Question about Radio Communications
Radio keys up but will not transmit or receive sound
  • 35 Answers
Sounds like the audio chip is toast. Most of the radios that I have seen have see have the chip mounted on she side.
with the cover off check the component side up...look to 1/3 from rear of unit and the chip is usually seen there.
Good luck !
Posted on Oct 04, 2010
Why is humming coming from speaker when mic is keyed?
this is strange as most times if a proper transmit key is depressed , then the radio switches from receive to transmit , the mfg know this would cause some great squeal from receiver /transmitting so close to a receiver so the part that is the receiver is muted to keep this from happening , id say there is some fault in the part that does this muting of receiver
Apr 13, 2016 | Radio Communications
Cant transmit on Cobra PR 4750 WX.
It sounds like you have a shorted RF output transistor.
Apr 22, 2015 | Cobra Radio Communications
No transmit or recieve
sounds like a repair for a tech to me.
Jan 16, 2014 | Galaxy Radios SSB Echo Base Station CB...
Walkie talkies model gmr325-2 ic;513C-UT914 HOW DO I GET THESE TO TRANSMIT, MY HUSBAND HAS CANCER AND WE NEED THEM IN OUR BEDROOMS AND WHEN I AM OUTSIDE, TK U, TK U
In order to get the most out of your new radio, read this reference guide completely before attempting to operate the radio.
Turning the Radio On and Adjusting the Volume
1) Press and hold the key to turn the radio ON.
2) To change the volume level press the volume/monitor up or down key to increase or decrease the volume level.
3) Press and hold the key to turn the radio OFF.
Adjusting the Sound (Key Beeps)
Your radio emits a beep each time one of the keys (except for the PTT button and call key) is pressed.
The sound of the Key Beep will increase or decrease depending on the volume level setting.
To turn OFF this beep:
Press and hold the call key while turning ON the radio.
To turn ON this beep:
Turn the radio OFF and ON again.
Choosing a Channel
Your GMR325-2 radio has 22 channels you can use to talk to others. In order to speak to someone,
each of you must be set to the same channel.
To choose a channel:
Press the channel/scan up or down key to increase or decrease the channel number displayed.
Channel Scan Feature
Your GMR325-2 radio has a channel Scan feature that allows you to easily Scan all 22 channels. When an active channel is detected, the unit will pause on that channel until the channel is clear. Then after a 2 second delay, the unit will continue scanning.
Pressing PTT button while the Scan is paused on a channel will allow you to transmit on that channel.
To turn ON channel scanning:
Press and hold either the channel/scan up or down key. The channel number on the display
will rapidly cycle through the channels.
To turn OFF channel scanning:
Press either the channel/scan up or down key.
Talking on Your Radio
To talk to others using the radio:
1) Press and hold the PTT button and speak in a clear, normal voice about 2-3 inches away from the microphone.
While you are transmitting the tx icon is displayed. To avoid cutting off the first part of your transmission, pause slightly after pressing the PTT button before you start talking.
2) When you are finished speaking, release the PTT button.You can now receive incoming calls. While receiving, the rx icon is displayed.
Transmitting a Call Alert Tone
Your GMR325-2 radio is equipped with a call tone that will be transmitted when the call key is pressed.
To transmit the call alert tone, press the call key.
The tone will automatically be transmitted for a fixed length of time.
Auto Squelch Feature
The GMR325-2 is equipped with an automatic squelch system which shuts off weak transmissions
and unwanted noise due to terrain conditions or if you have reached your range limit.
Monitor Mode Feature
Your GMR325-2 radio allows you to listen for weak signals on the current channel at the press of a key.
To turn ON monitor mode:
Press and hold the volume/monitor up or down key. The rx icon will blink.
To turn OFF monitor mode:
Press the volume/monitor up or down key. The rx icon will stop blinking.
Automatic Power Save Feature
Your GMR325-2 has a unique circuit designed to dramatically extend the life of the batteries. If there is neither transmission nor an incoming call within 2 seconds, your radio switches to the Power Save mode. The radio is still able to receive transmissions in this mode.
KEYLOCK ON/OFF
Press and hold the call key until the "L" appears. After 1 second, the LCD will return to the channel display.
To exit Keylock on mode, press and hold call again.
Note: While in keylock on mode, it will still receive transmissions.
ROGER BEEP
Roger Beep is a BEEP that is sent to notify the end of transmission.
Roger Beep can be heard through the speaker when Key Beep is on.
Roger Beep is transmitted even if key beep is turned off. However Roger Beep will not be heard from the speaker.
To turn OFF Roger Beep: Press and hold the channel/scan up Key while turning on the radio.
Jun 21, 2011 | Motorola Walkie Talkies 2-Way Radio
Cant transmit
Hello Darren, Yes it sounds like the mic is wired bass ackwards,,! A cobra 25 mic wiring is
PIN #1- Shield or ground wire
PIN#2- Audio or Transmit modulation
PIN #3- Transmit or Dead Key
PIN #4- Receive Audio.
When your keying the mic, the RX wires are being connected to make the RX work,,,
*** Let me know how you get along with it. Either buy a new mic wired for your radio or you or someone comfortable with soldering needs to resolder the correct wires back on the mic plug,,,Like I said, let me know and have a great day,, Mechanic is back quiet!
Oct 21, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Meter Shows Signal, no noise
when you have no RX or TX at the same time, that most often means the pre-driver audio transistor is bad.
Thanks,
Dodgem
http://dodgem250.angelfire.com
May 06, 2008 | Maxon MCB-30 40-Channels Base CB Radio
GE 3-5814a cb
first of all i would check the speaker, can you get feedback or even a 2Kilohertz tone? Is there any popping or cracking coming from the speaker?
Sep 10, 2007 | Radio Communications
Staying keyed up after button release
I have never seen this problem before, check if the VOX is activated, this could cause to transmit the radio, but the voice must be transmited. check if the Accesory connector is not dirty, clogged or damaged
Feb 08, 2007 | Motorola Talkabout T5720 (7 Channels)...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
