Question about Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho
I need one of the small red pins that insert in the timer face which turn the system on. Please give me a heads up on where I can order one of the pins.
  • 56 Answers
You should be able to pick up one of these at your local hardware store or Home Depot if not you can order from Malibu on line
Posted on Sep 30, 2010
My Power head on my Dyson Animal DC39 will not stay spinning. Suction Issue?
There should be a red insert on the right-hand side on the cylindrical bulge behind the brush cylinder. Check that this is moving when you push the button. The red insert should stay pushed in for the brush to rotate. The insert moves in an out as well as rotates in order to lock in the 'in' position. Mine is a little sticky on the rotation and I need to shake the brush head a little in order to get it to rotate and lock.
Jan 05, 2013 | Dyson DC39 Animal Canister Vacuum
We can't figure out how to set our timer. Where and what are the segmented pins. Nothing is labeled. There is no diagram with the timer. Thank-you. Joy and Fred.
Hi Joy and Fred.
You posted under Woods outdoor timer, but don't give specific brand or model
Open following links for detailed information and illustrations:
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
http://waterheatertimer.org/Woods-timers-and-manuals.html#59383
Segments are usually on outer edge of dial.
Some timers the segments lift up, some push down, some pull up and out, etc.
Use a fingernail or small tool and fiddle around with it.
Some timers have pins located on dial face that click inward or outward. Use small tool and move them in and out.
Some timers have trippers that you attach to outer edge of dial.
If you are confused, open links above for illustrations.
After moving some segments-pins. Plug lamp into timer.
Turn lamp on. Plug timer into outlet.
Manually rotate timer dial and watch how lamp turns on-off.
Move timer switch both directions and manually rotate dial to see lamp turn on-off.
These tests will show you how to set pin-segments-trippers and switch for your specific timer.
The timer dial rotates as time passes. The dial is a simple clock that rotates because of a clock motor.
The dial causes segments-pins move small lever that turns lamp on-off.
Just like any clock, the correct time has to be set. To do this: rotate dial until current time lines up with arrowhead located on inner dial.
For more information, add a comment with in-focus photo of your timer.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 29, 2011 | Woods Outdoor 24 Hour Mechanical Heavy...
Wiring diagram for motherboard m7vk6
It is a very an old question. I had this problem myself at an early age.
Here is an image that will help you:59ae22f.jpg
These are small, 2-pin cables that are in Red, Blue and Green colors (with white main connector). Try to not bend te pins receptors, because they are very fragile.
1. Plug the POWER_SW cable on the first two left pins;
2. Plug the HDD_LED cable next to it;
3. Plug the POWER_LED cable either to the insulated 2-pin slot or next to the two others you plugged in;
Be carefull because if you missplace the order your system won't power up, and insert them horizontally.
If you need further assistance please leave a comment.
Aug 25, 2010 | Computers & Internet
Non-labeled diagram of motherboard
Motherboard Problem
Good day,
There are several component we need to consider in order for us to give you a more appropriate solution to your dilemma.
1. There are pin configuration at the back of your hard drive which can be switched from one combination to another. These pins is for boot sequencing. Try switching your hard drive pin configuration from master or slave to auto detect or IDE detect.
2. IDE cable must be inserted correctly. IDE cables have red lining on one side which indicates the proper insertion. Red Lining must be facing the red wire from the power supply cord. Try looking a closer look.
However, we need to ask you a few questions to give you a more direct answer.
Kindly provide the following.
1. Is you hard drive an IDE type it SATA.
2. Motherboard specs.
3. Memory allotted.
Should you have any questions, feel free to approach us.
Jul 24, 2010 | Intel Computers & Internet
Our timer has a red pin and green pin how do we set the timer? We cant find the instructions from last year we used it for our Christmas lights. It is just a small timer.
Put red pin in one spot put green pin in another pluged lights into timer continued to turn until lights came on and went off
Nov 19, 2009 | Electronics - Others
Can't figure out how to set Intermatic timer 111c up to nightlight
Hello. I can help you with this times.
Step one - insert the pins at the times you want the night light to come on and go off. The green pins will turn on the night light and the red pins will turn it off. If you just want one on time and one off time just use one pin of each color.
After you have the pins inserted, set the correct time on the timer and plug it into an outlet that is always on [not one that is controlled by a wall switch].
The override switch will turn the device off if it is on, but just one time. As the next time it turns on it will once again be controlled by the times.
If ou want the night light to come on and off in the evening and again in the morninng, use two green pins and two red pins. Push in a green pin at each time where you want the night light to come on and push in a red pin at each time you want it to go off.
Get back if you need additional clarification.
Jun 02, 2009 | Intermatic & Lighted Dial Timer
It is not cooling at the top
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question please let me know.
thanks,
Mar 24, 2009 | Bosch Refrigerators
Raytheon --Apelco 365--fishfinder
For the information of future searchers, I add an OEM type repair that has just worked for me.
Go to the dollar store and pick up any audio lead that has a single narrow pin in the centre. Cut the plastic where the cable enters the plug to expose the end of the pin and wire connection. unsolder the plug and at the same time using the heat from the soldering iron, withdraw the pin from the plastic that is holding it in place. Now you have an unsoldered pin all on its own.
Remove the back from the Apelco 365 and unsolder the wire on the broken pin, (mine was just a push fit). Touch the broken pin with the soldering iron and withdraw it. Insert the new pin, heating it a little with the soldering iron. From the outside of the back case, check the alignment of the pin, making small alterations using a bit of heat. Once satisfied, apply a little dab of crazy glue to fill any gaps around the pin.
Job done. In future use a little Vaseline Petrolem Jelly on the female plug and make sure the plug is square to the back when you insert it, and lined up with the notch at the top.
Oct 15, 2008 | Boating
Kenwood 8pin harness
looking at back of 8 pin harnes, with wires facing you and tab facing up, left to right,
top
plugged into head unit i----------- i
______________________| |___________________________
| 1st pin, - blank | 2nd pin - Black wire | 3rd pin blank | 4th pin blank |
| 5th pin - yellow | 6th - pin blank | 7th pin- green| 8th blank |
Sep 27, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho Logo
121 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
Scott Jelt
Scott Jelt
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
