Question about Bosch HDI7282 Dual Fuel (Electric and Gas) Kitchen Range
Bosch electric range 700 series model # hes7152u error # 124
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with leave the unit unplugged for 30minutes to 1hr. then plug it back, if still the issue is not resolved then you'll have to replace the Electronic Range control (ERC). However, while it's unplugged you can also try to blow air on the control with the help of hair dryer so that if there is any moisture it blows it off. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 30, 2010
Bosch range door does not close all the way
there is a repair kit comes with hinges liner heat shield
call bosch with mod and ser # they may cover
Jan 26, 2018 | Bosch Integra 700 HEI7052U 30" Slide-In...
Touch sensor Bosch HES-7152U /01
Maybe if you unplug it let it sit for for a half hour then plug it back in maybe that might work.
Jan 02, 2013 | Bosch HES7152U Electric Range
Oven is taking a long time to heat...15 minutes and it barely reaches 200
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more deatil about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Aug 31, 2010 | Bosch Integra 700 Series HEI7152 Electric...
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Bosch convection oven in self clean mode, am getting an error code of 41
Hi, I am getting the same error today. Did it ever clear up? Were you able to open the door eventually?
Jan 24, 2010 | Bosch Evolution Pro-Style 700 HDS7282U...
Bosch oven function error e124
Can you provide a model number for your oven. Is it a single oven or double ? Wall oven or free standing range ?(conventional with cooking surface)
Unfortunately the error codes for Bosch are different depending on the model of the unit.
Thank you, I`ll look for your reply.
macmarkus :)
Jan 09, 2010 | Bosch Ovens
Noisy cooling fan. When I first installed this range, I thought the fan was defective, so had it replaced. The replacement made absolutely no difference os it is a design defect. I wrote Bosh, never...
Bosch has a repair kit to solve the problem-our dealer ordered it and installed it after their first fan replacement failed. The kit changes the door ventilation and the fan speed.
Dec 25, 2009 | Bosch Integra 700 Series HEI7152 Electric...
All lights on the touch panel are flashing and a continous beeping sound
bosch 700 series range. So far unplugging the range and waiting several minutes to plug back in reset everything like rebooting a computer.
Dec 19, 2006 | Bosch HGS435UC Gas Kitchen Range
Bosch HDI7282 Dual Fuel (Electric and Gas) Kitchen Range Logo
326 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
