Question about Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer - Blue
My dryer has power and lights, but when I press start is just clicks twice. Dryer model is DC68-02365A-01
kachbibi1
  • 979 Answers
SOURCE: Kenmore Electric Dryer 66812 clicking not starting
I hate to tell you this, but it is probably the timer. The good news is that it is easy to replace and you don't have to have a tech to do it.
Posted on Jan 14, 2009
  • 659 Answers
SOURCE: Kenmore Dryer 90 series model number 66912691.
It sounds as though it could be the door switch. Remove it and check for continuity.
Posted on Apr 18, 2009
Greg20
  • 149 Answers
SOURCE: kenmore he2 electric dryer error code f-01
always unplug for 10 minutes and retry first.
Posted on Jun 12, 2009
  • 277 Answers
SOURCE: dryer won't start
Jon
Some dryers now come with a lot of electronics to run them and with electronics and heat, they don't like each other.
The click you hear is a relay switch on a board inside on or near a power board simular to a tiny computer,
Rplace that board.
Now to know which board is another question,
With the power removed (unplugged) disassemble the top part or the back of the dryer. When inside follow the main wires from the plug and see if it meets a electronic board. It could be or maybe burnt.That is you main power board, take it to an appliance shop to replace it
Take along your model# of your dryer
Happy drying
Posted on Jul 25, 2010
heatman101
  • 43501 Answers
SOURCE: Dryer has power, but when
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 30, 2010
I have a GE dryer model #DCVH660EH3BB, it powers on but when I press the start button it beeps twice at me and won't start the cycle. The lint trap and vent have both been thoroughly cleaned.
From the manual...
Problem
Cannot make a selection and the dryer beeps twice.
Possible Cause
The DRYNESS LEVEL, TEMP or OPTION that you are trying to select is incompatible with the chosen dry cycle.
Link to your manual, troubleshooting starts on page 24.
ShopYourWay GE Residential Dryer ShopYourWay
Jul 22, 2016 | GE Dryers
417.84052500 electric dry 05 model safe mode code. Everything lights up but won't run
Rocky, Could be door switch problem.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Bypass dryer door switch Whirlpool
Dryer Not Starting How to Test the Door Switch
. Whirlpool Kenmore Dryer Repair 01 Won Start or Run Door Switch 3406107...
http://www.selfhelpforums.com/archive/index.php/t-10060.html
Mar 13, 2016 | Kenmore Dryers
Model FEQ1442ES0. I press the start button and all I hear is a click, nothing happens. What's wrong?
I appreciate your inquiry, Cody!
I see that your Frigidaire dryer is not operating after you hit the start button and it clicks. It is possible that your control panel or wiring harness could be causing this issue with your dryer. You may need to perform a reset on your dryer and you can do that by disconnecting power from your dryer for at least ten minutes. If this does not correct your issue I would seek assistance from a professional technician for a proper diagnosis and repair. I hope this information is helpful to you. -Matt
Jun 15, 2015 | Frigidaire Dryers
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My dryer Bosch model number WTA3003GB/01 will not keep turning after being switched on. It works if the switch is pressed in but stops as soon as the switch is released.
heatman101
Jan 02, 2011 | Dryers
Gas dryer panels light up when you press any panel button but when you press "start" it won't turn on. It worked twice where it turned on and rotated once or twice before shutting off but now it...
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 30, 2010 | Kenmore Dryers
Model # 110.63012101 Won't start. Light comes on
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Oct 22, 2010 | Kenmore 64972 Electric Dryer
Kenmore he2 electric dryer error code f-01
Jun 12, 2009 | Kenmore 82822 Electric Dryer
Maytag Epic Front Load Dryer
When you close the door it needs to click twice, the light will go out once its all the way closed........then your good to go
Jan 26, 2008 | Maytag MED9600S Electric Dryer
Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer - Blue Logo
223 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
