Panasonic NN-S960BA Microwave Oven Logo
Posted on Sep 30, 2010
Microwave seems to work but will not heat. - Panasonic NN-S960BA Microwave Oven
Microwave seems itis working fine but not heating
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Microwave will not heat food everything else seems to work, timer, rotating plate everything works but heating food
Basic Microwave Oven Troubleshooting Tips
heatman101
=0=0=0=0=0=0=0=0=0
Unit operates does not heat anything
A defective diode or magnetron can cause the oven to sound differently and not to cook.
Microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101p[]][p
1helpful
Things are not heating up in the microwave
My GE Spacemaker Microwave oven does not heat up. Every other thing works. Model JVM1640
1helpful
Microwave seems to work but doesn't heat up
HI, when the Magnetron becomes unstable, the microwave will not heat anything. simply replace the Magnetron. This device creates the heating action and it is damaged and not functional at this time.
No heat in Microwave operation
Check High voltage rectifier diode if it is ok replace the Magnetron.
Jenn air microwave....
Probally the belt is broken on fan up at the top.
MICROWAVE NOT HEATING
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Top Panasonic Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Jerry Naidoo
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
