You are probably right that it is always running. This is because the thermostat/sensor has gone bad. The fridge adjusts by a door that allows air to come from the freezer to the fridge side. Therefore this will still work...
You will need to replace or have the thermostat replaced....
Heatman101
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Feb 04, 2010 | Maytag Freezers
Maytag plus refrigetor not cooling model msd2756geb
after removing all of the freezer racks and shelf pull the 4 1/4 inch screws out at the bottom back panel of the freezer. pull the 2 panels off and slide them out strait down to the floor of the freezer. if your freezer coils are full of snow and ice then the fan cant pull any cold air up into the refrigerator.your problem is probably th defrost adaptive timer. if the heater ohms out at around 20 to 30 ohms it is ok. next ohm the 2 white wires at the plug this is checking the thermostat it shoud ohm out at aproximately 240 k ohms if those 2 things check out the problem is the adaptive defrost timer it is in the ceiling behind the temperature controls on yhe right side.
Oct 02, 2008 | Refrigerators
Maytag MSD2756G Side by Side Refrigerator Logo
272 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
