Question about Electrolux Refrigerators
Hi, Can you give me the overall dimensions of an Electrolux RM 2310 Gas/ Electric Fridge for caravan, and the recess dimensions it would require for installation. Or, whether a Dometic RM2350 Gas/Electric Fridge has the same recess dimensions. Thank you, Linda
SOURCE: we have caravan electrolux rm
Problem is either thermostat or heating element...not sure which yet..but found website supplying most usable parts for RM series fridges. Hope this link is of use.
http://www.leisureshopdirect.com
http://www.leisureshopdirect.com/caravan/ventilation/Dometic-Electrolux_Spares$$6.aspx
Posted on Jul 08, 2008
SOURCE: Electrolux RM 4270 caravan fridge
Thankyou for your assistance, but i found the solution with electrolux direct.
Hope to use your site again sometime.
Posted on Aug 05, 2008
  • 68 Answers
SOURCE: My electrolux rm 2310 has stoped working (the beer
Classicpark;
The cooling unit has lost it's ammonia/hydrogen. Need to replace cooling unit or entire fridge. Prices for repair are as follows.
Part# 2934334091 $ 482.67 New 2 hour install
Replacement fridge RM2354RB $844.00 1 Hour install The R means right hand door. If the is a left you will need an L hinge kit. $27.00 plus .5 hours install.
Rebuilt cooling unit $400.00 2 hour install
All prices do not include shipping.
I know someone that will supply you with what you need.
Post back and I will give you the link.
Thanks for using Fixya
Jerry
Posted on Mar 27, 2009
SOURCE: dometic rm 2310 on gaz only the freezer work but
we put the camper on level tank you we resolve the problem
Posted on Aug 20, 2009
  • 5370 Answers
SOURCE: dometic rm2350 - cooling in
Corrosion can form between the pipes and the fins inside the fridge.And this causes the problem. -------------- If you are a bit of a handyman,turn off the gas and take the bottom outside vent off and remove the whole burner assembly at the base of the fridge. There is a metal cover that shields the burner but It is fairly straight forward, just be careful once the burner assembly is removed to NOT loose the gas jet that is a little dome like cone inside the end where the gas pipe goes in.
Carefully clean the jet with metho solvent to unblock the jet orifice.And do not poke anything in the tiny jet hole.Then try if it works and cools properly on gas.More that likely the control board has gone bad or the thermostat quit working. You might have to try and light this on gas several times to finally get it to go, if there is any air in the line it won't light and the air must be purged. This can take several minutes of continuous trying to get it to light. When it kicks off switch from gas to off and back to gas again till it lights. Have you checked the thermocouple that lets the control board know that there is fire in the pilot? If this is bad it won;t kick the main gas valve on. You can check these with a volt ohm meter, when there is fire on the thermocouple you will get a small voltage reading in the mil amps portion on the tester, no reading means bad thermocouple. Check the fuses on the circuit board under the cover I mentioned on the back of the fridge. You should have access through a door on the outside of the coach.---------------- If not then Do a direct test on the cooling unit. You will first need to locate the 110Volt heating element on the rear of the refrigerator. It is located in the tin stack on the right hand side. After locating these two wires, you must plug them in to a 110 Volt source. You can do so by cutting an old extension cord and splicing the wires to to the heating element wires, then plug the extension cord in. This will by pass the thermostat and run your cooling system wide open. If your refrigerator works in a direct test then the problem is your thermostat. But if still not running then problem is with mother board(the main board of the unit).Also, you can replace the OEM electronic motherboard with a better made 3rd party board made by Dinosaur Electronics, who make quality replacement boards for less cost then original. They are not difficult to install.As you mentioned its not cooling the fridge on any 3 way source,this indicates board problem.------------------ This should help.Thanks.Helpmech.
Posted on Feb 01, 2011
Dometic RM 4224 won't cool on gas or electric. The stack in the back gets super hot, the fridge is not cool at all.
First ensure that the fridge is level. If the fridge is level and still not cooling while there is heat on the rear of the fridge, then you will require a replacement cooling unit. Give Arcticold a call 1-888-782-6665 Web site: ArctiCold Refrigeration We keep it cold
Online Store: http://www.rvfridgerepair.com/
Aug 22, 2013 | Dometic Refrigerators
Hi, we have a caravan which has an electrolux RM360 gas/electric fridge installed. There is a very weird smell coming out when the fridge is turned on. Its like an ammonia smell it is really strong,
Travel refrigerators use an ammonia coolant instead of freon. So the smell is telling you that you have a leak in the sealed system.
Suggest you look for a replacement fridge OR a rebuilt unit because that is usually cheaper than taking it to a service center for repairs.
Jan 25, 2012 | Electrolux Refrigerators
I NEED A USER MANUAL FOR ELECTROLUX GAS FRIDGE IN MOTOR HOME. MODEL IS RM 2260 AND PRODUCT NO. IS 9215430-01. GAS IGNITION SYSTEM NOT WORKING - THANKS FOR ANY HELP JAMES GREIG SMITH
Hello, here is the manual: -
http://web.me.com/danperkinsartwork/Autohomes-Bedouin/Manuals_files/Electrolux%20RM2260%20operating%20and%20instalation%20instructions.pdf
Also found this site with a list of parts for the fridge you mentioned
http://www.leisureshopdirect.com/Caravan/ventilation/Dometic_Caravan_Fridge_Spares/Dometic_RM2260_Fridge_Spare_Parts.aspx
Hope this helps, good luck
Aug 04, 2011 | Electrolux Refrigerators
I have a 2453 150 litre caravan fridge not working on 240 but works on gas. What maybe the problem and can i get a mobile repairer
It sounds like the electric heater is not working as you say it works on gas, so the expensive bit is OK.
An appliance engineer should be able to get the spares and fix it.
Mar 07, 2011 | Microwave Ovens
Electrolux fridge in my caravan will run on gas,
Hi it sounds time to pull it out and give the ignition box a good blow out to remove dust and cobwebs. Also remove the jet in the supply pipe where it screws on to burner box. Just wash and clean it dont poke anything in the jet hole. Graham
May 13, 2010 | Refrigerators
My electrolux rm 2310 has stoped working (the beer is getting warm). When used in all 3 modes there is a strong smell of amonia. What do I need to do to fix this? What should it cost to fix?
Classicpark;
Jerry
Mar 26, 2009 | Electrolux Refrigerators
Aug 04, 2008 | Refrigerators
We have caravan electrolux rm 4230 light is on for 240 chilling, but fridge does not cool. appliance does however cool fine on gas.
Jul 05, 2008 | Electrolux Refrigerators
Refrigerators Logo
313 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
