Question about Hayward 1.5 Hp Northstar High Performance Pump
Hayward 1 1/2 hp pump is four years old and just stopped working. I reset the circuit breaker and the motor hums and just clicks off. The heater and goes from stand by to service. What should I do first? Thanks Jerry
  • 44 Answers
Your heater will not work until you fix your pump, and your pump won't work until you replace the shorted out motor.
Posted on Sep 30, 2010
I have a hayward pump model SP2610X15 that will only hum when turned on. I replaced the capacitor, it did not help. What else could be the problem?
DIRTY START switch or the motor is locked up, breaker off ! remove motor from tank body and see if the motor will turn over if it does could be the switch or the motor is shorted witch there is no fix but a new or rebuilt motor. search your area for your local pool pump motor repair guy with free testing..
Jay the pool pump motor repair guy longwood Fl
Apr 02, 2012 | Hayward 1.5hp Pool Pump Motor Motor A O...
My hayward pool pump not working,forget to close the air vent before pump started and is water allover the pump,what to do?
Water sprayed on the pump occasionally shouldn't hurt it but it might cause a ground fault circuit interupter (GFCI) to trip. If you turn on the pump and literally nothing happens then most likely the the GFCI has tripped. If it hums then this is a different issue. If you have a volt meter you can open the timer box and check whether power is available to the timer. If no power is available in the timer then it confirms that the pump is probably ok. Checking your circuit breaker panel for a tripped breaker or finding a tripped GFCI then either one can be reset and your pump will probably run without a problem.
I hope this helps.
Sep 16, 2011 | Hayward Tristar Pool Pump 1 Hp for In...
The pool timer goes on, the hayward 2 HP pool pump turns on and then causes the circut breaker to pop. After two, three resets, it starts to work. This problem started a week agao. The pump is 9 years old.
could have a bad run capacitor or a start capacitor . search your area for your local pool pump motor repair guy with free testing, 9 years old that motor needs to be rebuilt.. i charge 85.00 to rebuild a 2hpincludes a free shaft seal.. remember to prime the pump with water after a repair !! best of luck .. oh breakers become week after amount of time time .. and ask the repair guy if this is the right size pump for you pool.. 9 out of 10 times its way too big !.. jay longwood florida
Sep 08, 2011 | Hayward 2HP Pool Pump Motor A O Smith...
My pump stop working. It's 3 months old. There's power to the pump and the switch is on. Is there a internal fuse or circuit breaker
There is part inside the motor that resets automatically if the current is too high. If the motor hums and then switchs off for a while and the retries after a while repeatedly then you may have a bad capacitor. I hope this helps.
Aug 12, 2011 | Hayward Power Flo Lx
My Hayward Tristar 1.50 HP pump is 3 years old, and recently developed a high-pitched humming noise that is causing a noise disturbance. The performance seems to be operating okay, but it never used to...
sounds like the bearings are going out on the motor. The noise will increase as they wear out more until it locks up and throws the breaker. You can have the motor rebuilt or just replace the motor. Consult a pool professional to help out with this.
Nov 22, 2010 | Hayward TRISTAR PUMP 1.0 HP, 115/230V
Pump is making humming noise but not turning on. This happened after a breaker blu. I reset breaker and this is what happened.
This may just be the start celonide. Look's like a "D" battery or bigger in the back of the motor or on the top in a half round case. It is ment to boost the power to start the motor turning. If it bad the motor just humms till the breaker blows. Sounds like just what you have.
Jul 11, 2010 | Hayward 1 HP 2 SPEED POWER-FLO MATRIX PUMP
Haywood Max-Flo Pump (self priming)for indoor inground pool 3/4 HP ... model C48J2N131A -- yesterday turned off master breaker switch to everything in the pool area (including power to pump) so that I...
The motor may have blown the start capacitor. It is the black cylinder about 1-1/2" dia x 2-1/2" long. Look at the end with the wires for a small hole. Is it blackened or have a hole blown thru? If so replace it. Otherwise have a local electric motor repair shop look at it for possible repair or replacement.
Sep 06, 2009 | Hayward Pool Products Hayward Max-Flo 1...
My hayward pool pump was working fine until yesterday when I blew the circuit it was on. After turning the breaker back on, all my pump does is hum. I took the rear cover off of the pump and was able to...
It is likely a motor failure. You may be able to take it to a local electric motor repair shop but most of those motors are not economical to repair. You can replace the motor and pump seal for far less than the whole pump. If you would like a quote on the parts, try us at www.arrowpools.net
Use the contact button and include your current pump info in the message.
Jul 05, 2009 | Hayward Powerflo Matrix 1 - Hp Above...
Hayward Super Pump not turning on
it sounds like your pump is stack it could
bee that something is stack in the pump,
try somehow to turn the motor to see what is binding
get access thrue the pump.
G
May 18, 2009 | Hayward Super Pump 1 1/2 - Hp for In...
Hayward 1.5 Hp Northstar High Performance Pump Logo
160 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
