Question about Kenmore HE2 Plus Front Load Washer
Door stays locked and wont drain - Kenmore HE2 Plus Front Load Washer
    Sergeant:
    Champion:
  • 351 Answers
Check strainer be hind lower front panel
Posted on Sep 30, 2010
Wont drain..door locked..what do l do?
put drain hose below water level when empty should spin
Apr 17, 2015 | Washing Machines
WHAT SHOULD I LOOK AT FIRST
You need to look at the door lock actuators, I'm guessing 1 is operating but staying on when locked and draining the battery. Try manually locking the doors and see what happens. It may come down to removing the door trims and disconnecting each lock in turn, don't forget the boot lock, until you find the culprit. Its possible you may hear the lock solenoid humming or buzzing or feels warm as its trying to lock the door unsuccessfully.
May 20, 2014 | BMW Z3 Cars & Trucks
Doors wont lock when you turn on ignition.And the radio doesn't stay on when you turn the ignition off.
Your radio is connected to ignition instead of accesories. Not all car locking sytems lock doors with ignition. Check with the supplier if known or with nistallers.
Sep 25, 2012 | Cars & Trucks
My mah9700aww door stays locked and when i try to start it in any cycke i just hear a humming coming from the assy pump drain.
my mah9700aww door stays locked and when i try to start it in any cycke i just hear a humming coming from the assy pump drain.
Aug 01, 2010 | Maytag Neptune MAH9700 Front Load Washer
1998 Ford Windstar fuse problem - dome light stays on etc
you most likely have a bad door ajar switch- the door panel has to be removed to access it, its on the door latch- you can unplug them this will take care of the batt drain prob.as for the locks it may be a switch problem- most ford vehicles will not let you lock the vehicle from the driver's door when it's open to prevent locking the keys in.
May 26, 2009 | 1998 Ford Windstar
I have the neptune front loader. The lock light wont come on and the door wont lock. During a wash cycle the water just started comming out of the door. If I hold the stop/start button manually the light...
hi there,
you have a door latch problem. the reason you can still push on the button is because this particular washer has a time delay function. i would recommend taking a look at the latch itself and possibly the wax motor that runs the latch.
Dec 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Cycle finished but door won't unlock, please help
normally, front loading machines have this bypass cables in case this things happens, if there is a small opening at the front to acces the drain filter, open it up then look for a small plastic pc with a ring at the end. this is the pull release cable of the door lock. pull it downwards and the door will be released.
if you do not have the small opening to access the drain filter, you can tilt the machine to its back, ( be carefull, its very heavy) then reach for the plastic ring underneath to pull to release the door lock.
tnx 4 using fixya..
drcool
Aug 30, 2008 | Hotpoint WMA40 Front Load Washer
Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Remove drain hose from where it connects to the plumbing under the sink/tub. Inspect the spigot. If clogged, clean. If clean, then tilt machine back and remove drum to pump hose from pump. Check hose and also drain pump. Clear any obstructions.
Nov 03, 2007 | Washing Machines
Door clicks and wont open and washer runs but wont do anything
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure You should remove machine's top cover and then you will have an access to the door lock unit. Be aware you should discconect machine's power cable first !! Good luck!
Jun 15, 2007 | GE WBVH6240F Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
57 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
