Question about Shimano Cycling
Shimano front deraileur takes doesnt shift up to the next gear it takes two pushes on the lever
    Genius:
  • 1,788 Answers
Your cable needs to be tightened and adjusted
Posted on Sep 30, 2010
How to Adjust Shimano Altus SL-M310 3-Speed Rapidfire Lever
Put chain on smallest chainring, loosen deraileur cable, set lever to lowest setting (usually cable has the most length at that point). pull cable tight through derailleur set screw( may be a 5mm hex or a 8mm nut). Test to see if shifting is accomplished. There is a U-tube video on this subject and a how-to web site is Sheltonbrown.com
Dec 05, 2014 | Shimano Cycling
My shimano ultegra left shifter is super stiff/hard to push in; what is going on?
Try flushing out the shifter(s) with WD-40, use plenty. The next step will be replacing the shift cables and cable housings.
  • Take the bicycle in an area free of cars and obstacles, such as an open parking lot. Concentration is required when learning to use Ultegra shifters or any other type of bicycle shifter.
  • 2 Mount the bicycle and rest both hands on the proper Ultegra hand control. The left-hand control operates the front derailleur. The right-hand control operates the rear derailleur.
  • 3 Start pedaling, smoothly and evenly. While pedaling is crucial to propelling the bicycle forward, it is also necessary when shifting the derailleur. Pedaling forces the chain to rotate. The chain must rotate before it can transfer to another gear.
  • 4 Push the outside right Shimano Ultegra lever in toward the bicycle. The rear derailleur will shift the chain to a smaller rear gear.
  • 5 Push the inside right Shimano Ultegra lever in toward the bicycle. The rear derailleur will shift the chain to a larger rear gear.
Rear Ultegra Derailleur Control
  • 1 Push the outside left Shimano Ultegra lever in toward the bicycle. The front derailleur will shift the chain to larger front gear.
  • 2 Push the inside left Shimano Ultegra lever in toward the bicycle. The front derailleur will shift the chain to a smaller front gear.
  • 3 Use the front and rear Ultregra hand controls interchangeably. For small changes in gearing, using the rear control. For larger changes, choose the front control. A smaller gear causes the bicycle to travel a shorter distance per pedal stroke but also requires less energy to use. A larger gear requires greater effort but in turn causes the bicycle to travel farther per pedal stroke.
Oct 25, 2011 | Cycling
I have Campy mirage 10 sp and the rear deraileur shifter ( the right shifter) will skip gears while shifting down 23 to 11. Often I can hear the mechanism making multiple "clicks" on a single...
I would lube everything and check the derailleur adjustments and cable tension. Some Campy chains are 'notchy/clunky' all the time. It's just the way they are. If the bike is low mileage most likely nothing major is wrong. Check the derailleur hanger too just in case you dropped the bike and bent it or something. The shifter 'G' springs will wear out before the derailleur. When the springs are worn, the shifts will be imprecise and will jump from gear to gear without shifting. One thing with Campy stuff...it DOES take awhile to break in. Unless the shifting is horribly off, I wouldn't worry about it - just ride it more - and see what happens. Mirage is a good product, I think inline with Shimano 105 stuff.
Sep 12, 2011 | Campagnolo Mirage
Shimano 200GS STI, upshift lever moves freely but when released, it returns the derailluer back to the lowest gear. How do you take the shifter apart?
"Upshift lever" could be either one since they both shift up or down.
I'd make sure it's a lever problem before embarking on that project. Is the cable actually being controlled by the lever?
A simple web search for "Shimano 200GS STI assembly" yields all kinds of resources.
Another good start would be http://www.shimano.com/
Other web searches like "how to.." work, too.
Aug 02, 2011 | Cycling
I bought a mountain bike with Shimano Altus gears over the net with most of the assembly in place. Have indexed the rear gears which work fine. Did the same for the front deraileur works changing up but...
There are a couple of possible problems. You can try backing off the cable tension a little bit at the shifter and running back and forth through the gears adjusting as you go till it hits 2nd coming down.You can also try backing off the High limit screw on the derailleur. This will allow the shift to start a little farther from the bike hopefully hit 2nd. Hope this helps.
Sep 12, 2010 | Mountain Shimano Altus Front Bike...
Deraileur adjustment/tuning
Yeah you will run into that at some bike shops. When they see older components like that, they often refuse to adjust them for fear of breakage and liability. Try a different bike shop if you can, or if you are confident in your mechanical abilities, try it yourself, instructions here:
http://www.ehow.com/how_6086607_adjust-shimano-rear-derailleur.html
Good luck.
Mar 27, 2010 | Shimano Xtr Mountain Bike Dual Control...
Shimano total integration shift levers will not hold the front deraileur in the high gear position. Slips back to inside, small, front sprocket immediately. I have tightened both the allen screw on top of...
Try this site:http://www.parktool.com/repair/byregion.asp?catid=53 Read the articles on shift levers and derailleurs especially. Good photos.
Oct 19, 2009 | Cycling
Shimano 105. Front derailleur won't shift down
It sounds like you could have two different problems. Your derailleur has become contaminated or your shifter may need to be lubed. Either way, the likely solution is the same. The best solution to get the derailleur operating again is to spray it with GT-85 or PB blaster and manually move in back and furth until it is working again. The same goes for the 105 shifter, spray GT-85 inside the shifter by compressing the brake lever and spraying towards the head of the shift cable. This will solve a non-functioning shifter many times.
The only other problem that fits is the limit screws could be wrong or the deraileur is in the wrong position. This would not be the case unless someone adjusted your derailleur before the ride you started have that problem. Or if the derailleur has moved. Both of which require the derailleur to be fully readjusted.
Hope this helps. Thank you
Jul 15, 2009 | Shimano 105 Triple Braze On Front...
On my bike with shimano ultegra shifters and 105 front deraileur, I can't shift onto the big chainring. The deraileur is not at the stop, but I can't move it any farther. How do I fix that.
Try this first:
Shift into the little ring and release the cable. Pull it tight (with pliers) and re-tighten the cable. It should shift now. If it doesn't, the solution is a little time consuming, so i apologize in advance.
First, flip your bike onto the bars and saddle. Now shift into the small chainring and your lowest cassette cog (the largest in number of teeth). Release the cable from the front derailleur and set the adjustment knob for the front derailleur to its center point. You should find it on your down tube. Now adjust the "L" setting on the derailleur while turning the crank so that its stop sets it in a position where it just skims the chain but does not touch it. Now pull the cable taut and re-clamp the cable. Shift into the middle ring and shift the rear derailleur to its highest and lowest gears, making sure the chain does not rub the front derailleur. If it does rub (it will be in either the lowest or highest cog on the cassette), adjust the front derailleur by way of the adjustment knob to clear the rub. Then shift into the big ring and you should have no problem. Set the "H" stop if necessary.
Jun 23, 2009 | Shimano 105 Triple Braze On Front...
How do i set up my shimano 21 gears . just had new cables and ive lost some gears. theres also small screws on the drailiures, and ive messed with them and maybe thats my problem?can u help me on how to...
okay start with the deraileur in the smallest gear if it wont loosen cable and screw with the letter h by it if you cant see letter just loosen the one that lets it move out only go until its in high gear then making sure its shifted to high gear tighten cable slowly shift to low gear when it reaches low tighten small screw you havent adjusted yet to keep deraileur from going into spokes
Apr 07, 2009 | Cycling
Cycling Logo
109 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
John Egan
John Egan
Eric Hidle
Level 1 Expert
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
