My television is saying that "an incompatible video signal has been recieved. Check the output device settings." and it won't turn off at all. what can i do so my cable comes back on and it goes back to normal??
  • Rommel Cana
    Rommel Cana Sep 30, 2010
    what are you trying to connect? Model and make so as to help you better
    Are you trying to connect your computer or laptop? ( If it is , set your TV as secondary monitor
    and check your computer documentation how to enable )
  • 130 Answers
Hi
well you tv is scanning to find a signal and do not find it chances are you have bad connection
Posted on Sep 30, 2010
Incompatible video signal has received check output device settings
My guess would be that your PS3 has somehow switched the output settings. You can reset the settings by pressing and holding down the power button till it starts blinking. Try connecting it with your RCA cables to a TV and if that works try going into your settings and setting the PS3 back to HDMI.
Jan 23, 2014 | Sharp Aquos Televison & Video
My Sharp LC-32SB24U says An incompatiable video signal has been recieved. Check the output device settings?
It sounds like an HDMI lead has standard video on it or the output from a digital unit is not the correct specification for your TV.
Check the instruction booklet for recomended signal sources and then check your DVD, Video, Computer for the right type of signals to be outputed to your TV.
Hope this helps.
Oct 29, 2010 | Sharp LC-32SB24U 32 in. LCD TV
I have a message that says no signal o signal
your tv is working but your antenna or recieving device is not sending a strong signal to your set, try using a hd antenna or a dvd device maybe a cable reciever or similar, to see if your able to see a picture but usually its a signal problem not something wrong with your set.. hope this helps
Jun 03, 2010 | JVC LT-42X788 42 in. LCD HDTV
Hooking up my Sony HD Tv
Couple of items come to mind.
In the menu of the receiver, is there a way to choose video and RGB?
Set the receiver to SAT
Connect the HD Cable Box to SAT
Check the TV is on Monitor RGB.
Check the input being used by the monitor RGB cables is selected on the TV.
Have a picture? NO, receiver has issues.
Yes? Do this with each input to confirm they work.
You can reset the whole receiver to factory by holding the tone button down and holding the standby button for three seconds. (This clears your speaker setups, too.)
Apr 02, 2010 | Televison & Video
Sharp Aquos 40lcd will not play bluray
You need to change the resolution on the Blu-ray to 720P to match the Tv native resolution.
Jun 26, 2009 | Televison & Video
Incompatible video signal has been recieved
I just had the same problem and it turned out to be the HDMI cable.
Apr 08, 2009 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Incompatible signal
Check your resolution settings on you playstation 3 menu's. If you are using an HDMI cable, there is a chance that your ps3 could be trying to output at 1080i or 1080p. The unit you have only goes up to 720p and if you set it any higher than that, you run the risk of having picture issues, or not getting a picture at all. Good luck to you
Mar 28, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Tv shuts off sporadically, and now won't recieve any video signal
Check the solder on the vertical output IC this is a common problem and can cause loss of video while sound remains and often will shut the set down with a vertical deflection error
May 07, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Incompatible video signal check the output device setting playstation 3
remember that most dvd/surround sound systems do not support picture mode through some inputs (just audio), you should check your manual as it is usually in the small print.
May 01, 2008 | Sony Playstation 3 (PS3) Console
No digital to reciever??
This tv will only output the sound from a digital tv channel through the optical output when using the tv's digital tuner. So if you are connecting a DVD etc it will not output through the optical output on the tv. ONLY digital chanels through the tv's tuner will give you sound. Refer to the tv's owners manual for more info.
Dec 27, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
454 people viewed this question
Top Televison & Video Experts
Electro Med Services...
