Question about Amtrol ST-5-C THERM-X-TROL ASME Expansion Tank, 2 Gallon
My Amtrol Therm-x-trol tank has dropped 6 to 8 inches since it was installed, and a few drops of water are coming from the washer where is attached to the water heater. It is very heavy now. Could it be full of water and need to be drained. If so, how do I go about draining it.
Sounds like the internal diaphragm has ruptured. The tank should be replaced immediately. You should disconnect the electrical power to the water heater and close off the incoming water supply to the heater. Open a HW faucet to relieve the pressure and remove the tank. Be careful cause you are going to get wet. Replace with a new tank.
Posted on Oct 01, 2010
Amtrol them-x trol drum is leaking from top egde.I like to know how ti fix
Once these start to leak, usually the best solution is to replace the tank. It is corroding and will only corrode more with time. You could try epoxy for a short term fix, something like liquid metal.
Apr 18, 2011 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
My A.O. Smith 8 year old water heater drips water out of the expansion valve but only when it is heating water. The builder of my home mounted the Amtrol THERM-X-TROL ST-5 in the horizontal position and I...
It seems that you have this figured. In their literature all units are shown vertical, either inlet up or inlet down. Also, it appears that if the unit is full of water, (water logged) pressure will build up in the system. Temporarily, you could shut off water to the water heater, open some drains and use a pump to put some air back into the tank. This would at least get air into the upper half of the tank for a while until you can get set to make a repair.
Gary
Dec 14, 2010 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
I am loosing water pressure in my shower so I checked pressure at my ST-12 Therm-X-Trol tank hoping it would be 40 but water comes out of the test point and if you tap the tank it feels like it is full of...
you are correct....the rubber bladder inside the tank has leaked by and filled the expansion tank. it will need to be replaced and you also may find boiler or water heater relief valves may blow off until its replaced
Oct 21, 2010 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
Lots of water on basement floor at pressure tank.
sounds like the bladder tank at the well is ruptured this will cause pressure surge, and pump short cycling, and needs to be replaced asap.
Mar 28, 2010 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
Short buzzing noise every few seconds from hotwater tank
it maybe that there is a small leak at the connection.try to remove the tank and put teflon tape on the connection.this may fix the problem.if this does not fix the problem,it may be possable that the amtrol has a pin hole in it.this may hve to be replaced.good luck with your project
Sep 29, 2009 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
ER3 no hot water
Er3 means that the water is being heated for more than 1 hour without reaching the set temperature.
Need new aquastat.
Sep 28, 2009 | Amtrol ST-120V-C THERM-X-TROL ASME...
How do I change a amtrol thermal expansion take, Is it as easy to unscrew and put the new one after shutting of the water supply
Yes. After attaching the new one,check air preasure with a tire gage to match the recomandation that come with the tank.
Feb 23, 2009 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
Amtrol ST-5-C THERM-X-TROL ASME Expansion Tank, 2 Gallon  Logo
158 people viewed this question
Top Amtrol Water Heaters Experts
Paul Carew
rayc588
Level 1 Expert
Are you an Amtrol Water Heater Expert? Answer questions, earn points and help others
