Question about Bosch Axxis WTA 3510 Electric Dryer
Bosch AXXIS dryer # WTA 3510 uc slipping / grinding sound when drum reverses direction. Difficult to turn drum by hand. Belt or motor?
    Sergeant:
    Champion:
  • 351 Answers
Drum baring or rollers if you can get belt off try to turn drum if it still hard to turn you will know its not the motor may be something in blower give it a try
Posted on Sep 30, 2010
Testimonial: "Will try it with help of a friend. Sounds much less expensive than replacing motor as Bosch dealer suggested. Thanks"
Loud, low (bass) noise, not coming from the vent or the heating element
Most probably caused by one of the belts being frayed and about to break. You might want to replace the small drive belt (00096426) first as it does the most work of transferring the motor power to the shaft causing the drum to rotate. A worn belt can cause a low frequency hum and potentially slow down drum rotation as it slips on the hubs. Replacing the large drum belt requires a lot more work than the drive belt because you must remove both the front and side panels of the dryer; whereas, the drive belt is accessed by removing the right side panel.
Apr 25, 2015 | Bosch Axxis WTA 3510 Electric Dryer
Bosch WTA2000 tumble dryer motor turns weakly without the belt.
The brushes in the motor are probably shot. Good luck in finding those though, best to just replace the motor.
Dec 09, 2013 | Bosch Axxis WTA 3510 Electric Dryer
Hello, I have a Bosch Axxis electric dryer that when i turn it on and hit the start button the light comes on telling me that the unit has started but it is not spinning. Also there is not any heat being...
Hi, Welcome to FixYa. If you turn the drum by hand do you feel any airflow out the back ? (you need to undo the vent hose too) This will tell you if the belt is broke. Let me know and we can go forward from there. Regards, Macmarkus :)
Mar 21, 2011 | Bosch Axxis WTA 3510 Electric Dryer
The drum is not ratating, difficult to rotate manually
Hello:
IF you hear a motor while attempting to use the unit, then it is possible your drum belt has broken,
If you do not hear the motor then its possible that the motor is defective and has frozen up on you.
Jan 08, 2011 | Bosch Axxis WTA 3510 Electric Dryer
The dryer heats but the drum won't turn
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 05, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis electric dryer, 3 years old, dryer drum won't turn
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 22, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Dryer rotates and drys well, but makes a noise when reversing rotation. Makes more noise at the beginning of use, then subsides. What could be wrong? Belt, bearings? Can I fix or do I need an expert?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fsjhgf
Nov 20, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Dryer drum stopped rotating, dryer blower continues to work.
The belt probably broke, and coincidentally happened while drying the shoes. The belt is easy to replace. Open the back and you'll probably see the belt laying on the bottom
Nov 10, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis WTA 3510 Electric Dryer. I changed the fuse but it won't turn. Could it be the motor because I don't hear any sound?
there is a switch next to the belt tension arm behind the motor that needs to be reset push the switch needs to be pushed to the right andthis should get your unit running as long as you have power
Sep 16, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis WTA 3510 Electric Dryer Logo
453 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
