Question about ASUS A3Ac Notebook
My notebook suddenly shut down itself, then after i restart, it show select which drive to boot (but no option to let me select). Then i try to reformat it, but it show no harddisk install? i have try to remove the harddisk and reinstall again, but problem still same?
  • aoshi_kh Sep 30, 2010
    question
    1. if my harddisk break down, is there any way i can get the data inside??
    2. how can i check are my harddisk is IDE or SATA?
    3. if my notebook now is using IDE harddisk, is there possible i can change it to sata?
    Brigadier General:
  • 10,406 Answers
This means that no "bootable" CD-ROM was loaded into the CD-drive, *AND* that the "bootable" files could *NOT* be read from the disk-drive.
> it show no hard-disk install
Well, it shows that either:
* no electrical power is reaching the disk-drive
* the electronics "underneath" the spinning-part of the disk-drive have failed
* the "spinning" part of the disk-drive is not spinning (dead motor?)
* the disk is spinning, but nothing can be read from the disk-drive.
Try connecting the disk-drive to another computer.
If it is detected, that's good.
If not, then your disk-drive has a BIG problem,
and replacing it (with or without exercising any "warranty'") is your only way to move forward.
Posted on Sep 30, 2010
  • 1 more comment
    the harddisk has sound "tab tab tab".. not sure why it like that?
    and if my notebook now is using IDE harddisk, is there possible to change it to sata?
    My question is
    1.) if my harddisk break down, is there any way i can get the data inside??
    2.) how can i check are my harddisk is IDE or SATA?
    3.) if my notebook now is using IDE harddisk, is there possible to change it to sata?
  • ikkenom Sep 30, 2010
    It depends on "how broken" it is. Either the electronics "under" the spinning-part is broken,
    or the spinning-part no longer is spinning. Search online for "data recovery service".
    These companies, for a large fee, can repair most disk-drives, just long-enough to try to copy your files.
    An IDE drive will have gold "pins" at the one end, arranged into two rows.
    A SATA drive will have (usually-BLACK) sockets for "power" and "data".
    Maybe a 1-in-a-TEN-THOUSAND chance.
    One can still purchase 2.5-inch IDE drives for use in older laptops, up to 500 Gigabytes.
Got Dell Inspiron 2650 2002 from a friend, free. Want to restore to factory settings. How? Installed Windows XP and Norton Anti Virus
Hi and welcome to fixya!
There are two ways to restore this machine to factory settings;
First is thru the Recovdery partition in the hard disk itself:
  • 1 Close any windows currently open and click the Inspiron's "Start" button. Select "Shut Down" and choose the "Restart" option.
  • 2 Tap "F8" when the Dell image appears on the screen. Continue tapping the key until the advanced boot menu loads.
  • 3 Scroll down to "Repair Your Computer" and press "Enter" to access the DataSafe local backup screen. Click "Next." Select "Dell Factory Image Recovery and DataSafe options."
  • 4 Click the "Restore without preserving new or changed files" radio button and click "Next." Click "Next" three more times and click "Restart" to restore the disk drive to its original condition. Follow the on-screen prompts to set your operating system settings.
If the hdd was already repartitioned or corrupted, the second option should work:
  • 1 Insert the Dell recovery disk in your Inspiron's optical drive and close the "AutoPlay" window when it appears. Shut down any other open programs. Click "Start" and select "Restart."
  • 2 Tap "F2" as soon as the Dell image appears on the laptop's screen. Scroll to the "CD-ROM" option and press "Enter." Tap any key when you see the "Press any key to boot" option.
  • 3 Press "Enter" when the setup screen appears. Press "F8" and highlight the Dell's hard drive partition. Press "Enter."
  • 4 Follow the instructions on the screen to choose the Inspiron's operating system options. Click "Finish" and remove the recovery disk from the optical drive. Click "Start" and select "Restart."
Hope this helps!
Takasashi
Jul 19, 2011 | Dell Inspiron 2650 Notebook
My hard drive fails and it wont boot. What is the best solution to it?
If its a HP notebook then perform the har drive self test.
Here are the steps below.
Steps for HDD self test.
  1. If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
  2. Shut down the computer if it is running.
  3. Press the power button to turn on the computer.
  4. Press f10 when the HP/Compaq logo displays.
  5. After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
  6. Select HDD Self-Test options .
  7. Press enter to display a list of HDD/Self-Test options.
  8. Select Notebook Hard Drive and then press f10 to display an Estimated test time .
  9. Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If the hard drive fails then surely there is no option other than replacing it....
Please surely buy HP Hard drive.
Jun 14, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
Acer Aspire One loops on start up screen. All it does is show the acer logo, then shows the ''windows was shut down improperly'' screen with all those options and then goes to the windows xp start up...
Try tapping F8 when the acer window shows, when it shows the muliboot option, scroll down to "Last Known Good Configuration" and hit enter. If it does not boot normally, you will have to get an external dvd drive and boot off the drive with a windows installation disc to perform a repair.
Jan 07, 2010 | Acer Aspire One PC Notebook
Toshiba L350 series laptop shows "windows failed to start" screen when booting up & goes to a completely blank screen afterwards. Tried using recovery cd & can't get C prompt to come up. Need...
Shut down the laptop, make sure that no light is lit up. Before booting it back up, press and hold the F12 button. It will lead you to boot options. Open up your DVD drive and insert Disc 1 of recovery then make sure you select the ODD or the dvd drive to boot up. This will start the recovery process.
Other models has Icons for boot options. Make sure you select the single disc option to boot the ODD.
Hope this helps.
Dec 20, 2009 | Toshiba Satellite L350-ST3701 Notebook
How to install xp in dell 1545
Insert the xp install disc into drive "d" or whatever letter is assigned to the drive, restart your dell, if it doesn't boot from the cd, restart and press and hold down F2 while it boots(or F2 or F8 deoending on setup) until the boot options appear, select drive "d" as boot device and continue the restart.
Then when the options appear, select the choice you need, full install will allow you to format and partition your drive.
Sep 05, 2009 | Acer Aspire 5610-4648 Notebook
Boot from CD does not work.
You should definately be given the choice to boot from cd, when you press F2 to get into the bios and go to boot options, what boot options do you have?
If you go into the bios you should have the choice to boot from ide (hard drive), cdrom, floppy disk, network (on some) and try other boot media.
Are you going into the boot option in the bios by pressing F2.
Jan 14, 2009 | Compaq Evo N610C Notebook
HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
Jan 14, 2009 | HP Pavilion dv9000z Notebook
Shuts off at boot up screen?
Start the computer in safe mode (tap F8 immediately after turning it on until you see the option of how to boot)
If it successfully boots into windows, you have an issue with either driver conflicts and/or viruses. If it still restarts itself, you most likely have a hardware issue (bad hard drive, motherboard, etc)
Jun 24, 2008 | Acer Aspire 5000 Notebook
ACER PC 5100 Problem
It sounds like you have some internal hardware problems. It is best if you have an exprat inspect you laptop interior power connections and inspect your BIOs options for boot sequence.
Feb 18, 2008 | Acer Aspire 5100 Notebook
Laptop ?
First try to boot in the safe mode, by repeatedly pressing the F8 key. If it boots into the safe mode, press the start button, shut down then select restart. If it will not boot normally then, repeat booting in the safe mode and once booted go to programs/accessorys/system tools/restore the select a restore point date that the computer was functioning correctly and restore for that date. If it will not boot the safe mode restart the computer with the system cd disk and restore from it. BPCS
Dec 05, 2007 | Dell Inspiron 6400 Notebook
ASUS A3Ac Notebook Logo
152 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
