Question about GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Freezer frosting up and fridge not cooling - GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
    Sergeant:
    Champion:
  • 351 Answers
Check deforst element and timer
Posted on Sep 30, 2010
  • 1462 Answers
SOURCE: Refrigerator warm, frost in freezer
take back panel off freezer and check for ice build up which will block air flow and temps will rise. melt off carefully with a hairdryer.make sure drain is also clear and use hot water and patience if blocked with ice. if fault re-occurs, you have a fault with defrost system
Posted on Apr 24, 2007
SOURCE: fridge freezer
there is a fan inside freezer behind back panel. if pipework behind panel is covered with ice, it will prevent air circulation and the fridge is affected first
take back panel off and check for ice build-up and that the fan is working
Posted on Jun 23, 2008
  • 15 Answers
SOURCE: frost free fridge freezer freezing
make sure that the vents between the freezer and box are not frozen..check to see if the fan in the freezer is working(evaporator fan)..check timer and defrost heater,,
Posted on Aug 18, 2008
mgprice
  • 744 Answers
SOURCE: fridge/freezer cooling inefficiently
Either the repair guy did not wire up the heater correctly or he replaced the wrong part, if the heater was good it was likley to be the defrost thermostat...I would call the repair guy back to check.
Posted on Jun 23, 2009
hiltonjug
  • 612 Answers
SOURCE: Freezer frosted Inside, Fridge not cool
You have a defrost problem. Most likley a defrost heater if it's a side by side. If you unload the freezer so that you can get to the inside back wall, take the screws out of the inside back wall. Remove the panel from the back wall. Take a hair dryer and melt the ice that has formed behind the panel. (DO NOT USE A SHARP OBJECT TO CHIP ICE OUT) You can then see the defrost heater. If you put it back together the refrig, will work correctly for around three days. If the heaters are glass, you will be able to see if they are broken or the filliment is broken inside. If so you will need new ones. You will need the make, model number and serial number. to buy the new part.
Posted on Aug 15, 2009
Testimonial: "thanks"
Fridge s/s cool on freezer but no air cooling fridge side
First, inspect the back wall of the freezer for frost build-up. Defrost failures are a common cause for incorrect fridge temps, and the frost will block air-flow even if your damper is wide open. if there is no frost, verify that the evaporator fan in the freezer is spinning, THEN check the damper door to see if it is open during cooling. Call a tech, guessing will likely lead to a broken machine and/or tons of wasted money!
Apr 26, 2016 | Refrigerators
Maytag msd2641kew fridge side is not cooling its warm . freezer is still cold notice some of the ice look like it was starting to melt a litte. turned freezer up acouple of hours ago stuff is staying...
Sounds like a defrost problem, is there ice on the back wall of the freezer? If so the defrost system has failed. The most common repair is a Part# 67004757 defrost thermostat and adaptive defrost board Part# 67004704. Even with the parts in your hand, you will need to de-ice the freezer to replace the thermostat in the freezer section, then unplug unit to replace the adaptive defrost board located in the controls of the refrigerator section. Normally it can take about an hour to complete.
Good Luck
Jul 13, 2011 | Maytag MSD2756G Side by Side Refrigerator
I have an Amana fridge/freezer which is freezing only at the bottom of the freezer and also in the bottom of the fridge however the rest of the fridge and freezer are only just cool. The fridge is...
It is important to shut off the fridge for few hours so that the system cools down and the compressor resets. Now check the thermostat settings, check also the position of the freezer settings.
After the fridge is switched on , if there are no issues then the auto frost timer can be a suspect. If not the thermostat must be checked. check if frost has build up to prevent cooling.
Jun 13, 2011 | Refrigerators
I have a Kelvinator Opal Fridge/Freezer. The freezer is working fine but the food compartment wont cool. It used to run too cool and freeze stuff on the top shelf. The fridge seals are fine, the fan runs...
The vent from the freezer to the fridge can be blocked with frost and is preventing the flow of cool air to the fridge.
This can happen if there is frost build up due to failure of the auto defrost timer.
So please check on the fan section , remove panel and see if there is frost or block, if so check the timer Heater and the thermostat.
Jan 24, 2011 | Refrigerators
Electrolux frost free fridge freezer. Warm fridge and ice in the frost free freezer?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 22, 2010 | Heating & Cooling
Freezer frosts up, cleaned coil under fridge and defrosted. worked for about 2 weeks and is starting to frost up again.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 19, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer not cooling, fan blowing, fridge also not
If there is no frost , on the inside rear freezer wall ,
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
If there is frost , reply back with complete model number .
Nov 08, 2009 | GE PSS25MGN Side by Side Refrigerator
GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
48 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
