Question about Intermatic Hardware & Accessories
Stopped working. no0 p code - Intermatic Hardware & Accessories
1) Can you identify your timer and then re-post your question?
Here is a link to Intermatic >> on left side of page are types of timers. Press + to expand each selection. There are a lot of timers. It sounds like you have electronic timer, and not a mechanical timer.
2) Guessing at solution without knowing exact timer?!?
Could that code mean 'no power'
Have you checked circuit breaker, click it all the way one direction, and then back the other way
Does manual override work? Does manual override turn the load on-and-off?
Have you checked battery?
EH40, EH10, ST01C, EJ500, EI600 each have a battery, but usually the error code is BATT
Posted on Sep 30, 2010
HAVE A 32 INCH SAMSUNG LCD TV GETTING SOUND BUT BLACK SCREEN WITH NO BACK-LIGHTS
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Aug 06, 2016 | Samsung Ln32d403e2d
My printer Konica Minolta stopped working and showed me an error code F-26-6
The printer stops working & showed me an error code F-26-1
www.fixya.com/.../t16683015-printer_stops_working_amp_showed_me
Feb 20, 2013 - the printer stops working & showed me an error code F-26-1 , How can I repair it ? I think it s relating to a - Konica Minolta 26NA53040 7130 ...
Konica Minolta 26NA53040... Repair Questions - Fixya
www.fixya.com/.../p4700437-konica_minolta_26na53040_7130_7025_...
Konica Minolta 26NA53040 7130 7025 7020 Oem Lower Fixing Roller Assy New ... Theprinter stops working & showed me an error code F-26-1 , How can I ...
Feb 20, 2013 | Konica Minolta 26NA53040 7130 7025 7020...
The Phoenix Bios setup utility is password protected now. I had to replace hard drive but won't let me reinstall cause says it needs a password. Is there a way around that?
No0 theres not... your going have turn to your manufacture for help to reset the passsword or te person that put the password on! Goodluck
Dec 03, 2010 | Panasonic Toughbook CF-51 Notebook
Hi I have a Maytag fridge freezer GC2227CDFB The fridge compartment has stopped working, the lights still come on when door open, the motor seems to be working, when temp. setting is turned down to 0 the...
Your problems are exactally the same as mine. I have taken the freezer back panels off and fornd the elements blocked with ice, the upper and lower channels to the fridge are blocked with ice and obviously therefore no0 cold air is going the fridge, I have de-frosted the freezer and put back together and everything works great for 2 weeks when the same thing accurs. My settings for both fridge and freezer are on the lowest possible, but the wife does fill the freezer with too much food! I guess I need an expert in!!
Jun 16, 2010 | Admiral 26 cu. ft. Side-By-Side...
I lost my drivers,pci,sm bus,vga, i have no sound i have no0 reboot cd==any ideads
search for the motherboard drivers.use google to search for the motherboard drivers.download it if you find it.
Sep 15, 2009 | Computers & Internet
Ahhhh
if you use vist os its normal
Aug 29, 2009 | Dell XPS 420 PC Desktop
Sony desktop computer reboots on power up
yes replace the power supply might solve your problem
Feb 12, 2009 | Boston Acoustics MicroMedia Computer...
Remote stopped working
original remotes of the unit don't require codes. check the battery, otherwise try using universal remote where codes are required for different models
Oct 15, 2008 | Samsung Televison & Video
No turn signals, no heater blower
test to see if there is battery voltage present to the blower motor on the Green wire. Make sure to leave the connector plugged in. If voltage is present, try back probing a jumper wire hooked to ground and probe into the Black/Tan wire, the blower should run at high speed. If battery voltage is not present, check for power coming into the ignition switch on the Pink/Black wire. Check for power coming out of the ignition switch on the Black/Orange wire with the key in the "on" position. The power coming into the ignition switch on the Pink/Black wire comes from a Grey fusible link near the battery. most likely a Corroded fusible link near battery. Good luck Jimmy........
Oct 01, 2008 | 1993 Dodge Caravan
Hardware & Accessories Logo
143 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
