Question about Verbatim 500GB USB Desktop 500 GB Hard Drive
I'm Windows XP... I can copy many files to the Verbatim. But when I try to copy a 1GB+ file, the copy craps out. I Googled and found some Microsoft problem when copying 1GB+ files to external drives, but I didn't see a solution.. Any ideas! Thanks
    Brigadier General:
  • 10,406 Answers
The usual limit is exactly 2GB, not 1GB.
It's a limitation of the file-system used for the directory of the disk-drive, when formatted according to the 'FAT32' specifications.
So, copy all the files currently on the Verbatim to your disk-drive.
Then, "reformat" the external (not the "internal") disk-drive, using the 'NTFS' file-system. This file-system has a maximum-file-size limitation for one file that is _much_ larger than the capacity of your Verbatim.
Then, copy all the "saved" files back onto the Verbatim.
Finally, copy your "large" files onto the Verbatim.
Posted on Sep 30, 2010
Usb drive use
Most thumb drives are used like floppy or rewritable optical discs (excluding ReadyBoost and the bootable versions). They are most often formatted as FAT drives (under Windows). If the drive is good and the USB port is good, plugging the drive into the computer's port should trigger a "new hardware found" message from Windows.
In Windows, open My Computer or Computer (depending on the OS) and you will see it listed under Drives with Removable Storage. You can use the file explorer to navigate through your regular drive and copy files to the thumb drive or the reverse. (I usually open two different windows and drag the files with a right-click then select Copy.) Synch programs can let you keep the thumb drive and hard disc copy at the same version. Alternatively, you can save a file directly from the program that you are usng to edit the material. (File > Save As and chose the destination). You can also open the file from the thumb drive in a similar mode. To avoid lost data, always select the Safely Remove Hardware from the taskbar (or Eject from the File Explorer) before unplugging the drive from the port.
The biggest problem is that the FAT formatting limits the number of files you can put on the disc unless you keep them in folders. (The same number of folders can be in the home directory as files without using folders.)
Bootable thumb drives (as well as those that can run software directly from the USB drive) come with software that lets them do this. Then they act like any optical disc with Autorun and executable programs. Readyboost is dealt with completely by the OS and keeps the drive (or portion of the drive) separate from the area that will store files.
Sometimes these drives do fail. Getting the data off the flash memory takes a professional most of the time.
I hope this helps.
(You can copy all of the files from the thumb drive and reformat it at intervals. Then copy files back if you are concerned about file fragmentation.)
Jul 24, 2010 | Verbatim VER95327 USB Hard Drive
I am a victim of software counterfeiting.my windows did not pass windows genuine validation.
This means that the version of Windows XP you are using is not a genuine copy.
This happens when you install a copy of Windows XP which does not match the serial key you used for installing.
Your Operating System (OS) has been blocked.
I advise you to immediately remove this copy of Windows XP by installing a genuine copy.
You can either buy a genuine copy or borrow a genuine copy from a friend and install.
You can use a copy which has already been installed on another pc and you will not have any problems as long as it is a genuine copy.
Jan 07, 2010 | Microsoft Windows XP Professional With...
Verbatim USB 8GB file copy problem
ITS virus problem which is playing with the inf file of the usb drive.
also another possibility is 1) the usb port ihas loose connections and disconnects i between drive sensing
2) certain 8 gb drives go back to a capacity of 2 gb drive if one formats it accidentally .
Sep 18, 2009 | Verbatim STORE-N-GO (95312) 8 GB Hard...
I have a 1GB file that is corrupted and I want to fix it?
The best way to solve this issue is by
formatting the pen drive.
thanks..
Feb 01, 2009 | Microsoft Windows XP Home Edition
Windows XP winsrv.dll file won't install
hi bcookie11,
if your windows xp installer is a legitimate one, return it and ask for another copy, sometimes, the cd is faulty, that is why you can't copy some files from it.
Jun 19, 2008 | Microsoft Windows XP Home Edition
XP upgrade to Vista install error code 0x800705AA
This error is something to do with the "Product Key" I think I have Googled this error and this is what shows up the most? I googled ... vista install error code 0x800705AA .... so perhaps ya can follow up in this vien... Good Luck
Feb 08, 2008 | Microsoft Windows Vista Ultimate Edition
Verbatim flash drive
try copying the files to a subfolder. The FAT file system has a limit of how many files & file name characters you can store in the root folder.
Oct 31, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Verbatim 500GB USB Desktop 500 GB Hard Drive Logo
464 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Computer Links
Marcin
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
