Question about Oreck BB1100DB / BB1100DC Housekeeper Ultimate Bagged Canister Vacuum
I live in Kent UK i moved in this house a year ago now we feel quite strong dusty smell specially in two rooms upstairs we clean house on regular biases but smell is still there and we think its not a damp smell does any one have idea what that smell could be ?
  • 10,865 Answers
Check your ductwork. It could be that they need to be cleaned. Also look for lady bugs because they clearly smell like dust. J.
Posted on Sep 30, 2010
Can you wash the Roomba Cleaning Head Module
I have cleaned every part of my Roomba without any problems.
Over a year ago my dog had a serious case of the runs. Before we got home my Roomba i780 equipped with it's millions of dollars worth of R&D effectively spread said dog "business" evenly to every single square inch of hardwood floor and carpet in my house. It was quite a scene, and cost me a pair of $300 Ugs to get my girlfriend to clean it up.
Needless to say I took it completely apart and washed every single component. Actually I washed each component several times because the smell lingered.
While it says in the instructions not to use cleaning solutions on the components I can say that in my experience it did not cause any harm. Mine has been working for over a year since without issue.
I should add that prior to this happening I had cleaned the cleaning head module with fantastic many many times. I'm guessing yours is starting to accumulate that mm thick film of dirt. Just spray a paper towel with cleaning solution and slowly wipe it off. I have found putting a cloth over a screwdriver for "soft scraping" is good strategy.
Nov 21, 2015 | iRobot Roomba 880 Vacuum Cleaning Robot
How to clean out dc27?
Hi there, it's Jack at Dyson.
If your DC27 seems to be making a burning smell in use, we would strongly advise against continuing to use your machine until we can inspect it and carry out a repair if needed.
Please contact us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) so we can take some further details. We can also confirm if your machine is within our 5-year parts and labour guarantee period.
Aug 19, 2014 | Dyson Vacuums
Vacuum just quit, while in use
If the Power from the wall receptacle was OK, and you did not trip a circuit breaker, then the motor may have shut down or the on/off switch broke. Usually your house power would go out if a short circuit occurred while plugged into the house current. Check all wires, and smell the housing for any burn odor. Look at the brush for accumulated matter that collected and stopped the motor and brush from moving. Clean if necessary.
Apr 03, 2014 | Royal 2028 Classic Household Upright...
Kenmore canister - trips 15 amp circuit breaker
Check specs on unit and amperage. If it is less than 15 then the upstairs breaker is kicking off prematurely - Not uncommon event. If unit is drawing more power than specs there is excessive friction in motor bearings. Also check out brushes for good contact since they wear.
Sep 11, 2017 | Kenmore 25512/ 25513 Progressive Canister...
Blowing dust out even after cleaning filter
the bagless containers of these vacuums do tend to hold a strong dust odor. the only way ive found to help eliminate it is with a product that i use called FreshWave odor neutralizing pearls. you never want to use fine dust carpet freshener or any product like that cause it will eventually burn up your motor. but if you are interested give me a call and i can ship you some of the freshwave. 703-724-1112
Apr 11, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Miele vacuum dust problem
Hello. The problem you are having can be rectified with the new Miele FJM bags.
http://www.mielevacuumbags.us/
Also, if you have never taken your machine into a vacuum repair shop for an internal cleaning, please do so. J.
May 24, 2010 | Miele S4210 Carina Bagged Canister Vacuum
I have a hoover mach 5 multi-chamber cyclonic vacum cleaner and it keeps getting hot and quitting.it's got a strong smell like something is burned when it gets hot also.
if its giving off that strong smell then the motor is bad. probably caused by not keeping the filters clean. on any bagless machine one has to clean the entire vacuum after almost every use to keep the unit operating correctly
Dec 31, 2009 | Vacuums
Hoover Vacuum Cleaner Bad Smell
change filters. the filter inside the unit and the one on the side needs to be changed once a yr. (these are not to be washed, only the side filter if foam can be washed ). also flat belt change every 6 months and the v-belt once a yr.
Jul 19, 2009 | Hoover U6616-900 WindTunnel Bagless...
Bissel vacuum cleaner
That is the problem with a bagless, but if you keep the filters clean it won't be quite as dusty.
Jul 02, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Dusty smell
http://geeksquad.fixya.com/ThreadView.aspx?prdid=41018&thid=618510
Dusty smell
Posted by chekle on May 23, 2008
I buy loads of Hoovers and always same problem. When I Hoover its a dusty smell and it stays around bag not full and check filter the Hoover is ok f couple days then this happens.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5881-900 Vacuum. It sounds to me that if you have a clean bag and filter, it sounds like you have dust in the motor section and it needs to be cleaned and or take a good blower and blow out the dirt or you may have a clog or dirt build up in the suction line and that might be causing the dusty smell. Please feel free to contact your local vacuum cleaner dealer in your area or call the Hoover factory and ask for tech support. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 23, 2008 | Hoover F5881-900 Vacuum
Oreck BB1100DB / BB1100DC Housekeeper Ultimate Bagged Canister Vacuum Logo
66 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
