Question about Canon PowerShot A75 Digital Camera
Need help fast b4 prom
Camera visual screen does not display what the camera is pointed at, the dispaly button has no affect - normal playback is functional - flash and remainder of camera is fucntional - basically - I paoint at an object to take the shot - yet nothing in the screen is displayed - picture shoots but the picture is the same - a black screen - with no photo - it seems like the internal part of the camera - it's eyes are closed. Any help out there?
  • Anonymous May 26, 2008
    weher you press the buton well that butun and the zoomer fell out so im triyng to get that bake in.
  • Anonymous May 27, 2008
    SONY CYBER-SHOT W-80
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on May 26, 2008
  • CameraR
    CameraR May 26, 2008
    It takes about 10 to 14 days from the day you ship it to receive the repaired camera back.
Can you please tell me how to delete individual frames without deleting everything. I have had a bad experience and don't want to repeat it. I can't find my manual....Thanks
Video clip cutting (extracting)
Display the video clip from which you wish to extract a segment.
Display the NORMAL Mode
Playback Menu (page 37), select
"EDIT VIDEO, and press the
button.
Select CUT!! and press the SET
button.
The Cutting Screen appears.
Specify the start point of the extract.
Use the procedure below to specify the frame from which the video clip extract will start.
• Play the video clip until approximately the desired point, pause the video clip, then play the video clip one frame at a time, stopping at
start point of the extract. This will be the first frame of the extract.
• If the start point of the video clip is also the start point of the extract, proceed to step 5.
Play:
After pausing playback, press and hold the SET button to the right
about 2 seconds for forward playback, or to the left for reverse playback.
Pause:
During playback, press the SET button.
Accelerated playback:
During playback, toggle the SET button to the left or right to change the playback speed.
Single frame:
After pausing playback, toggle the SET button to the right to move forward one frame, or to the left to move back one frame.
5
Toggle the SET button up.
• The start point of the video clip
extract is set, and the screen
•Specify the end point of the
extract by following the same
procedure as in step 5.
a. Toggle the SET button down.
Each time the SET button
toggled down, the sections
delete and the sections to
save are reversed.
b. Specify the end point of the extract. The frame following
end point of the extract will
the start point of the latter portion to be joined.
6
Press the VIDEO CAMERA button.
A screen appears for you to select either to save the edited video clip as a new (separate) file, or to delete the original video clip and replace it with the edited video clip.
SAVE AS NEW:
The edited video clip will be saved as a new file. The original video clip remains unchanged.
OVERWRITE:
The original video clip will be deleted. Only the edited video clip will be saved.
REVIEW CLIP:
Play back the edited video clip before saving it.
7
Select the desired option, and press the SET button.
• Editing starts.
• When editing ends, you are returned to the NORMAL Mode Playback
Menu.
I think this is what you are after if this isn't what you need you can find the manual at
http://www.retrevo.com/support/Sanyo-VPC-CG9-Camcorders-manual/id/18378dj397/t/2/
Jun 17, 2011 | Sanyo Xacti VPC-CG9 Digital Camera
SONY DSC-T1 CAMERA WHEN TURNED ON PREVIOS PICTURE SHOW UP FINE ON THE VIEW SCREEN BUT WHEN THE THE SELECT MODE SWITCH IS MOVED TO EITHER TAKE A NEW PICTURE OR TO MOVIE MODE THE VIEW SCREEN IS MOSTALLY...
Based on the information you've provided it seems that the CCD Image Sensor of the Camera is affected. If the CCD Image Sensor is affected, the images captured may be discolored or with lines on it. Even if the CCD is affected, the previously captured images and icons of the Camera will display normally. You may try power resetting the Camera.
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
Also try resetting the Camera back to factory default: The RESET button is located at the lower right side of the control button. To reset the camera just press the RESET button using a sharp-pointed object.
If the issue remains the same, then service may be required.
Thanks for using FixYa.
Mar 01, 2011 | Cameras
How to turn off "highlight" image display on D-80
This happens when you accidentally press the up or down button when viewing images on the playback. If you press up or down a few times it goes to a screen that looks like normal playback but with the flashing highlights.
All you need to do is press up or down until it goes back to the normal screen.
Hope that helps!
Dec 25, 2008 | Nikon D80 Digital Camera with 18-135mm...
Camera turns on, but no screen visual
You may have accidentally hit the DISP button on the back of your camera. This button manually turns the screen on and off to save batteries. Turn on the camera and press it once to see if that corrects it.
Jun 26, 2008 | Canon PowerShot SX100 IS Digital Camera
I have a canon SD 580. When I playback the video clip it's always in fast forward mode and I can't play it normal speed. Any help?
Make sure you are shooting your movies in "Standard" mode. If you have the mode set to something else, especially "Time Lapse", the playback may not match 'natural' motion.
In any case, you can control the speed of the playback. When you first enter the movie playback mode, there should be a movie control bar along the bottom of the LCD. Instead of the "Play" button, select the "Slow Motion Playback" button (single arrow with single bar next to the normal Play button), and control the speed with the left or right arrows on the multi-controller.
May 02, 2008 | Cameras
Balnk white screeen on my A610 powershot
unfortunately since the problem is on the hardware (lcd screen), there is no way of fixing it except from the people of the service center.
Jan 14, 2008 | Canon PowerShot A530 Digital Camera
No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Dec 23, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
Canon Powershot A70
There is a button on the back that can be pressed called Disp. (stands for Display). There are two or three settings it flips through each time you press the button. Press this button a few times to cycle through the choices in each of the playback and camera mode to see if this resolves your issue. Happy snapping...
Nov 23, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
No visual when I turn the camera on
This may seem crazy, but any chance you pushed the display button by accident? This toggles the screen on/off.
Aug 22, 2007 | Canon PowerShot A710 IS Digital Camera
Canon PowerShot A75 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
