Question about Casio Exilim EX-Z55 Digital Camera
Lens was stuck. And camera won't turn on.
I was camwhoring but suddenly my camera gave me this 'Busy..Please Wait.' sign until it died, with the lens stuck out and wont turn on. I dont suppose the batterry is the problem since it was fully charged and I just started using it. Please help me. Thanks.
  • 374 Answers
Nope. That is a definate lens error. That is going to have to be sent into repairs.
Posted on Jul 14, 2008
Lens won't come back
If the battery is discharged then it is likely the lens is stuck . If you can get the battery to charge and then turn on the camera it should help the lens come back. The camera will not turn on when the battery charger is connected. So you will have to wait until the battery is charged and turn on the camera only after disconnecting the charger.
Apr 28, 2014 | Nikon 26302 Coolpix S6300
Lens stuck
Please see this link for troubleshooting steps for a stuck lens.
And here's a video summary of the steps.
Apr 28, 2013 | Samsung S860 Digital Camera
Camera is stuck with lens out and won't turn on or
If this camera takes ordinary batteries you may have inserted them the wrong way around.
If it takes a rechargeable pack recharge it for average time recommended and try again.
Sep 20, 2011 | Sony Cameras
Lens is stuck with the barrel out. I hit power button and the light only turns orange then shuts off. If I hit playback button...says busy and shuts off.
I can't tell from your description what type of camera you are using, but it sounds like the battery is dead or dying.
It takes a lot of batter juice to open and shut the lens, and to power the LCD screen to view photos.
I hope this helps!
Mar 06, 2011 | Cameras
Powershot sd630 digital elph busy can not reset and says busy when deleting one picture
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 17, 2011 | Canon PowerShot SD630 Digital ELPH / IXUS...
Goes off after lens come out.
Get it repaired under warranty. Sounds like a logic circuit problem.
Dec 10, 2008 | Pentax Optio S50 Digital Camera
Lens not going in & getting stuck
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
Oct 10, 2008 | Samsung S760 Digital Camera
Lens cover only partially opens
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But it should be similar for the A430:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Mar 31, 2008 | Canon PowerShot A540 Digital Camera
Lcd reads system error
Apparently often related to a lens motor malfunction. My old 4300 just gave this error for the first time today. The lens extended but made a whirring noise before the message popped up. Nothing I tried would fix it - but after I drove home it worked fine again.
I had a similar problem over a year ago after the camera fell out of my backpack (it was in its own bag but not well padded). When I used it the lens stuck and refused to retract, but I don't recall a "System Error" message. After a few tries, the lens went in and it's been fine since, until today.
Make sure there's nothing (dust, dirt) stuck in the lens barrels. Otherwise, just keep turning it on and off and hope it works.
Dec 31, 2007 | Nikon Coolpix 4300 Digital Camera
Casio Exilim EX-Z55 Digital Camera Logo
153 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
