Question about HP Photosmart C6180 All-In-One InkJet Printer
Can't scan from printer or computer
I have the full software set for the C6180 installed on my laptop, which is connected wirelessly to the printer. I can print perfectly well to the printer from the laptop. I can copy etc on the printer.
When I run the HP Solution Center it exits with the error "No HP devices have been detected. HP Solution Center will close now."
Similarly if I try and use other software from the computer, it's not aware of the C6180 as a scanner.
If I try from the C6180 (choosing the scan to computer option) it says No Scanner Options.
Somehow for scanning purposes the two machines are unaware of each other - what do I need to do?
  • 3 more comments
  • hedgert May 25, 2008
    Connected via USB no problem - drivers installed, Control Panel option shows the scanner, I can scan etc.
    When I unplug USB scanner disappears - but again I can print to it fine over wireless.
  • javeaflat Sep 20, 2008
    This worked
    Insert the vista HP 6800 series setup disk in drive O: (it should be the same drive you used to install originally)
    Select the option to install an additional device using existing driver
    Select network when prompted
    Follow the wizard through
    Voila.
    I do not use windows firewall on my machine so I did not need to open any ports.
    The method posted did not work probably because I could not find a way of running the image monitor again after it had been closed.
  • Anonymous Sep 26, 2008
    cant scn to computer or vise versa.
  • luzlinar22 Nov 12, 2008
    I have the same situation with the problem that I can't unistall the sofware, alway I receive this mensageHp Installer Has stopped working
  • FLERNER224 Mar 25, 2009
    I have a L7680 I try to open my HP Soluction Center, I get the error message " No HP device have been detected. I have a Windows XP sp-2 . I have had HP on the phone for 8 hours and nothing. I have had them on for 2 hours today, 3/25.2009 and nothing. I can scan, copy, print, fax with other program. But I can not open HP Solution Center. I have uninstalled all HP programs with the uninstall programs. I have installed their program 9 times and still the HP Solution Center will not open. I am now tring to find a program that can control scan, print, etc. Thanks I really think their program has errors in it and HP doesn't know how to fix.. .flerner224@cox.net Thanks and if any one has beat this, let mek know....
    Guru:
  • 79 Answers
Close the Digital Imaging Monitor.
◄ Start or restart the services :
1. HP Cue Device Discovery.
2. HP Net Device Discovery.
3. HPQCS08.
◄ Run Digital Imaging Monitor.
◄ Wait for a Minute, if the configuration screen appears it is done else refresh the HP Cue Device Discovery
◄ Restart the Printer
◄ 99% chances of resolution and in the other cases a proper uninstall and reinstall is needed
If the issue still remains then :;
Added the files to the firewall exception list
C:\program files\HP\digital imaging\bin\hpiscnapp.exe (version 10 software )
•C:\program files\HP\digital imaging\bin\hpqscnvw.exe (other than version 10 software
•C:\program files\HP\digital imaging\bin\hpqste08.exe
•C:\windows\system32\hpzipm12.exe
•C:\windows\system32\hpzinw12.exe
•C:\program files\HP\digital imaging\bin\hpqtra08.exe
•C:\program files\HP\digital imaging\bin\hpqthb08.exe
i. 68: dhcp client
ii. 80: web server
iii. 137:UDP Port 137 netbios-ns (UDP)
iv. 139: netbios-Session (TCP),
v. 161: snmp. (UDP)
vi. 427: srvloc. (UDP)
vii. 5353: mDNS
viii. 9100: pcl/pjl print.
ix. 9101: debugging tcp recv/send
x. 9102: debugging tcp send
xi. 9103: debugging udp recv/send
xii. 9110: echo
xiii. 9220: generic gateway (scanning, pml).
xiv. 9290: scan.
xv. 9280: generic gateway
xvi. 2500: scan.
Posted on May 25, 2008
  • Hashir Tasleem
    Hashir Tasleem May 25, 2008
    from control pannel firewall
    add the programs and ports from there
    Njoy
Solution #4
Buy something other than HP!
It is joke how HP handles this problem.
Posted on Apr 29, 2010
How to add the files in the firewall exception list
  • 550 Answers
Try running with a cable connection
Try the firewall logs
That will confirm whether it is an install error, a buggy wireless connection, windows firewall may not be allowing inbound access from the printer, too many possibilities to discuss without some clarification
What do I need to make my printer wireless?
You need 1) a wireless router with a USB port that supports the HP OfficeJet printer. 2) The software for your router to run a printer on the USB port. Obviously, you will need a USB A/B male end cable.Note: the scan features of the all-in-one may not work unless the printer is directly connected to the computer. Bi-directional communication is required for scanning and the router software may not support this completely.
Check the list of supported printers closely for older routers. I have a Cisco Linksys E4200 v.2. This router supports all the HP printers that I use.
If this is a new installation of the printer, first install the printer on the computer. If you have Windows 7, just connect the printer to the USB port on the laptop. This will install the OS drivers for the printer. (For Windows XP, go to the HP site and get the full software.)
Next install the wireless router between your modem and computer and set that up. (If you have DHCP (dynamic address allocation), it should be automatic. Otherwise follow the directions.) Next install the router software (for my router, it was Cisco Connect).
My next step was to launch the Cisco Connect program and connect the printer directly to the USB port on the router. In Cisco Connect, choose add a printer and find the printer connected to the router. Print a test page. (At times, I've had to reset the port that the printer is on in the Windows Control Panel Printer Properties. (For the Cisco Connect, the printer is on the DOT4 port.)
Other routers will be set up somewhat differently.
Another option is to have the printer connected to a desktop and then make it a shared printer with the wireless router communicating between the laptop and the desktop. This makes the desktop the print server, so it needs to be on when you want to print. If you have several computers with Windows, this can fairly easy to set up. Make sure that the computers are in the same Workgroup (XP) or Homegroup (Win7). Enable sharing and you are done.
I hope this helps.
(who has a OJ 7000 (with ethernet port) and a LJ1320 (USB) connected to the router. Three computers talk to these printers with the laptop on the wireless network. On an older router that didn't support the printers, the laptop was the server for a previous OfficeJet and one of the desktops was the server for the LaserJet.)
Aug 27, 2012 | HP OfficeJet 6110 All-In-One InkJet...
Wireless radio button is suddenly not
If you have a password on your wireless internet make sure you are entering that into the printer. Do a scan on your computer, it could be that your neighbor and you have the same channel number. That could be your problem. I had that happen to on my wireless laptop.
Nov 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
How do i get my printer hp photosmart c6180 set up with my computer so that i can scan pictures from it to my computer
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01705280&lc=en&dlc=en&cc=us&lang=en&product=1153494
These instructions will help you install the HP software in Windows XP - make sure you choose the FULL driver install (explained on the link). The basic driver does not provide any HP scanning software.
If you want to scan pictures without installing any HP software, Windows has some built in scanning features.
For XP...
For Vista...
Sep 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
My HP C6180 printer will not print wireless via my laptop
Well it s a issues with the ip address on the printer and the computer.Both of them are not the same.You need to delete the printer icon and inser the cd that came with the printer and then try add a device .The printer drivers would be reinstalled and it should be ready to print and scan.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Mar 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
C6180 scan unable!! conection error reported
Get the right Driver's and will work fine than recalibrate the printer. .http://welcome.hp.com/country/us/en/support.html
Jan 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
C6180 stopped scanning after installing leopard
Unplug the printer from the computer, uninstall the printer software, and download the latest software and drivers from the HP website.
Leave the printer unplugged from the computer while you reinstall the software. When the installation program asks you to plug in the printer, do so.
One the software has completed installation, reattempt the scanning function.
Jul 24, 2008 | HP Photosmart C6180 All-In-One InkJet...
C6180 All-In-One InkJet... Problem
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=sg&dlc=en&product=1153494&lang=en&
download scanning software and drivers and install, print driver is not the same as scanning software/drivers
Nov 10, 2007 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
5,375 people viewed this question
Ben Johnson
