Question about Husqvarna Sewing Machines
Hand wheel on machine E20, is extremely hard to rotate, the machine has been sewing but has gradually come to a stop. I have checked that there is no cotton build up at the bobbin site. I feel that maybe it needs oiling but do not know the oiling point for the hand wheel. Can you help me please.
bargainbox
  • 1388 Answers
SOURCE: kenmore sewing machine 15008100 not working
Was all well and working before you did work on the bobbin area ?
Ensure the machine is unplugged & bobbin winder is set OFF as there is a clutch preventing the needle arm to operate when bobbin winding......remove the needle.
If you take the bobbin and hook out, can you manually rotate the handwheel forwards ?
If yes, this suggests they are not inserted quite right, or the timing is out of adjustment.
Can you rotate the handwheel backwards ? On some machines the clutch allows for reverse travel freely, but only around the 15 degrees you mention forward when the top cover is off.....there may be a broken or dislodged spring unit/armature inside top near the handwheel and bobbin winder assembly that is acting as though the top cover is open (a safety feature)....generally towards the rear of machine and acting like a log thrown into a gear.
This may help straight away, or only just start to unravell the cause....
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Mar 16, 2008
  • 106 Answers
SOURCE: janome 8080 computerized sewing machine
Is the bobbin the correct size? if you have spare bobbins do they all have the same problem?
Posted on Apr 05, 2008
SOURCE: toyota sewing machinge 5500
If I understand the problem, the bobin winder has probably lost a rubber 'o' ring.
Unscrew the two top screws and remove the top cover. At the base of the bobin spindle is a metal disk that should have a rubber 'o' ring on it. This will perish over time and break off.
When the bobin winder is pushed sideways into the active position, this should contact the main turning handle thingy (that's a technical term) and be spun around. Check if the bobin 'o' ring is making contact or if it is even there at all. Any sewing machine repair shop (or good automotive store if you're desperate) will have a replacement.
Posted on Dec 06, 2008
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
SOURCE: Oiling my Janome Gem Gold
Janome Gem are self lubricating. Silicon is embedded in the gears and releases as it runs. If the machine is put away and not run every so often it will lock up. The hand wheel may have thread caught up around it. The Gems aren't assembled to be dissembled except to change the light bulb.
Posted on Mar 04, 2009
Machine runs, then slows down, then stops, will start again but acts as if it is jammed with thread but does not have thread caught any where.
threads and fluff get jammed around the rotating shafts and act as a brake to moving parts
Take the machine in for a service
Nov 09, 2015 | Simplicity Denim Star SW210
Hand wheel rotates but stop motion screw doesn't rotate and it is not moving the needle up or down
Robin. Take off the hand wheel. Look for the funny looking washer with ears. The center fingers should be angled outward when you fit it into place (counter intuitive, I know) Fit everything back together and try it again.
Oct 25, 2012 | Singer 20U73
Slow Machine
it sounds like the machine needs to be checked at a sewing
machine repair shop, to see there is anything wrong with the
gears or other parts & also to be regreased & oiled
Aug 23, 2012 | Singer 2263 Mechanical Sewing Machine
How do I change the stitch length in my Juki LU 563
hi there
the graduation of the stitch length is marked on the feed graduation plate attached t the main shaft,to adjust the stitch length rotate the hand wheel slowly as you keep pressing the push - button stop the bed until the tip of the push- button enter groove of the accentric mechanism, when it is entered rotate the hand wheel eigher towards you or away from you as you keep pressing the push - button until the desired stitch length indicating mark on the graduation plate appears on the hole of arm. when appear release the push - button and check stitch length.
BEST REGARDS
AHRAF ABOZID
CAIRO - EGYPT
Apr 02, 2011 | Ludwig LG8B2 Industrial Sewing Machine
Im trying to sell a Kenmore 117 - 959 but I can't get it to move. There is power to the work light, but Im stuck. Help!
If your gaskets are bad, the machine will not rotate. Can you move it by hand? If not then have you checked the gasket in the back of machine that comes in contact with the hand wheel? If it is making contact, this is what runs the machine and both the little black gasket and the hand wheel will spin when you rotate by hand. If the hand wheel is free spinning then it may need oiled. If you have a manual, try oiling the complete machine according to manual.
Jul 10, 2009 | Kenmore 11101 Mechanical Sewing Machine
Machine stopped sewing
The thread is caught in the hook...Remove the upper thread and bobbin case, turn the hand wheel backwards and forwards by hand and remove the thread remands. Good Luck
May 28, 2009 | Sewing Machines
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Hand wheel hard to turn, won't sew
Machine wheel locked,what should I do?
Nov 04, 2007 | Sewing Machines
Sewing Machines Logo
27 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
