Question about Philips 42TA648BX 42 in. LCD TV
Screen dead - no power Is there an internal
Screen dead - no power Is there an internal replaceable fuse?
  • 11,361 Answers
Yes, there is main AC fuse in the power supply module, it is usually marked on the board as F??.
If is has blown fuse, then you will need to Ohm out the circuits to see if it has any shorted out components such as brdige rectifiers, MOSFET, ECT.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Sep 30, 2010
Suddenly microwave stopped working
(would really like more info- digital number dead as well?)
(assuming completely dead) Could be a couple of things:
- blown fuses (inside, relatively easy to replace, std size avail at Raioshack) <-- most likely
- cut/loose power cord connection inside.
- (unlikely but worse case scenario) Door was closed crooked- one tong hit one door switch before the other- causing a short circuit internally that "self destructs" the microwave to prevent it ever operating with an open (or even crookedly ajar) door, irradiating any users. Typically it just blows the fuses, but if fuses blow immediately upon replacing and turning power on, then possibly one of the switches fused or melted internally, and needs to be replaced.
Jan 28, 2014 | Whirlpool MT4155SP Microwave Oven
How do I replace the internal fuse on my Over the Range GE microwave? I opened the microwave door and and there was a quick spark after which the microwave went dead with no power. I have checked the...
I would say the lamp popped and took the fuse, so you will need to replace the lamp also.
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARRAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 05, 2011 | GE Microwave Ovens
The oven is totally dead. No light, fan etc. Replaced fuse internally, found no current at the fuse. Outlet has 120 v. Oven was run empty prior to going dead! Any thoughts?
check power between power cord connection and inernal fuse,start at cord connection and work way to fuse conn.eliminating possibe problem area
Oct 11, 2010 | Maytag MMV5000 Microwave Oven
DEAD, NO TURN ON, CHECKED INTERNAL FUSE OK
If the internal fuse is okay, then what you got here is a bad power supply. Many power supply's do die with the internal fuse intact what happends is the High voltage tranformer or relay goes out on you causing this to happed, Best thing to do is replace the unit becuase a new power supply would cost you more then the unit new. Let me know if you have any question.
please do not forget to rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 10, 2010 | Toshiba RD-XS32 DVD Recorder
Dead TV
U know basic electronic's,and u know how to do soldering?Have soldering iron,tools and solders?The power supply board,the board that the power a/c power cord plug into it.That the power supply board have these parts call capacitors are dead.These capacitors alway bulges up on it top or puff on it top.Check all around the power supply board and it supporting boards.Replaced these dead leakage bulges up on it top or puff up on it top.Or tries websites like Shopjimmy.com,Ebay.com to buy and replaced the whole refurbish power supply board.
May 28, 2010 | Hitachi 32PD5200 32 in. HD-Ready Plasma...
Dead Microwave - Internal Fuse?
After replacing the internal fuse (see other posts to see how I did it) the microwave is working fine (so far). We have used it 5 or 6 times without any issues.
Jan 23, 2010 | KitchenAid KHHS179LSS Convection /...
Heard a pop then screen went blank. Now TV wont turn on.
Sounds like your fuse.
If not the fuse in your plug, then the internal fuse in the TV. to get too this you need to open the TV by taking off the back plastic panel and look at the fuse.
the fuse is the glass tube on the board, will no doubt be near where the power cord connects to the TV. and are easy to replace with another fuse. you will know soon as you open it if its blown as the little glass tube will be blackened or the little wire inside the tube will be missing or severed.
Fuses in TVs are actually designed to blow over time with ware (usually to last a bit longer then the warranty time frame) so after the cover has ended the TV can go in for repair work at extra cost. Its a little known fact.
Jan 02, 2010 | Sony KDF-E42A10 42 in. LCD Television
Tv dead power through on/off switch
yes there is a fuse.that is located on the main board.and that fuse is mostly blown and needs to be replaced. you can get new fuse at  www.radioshack.com at the rate of $2.
May 05, 2009 | Televison & Video
Philips 42TA648BX 42 in. LCD TV Logo
188 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
