Question about Baxter BXA2G Stainless Steel Gas Single Oven
Burners will not stay on until set temperature is reached they shut off and on eratically....please help...
  • 43 Answers
Have you tried cleaning your flame sensor? The little metal rod at the bottom of the burner can be removed and the metal rod that sits in the flame should be cleaned with a wire brush or emory cloth (fine sandpaper).
Posted on Jan 02, 2012
Riello 40 gasG900 burner that will ignite but when oven reaches temperature it turns off completely. After temp drops by 4 degrees it turns back on and reheats back to temp then turns off.Why is this?
that would be normal. if it didnt shut off, it would go above the set temperature. the heat is either off or on. it cant me in the middle. it turns 'off' so that the temperature doesnt go too far above 250. when it senses the temperature falling too low below 250, it heats it up again.
Sep 03, 2017 | Ovens
Creda Double Gas Oven. Model Europa Gas.48132.Serial No: 83 1 00087
I would contact the manufacturer and ask for the repair manual, it does not appear to be available online. Here is a link for the contact form. Hope this helps.
Jul 18, 2008 | Ovens
Replaced the bottom element of the oven but it will not shut off when the temperature is reached
So we do not read about your problem on the evening news, please unhook the bottom element until someone helps you with the solution.
Dec 07, 2015 | Ovens
Hi there The oven burner is always on high ,even when I turn it on 200..
The oven burner will usually always be on high, until the thermostat reaches the desired temperature and then will shut off the burner until the temperature drops and then restart on high again. If your oven is getting hotter than what is selected then it could be the thermostat that is not working right.
Jul 13, 2011 | Ovens
Water coming out oven no steam and it will not get to tempeture
If your oven isn't reaching temperature you will not get steam. Turn the oven on and verify that the oven is calling for heat by looking in the temperature window next to the arrow that says "heat" or "on," if the set temperature is 5 degrees higher than the actual temperature there should be a small red dot next to the arrow. Then observe the burner, does the exhaust fan come on, can you see the ignitor glowing, does the burner light, does it stay lit or go out after 4 seconds? You could have a dirty flame sensor, the small rod with a wire attached to it at the top of the burner, remove the flame sensor and clean it with a cloth, wire brush, or emory cloth.
Jan 02, 2011 | Baxter OV300E Stainless Steel Electric...
When i turn on bake i first smell gas then the burner goes on and off eratically and takes a long time to reach the temp model#fgb557cesd
Part #37 on diagram #3 will show the temperature probe that needs replacing.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=111385&diagram_id=232775#d232775
Jan 01, 2010 | Frigidaire 24" Built-In Single Gas Wall...
Kenmore gas oven does not reach operating temperature
If your oven is 20 years old the temperature sensor system might no longer be accurate, if you have access to a temperature measuring device that can confirm that the oven is not reaching 350 then run it up and check that its not just your indicator light system. Some oven burners have air control and yours may have accumulated oven soil over the years. If your burner. Is behind a short wall like mine is, use a mirror and torch to check. A clean can bring things back to standard. Flame heat is from a good mix of. Gas and Air...
Dec 05, 2017 | Kenmore Ovens
GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Mar 14, 2009 | Ovens
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Baxter BXA2G Stainless Steel Gas Single Oven Logo
131 people viewed this question
Top Baxter Ovens Experts
Owen Barnes
ray gallant
Are you a Baxter Oven Expert? Answer questions, earn points and help others
