Question about Hitachi 60V710 60" Rear Projection HDTV
I changed the lamp almost 8 mths ago and now its not working again- same problem. please what to do
  • ladywinn
    ladywinn Oct 28, 2011
    What is the model number on back of TV?
  • Hitachi Master
  • 5,138 Answers
Get another Lamp Mats $99.00 1-800-628-1118
If you play this TV 24-7 you might need Lamp most lamps last between 5,000hrs of playing time,so when lamp has been played for 5,000hours then lamp goes bad.
Posted on Sep 30, 2010
  • Lilkey616 Oct 28, 2011
    How do u chande the lamp
    Do any one no how to change the lamp and where can u buy them from
My check engine lt went on this morning and will not go off. any ideas? No other issues. Had the head gasket changed several mths ago along w/timing belt and water pump. Also alternator went about 2...
Take it to autozone or advance auto they will tell you what the code is for free but more than likely it's an oxygen sensor that needs replaced 9 outta 10 times that's what a check engine light is on for
Sep 15, 2011 | 2003 Subaru Baja
I have a Hitachi CP-S860 projector that we replaced the lamp in 8 months ago. Now it powers on and the lamp comes on, but after about 2 minutes the lamp shuts off and you can hear the fan stop working...
Hi dear, This is ballaster board problem.If proper voltage is not going to lamp means this will occur.so, change ballaster board.I hope this is helpful for u
Aug 11, 2011 | Hitachi CP-S860 Multimedia Projector
Changed o2 sensor 14 mths ago.2002 v6 xl7 5 speed only 60,000 miles. only owner. check light on again thought I only had 1 sensor.Getting plugs changed,Changed air filter again yesterday. i change oil and...
Well your exhaust system may still be under the 8-80 warranty, so I would check with the dealer. My 01 had 4 sensors, an upper and lower on each side. Yours has at least 2 so replacing one did not update the other, and your converter(s) may have failed. So I would start by checking your VIN with a dealer to see if you are still under the 8 year/80,000 mile warranty on the exhaust system. If not I would have them do a diagnostic on it to see what is bad.
Apr 21, 2010 | 2002 Suzuki XL-7
Replaced the lamp in our 52HM84 and it still does not work.
Ballast board it is what powers Lamp,
Call Encompass parts Distrubtion 1-800-638-3328
Apr 12, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Sometimes the TV's lamp will not go on with the first Power-On
When the set shuts off again count the number of times the led on the front flashes and the color of it. ait will flsh a number of times pause and then repeat. this is an error code and will help diagnose the problem.
Apr 01, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
Timex 1854 chrono,indigo lght not working. 2nd one in 4 mths?
the same problem, after 3 years of use.
Night Indiglo light was very bad.
thought the battery replaced it, the battery was okay.
began to collect but probably need a special tool, the glass cracked)
Sep 09, 2009 | Timex Watches
My 1999 jeep grand cherekee laredo shut off on me 8 mths ago and now it just did it again. It will fire back up only to shut right back off. Almost like a safety device but i do not have anything like that...
Try switching out your ignition switch. I had a similiar problem and changed the part out and haven't had any issue since. they part is fairly inexpensive, and you can do it yourself. it is held in with 2 nuts and bolts, and has pig tails on either side of it. it should take you more than 10 minutes to do. you will spend more time going to the parts store to pick it up.
Jun 10, 2009 | 1993 Jeep Grand Cherokee
Lamp change
Press the Auto button when it says it's going to turn off, then hold Exit, then when it tells you, press Auto again - worked for me literally 5 mins ago :)
Good luck
Dec 06, 2008 | BenQ MP610 Multimedia Projector
Philips Magic 5 fax/copier/phone
Take the Sim card out and put it in again.  Worked for me.
Sep 11, 2008 | Office Equipment & Supplies
Hitachi 60V710 60" Rear Projection HDTV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
