Question about Bosch Classixx WFC 2465 Front Load Washer
Bosch washing machine
Can i change the carbon brushes in my bosch washing machine model no is wf0266gb
    Problem Solver:
  • 4 Answers
I just did this. Fitting the new brushes was fiddly but not impossible. Its easier if you remove the motor first as this makes access a lot easier.
Posted on Sep 05, 2008
I have replaced the carbon brushes in my logixx 8 machine after error code F43 appeared .the machine works ok but the washing stays soaking wet on the wash programmes
Make sure the pump wires have not got accidently dislodged when changing the brushes. Also check the program cycles, you may have accidently selected a "no spin" cycle.
Mar 10, 2015 | Bosch Washing Machines
How to locate the washing machine brushes?
Some motors do not have carbon Brushes as its a induction motor as a opposed to a reaction motor which does have, not sure about your model but you could check this first, if it does have a brush kit fitted they should be easy to identify and remove if on the other hand no brushes then you would need to fit a new motor. On the bosch the brushes can be hidden look at the back of the motor ,you will see two wires one for each brush connected. Good luck.
Jun 03, 2014 | Bosch Nexxt Premium WFMC6400UC Front Load...
Can anyone tell me where I can get carbon brushes for a Bosch WFMC1001UC/09 washing machine. Bosch does not sell or list the part. They say you have to replace the motor as a unit. The number on the old...
I realize that this post really old but I wanted this to be available for the next guy. I bought Bosch part number 154740 which are brushes that worked for me from repairclinic.com. They will tell you it wont work but it did for my Bosch (wfmc1001uc/09) washing machine.
Dec 28, 2011 | Washing Machines
Hi i just want to check to see if belt is ok, but dont know where to look, i have a drum wont turn
Its probably your motor carbon brushes. If the machine electricals work OK and it pumps water in and out then the carbon brushes have just worn out on the motor. I had the same problem with my Bosch front loader. Easy fix and you can get help visually on youtube. If you are looking for the belt to see if it has come off, undo the screws that hold the plate on the back of the washing machine to access and sight the belt. Also this will give you access to the motor if you need to change the motor carbon brushes. Hope this helps Sue
Aug 09, 2011 | Bosch Washing Machines
My washing machine is not spining
It is likely that the Carbon Brushes of your Bosch washing machine need replacement. Get them from your nearest Bosch Spares stockist (P/N: 154740) Replace these on the motor armature, and it will be alright again. To be certain that it is indeed the Carbon brushes, open your washing machine and look on the motor (opposite side of the pulley) There has to be 2 grayish chalk type brushes running on a copper armature, these brushes have a lifetime of about 4 - 6 years before being diminished.
Hope this helps
* If you found this solution helpful, please vote positively.
Feb 18, 2011 | Bosch Washing Machines
Where are the carbon brushes on a bosch classixx 1200 express
Generally speaking, you might only expect to find carbon brushes in the motors used in some power tools. Household appliances use a different type of electric motor that does not use carbon brushes.
Aug 03, 2010 | Bosch Washing Machines
I have a bosch clasixx 1400 washing machine and it is not spinning but is going through all the programmes and i have also changeed the carbon brushers, what is wrong?
Make sure the filter is clean, this is located at the bottom front right of washer, unscrew anti-clockwise to remove and clean.
Mar 09, 2010 | Washing Machines
Installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Bosch WFK 2401
Bosch washer carbon brush replacement
Remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws securing motor.
Lever back motor with screwdriver, remove motor..Carbons at opp end to motor pulley, remove and replace same.
Aug 27, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Remove carbon brushes from bosch washing machine
u can sometimes tip the washer backwards and with a torch u should be able to see the carbon brushes and the 2 star screws which hold them in undue these screws and the carbon brushes will pop out very easily for u to change them m8
Feb 24, 2008 | Bosch Classixx WFO 2466 Front Load Washer
Bosch Classixx WFC 2465 Front Load Washer Logo
172 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
