Question about Linksys WRT120N Router
Cannot reset to factory settings my linksys WRT120N I tryed with reset button 30 seconds but nothing change
    Brigadier General:
  • 10,406 Answers
Turn the router off.
Hold the RESET button in, for 30 seconds.
Turn the router on, and see if it has reset.
If not, then with the router still on, hold the RESET button in, for 30 seconds, and see if it has reset.
Posted on Sep 30, 2010
My wrt120n was hacked. login password was changed and i cannot login into the conf webpages. I do have physical access to the router. I tried to do the following after some search on the internet 1....
Please reset the router by pressing the reset button while your router should be plugged in to the power cable.
While reseting the router the lights on the router should be blinking for 30 seconds.
Try this this should work.
Apr 28, 2013 | Linksys WRT120N Wireless Router
Factory restore
According to Linksys support, you should not reset your WRT120n wireless router unless you are having difficulties with the unit. The WRT120n user guide also recommends applying other troubleshooting options before attempting to reset the device. Resetting the WRT120n restores the router back to factory defaults. After resetting the Linksys 120n, you''ll have to reconfigure the router back to your preferred settings.
Locate the Reset button on the back panel of the WRT120n. The button is labeled "Reset" and situated between the power port and the "1" Ethernet port. Press and hold down the "Reset" button for five seconds. The device resets. Open a Web browser on your computer. Type "192.168.1.1" into the browser's address field, then press "Enter" on your keyboard. A login prompt opens. Enter "admin" as the password. Leave the User Name field blank, then click "OK" to log in to your router and access your network settings.
Apr 02, 2013 | Linksys WRT120N Router
Forgot my password for wrt120n
Looking for the Linksys WRT120N default password? You probably have little reason to access your router on a regular basis so don't feel too bad if you've forgotten the WRT120N default password.
However, when you're troubleshooting a network problem and need to get in to the device, the WRT120N default password suddenly becomes very important.
For most versions of the Linksys WRT120N, the default password is admin. As with most passwords, the WRT120N default password is case sensitive.
In addition to the WRT120N default password, you can also see the WRT120N default username and WRT120N default IP address in the table below.
Note: The Linksys WRT120N default password may be different for certain hardware orfirmware versions.
If I have that information, I'll include the exact WRT120N version number along with the correct default password. You can usually find your Linksys WRT120N version number on the bottom of the router.
Be sure to change the default router password on your WRT120N to something more secure as soon as you're in. Then use a free password manager so you'll never forget your new WRT120N password.
Help! The WRT120N Default Password Doesn't Work!
At some point during the life of your particular Cisco Linksys WRT120N, the default password, username, and/or IP address might have been changed.
In most cases, if the Linksys WRT120N default IP address has been changed, the new IP address for the WRT120N will be the same as the default gateway IP address configured for your network connection.
See How To Find the Default Gateway IP Address for help.
In situations where the WRT120N default password or WRT120N default username has changed, you'll need to reset the Linksys WRT120N to factory defaults. You can usually do that via a special button or sequence of actions.
The WRT120N manual will have specific directions for performing a factory default reset. You can download the manual for the WRT120N from Linksys Support.
Please let me know if any of the WRT120N default login data below needs updated. For other questions about the WRT120N default information on this page, see my Default Password FAQ.
WRT120N Default Password & Other Default Login DataVersionDefault UsernameDefault PasswordDefault IPPrivilegesAll[none]admin192.168.1.1Administrator
Jan 13, 2012 | D-Link 802.11g Wireless Router WBR-1310...
I can't connect to the internet w/ my new laptop. I can't find my security key to hook up.
This article documents a known issue with resetting a Linksys WRT120N to its factory default settings.
Symptom: Holding down the reset button on the back of the router does not reset the settings.
1) Download the latest firmware from Linksys (link below).
http://homesupport.cisco.com/en-us/wireless/lbc/WRT120N
2) Unplug the router, hold the reset button, and plug in the router while still holding the reset button.
3) Open Internet Explorer, go to http://192.168.1.1
4) Use the "Browse" button to locate the firmware file downloaded from Linksys.
5) Once the update is complete, unplug the router and plug it back in.
6) Hold the reset button on the back of the router for about 30 seconds, a light will indicate when it resets.
7) Allow the router to reset for 1-2 minutes.
8) Open Internet Explorer, go to http://192.168.1.1
9) Enter "admin" for the username and "admin" for the password (without quotes).
Your router should now be reset to the factory defaults!
Nov 04, 2011 | Linksys WRT120N Router
How do I restore factory defaults?
hi,
If you want to restore the Linksys WRT120N router to default, you should find a reset button at the back. It will require a pin to press it. you have to hold it at lest 5 seconds and it will be resotored to factory default settings.
Thank you for using fixya.
Jun 16, 2011 | Linksys WRT120N Router
How do I reset my router password
Here is the step-by-step instruction to reset Linksys WRT120N Router
  • First af all you have to make sure the power is "On" . Power the router up while pressing the reset button located at the back of the router using pencil or paperclip
  • After around 30 seconds you will be prompted with the boot loader. Connect the boot loader using the standard IP address if you have not changed it (http://192.168.1.1)
  • Upgrade the firmware to the latest one from Cisco site
  • Power cycle the router and allow it to come up.
  • When it is fully up, press and hold the reset button for 5 secondsThe LED light will blink indicating that you're done holding the reset bottom. If the Power LED won't blink try to press and hold the Reset Button for I minute and then power cycle the router for another 1 minute.
  • Power cycle the device and now you have reset your linksys WRT120N router See the following link if you forgot to setup linksys router
(http://infoteknotainment.com/reset-linksys-wrt120n-router)
May 24, 2011 | Linksys WRT120N Router
Carlos, we have been doing the hard reset for a while already... more than 30 seconds... to no avail... still no blink and not yet resetted.
Are you trying to do 30/30/30 reset??
THIS WILL RESET TO FACTORY
You have to do this.
THere is in the back a reset button.
With the router on.
NEVER RELEASE THE RESET BUTTON UNTIL FINISHED.
1. HOLD THE RESET BUTTON FOR 30 seconds by watch
2. PULL OUT THE POWER CABLE while still holding the RESET BUTTON for 30 seconds.
3. WITH THE RESET BUTTON STILL PRESSED plugged in the power cable and continue holding for 30 seconds.
4. Then release RESET.
Hope it works.
God Bless You!!
Feb 05, 2011 | Linksys WRT120N Router
I want to reset my linksys wireless N router, model WRT120N. I have tried holding the rest button for 30 seconds, then unplugging it for 30 seconds then holding it for 30 more seconds to no avail.
Your router should be set to its factory defaults by either pressing and holding the reset button (at the right of the LAN ports) for 5 seconds, or firing up its browser-based utility (defaults: http://192.168.1.1, username left empty, and 'admin' as password) and going to 'Administration > Factory Defaults'.
By the way, if your router's user guide happens to be missing, feel free to download it from this location.
Please, let me know if I can help you any further.
Regards, Carlos
Dec 03, 2010 | Linksys WRT120N Router
How to reset default of my linksys wireless router wrt120n
Just press and hold the reset button for 30 seconds, that will restore it to factory default settings.
Important note: this will erase any settings you have made, so make sure you have your username/passwords, etc from it before resetting.
Oct 16, 2010 | Linksys WRT120N Router
Password for wrt120n
Default factory settings for this router:
IP address: 192.168.1.1
username: (left blank)
password: admin
If this username and password doesn't work because it was changed, press and hold the reset button on the rear of the router for 30 seconds. This will reset the router to factory defaults.
Apr 06, 2010 | Linksys WRT120N Router
Linksys WRT120N Router Logo
583 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
