Question about Kenmore Oasis HE 27062 Top Load Washer
After the machine is going on any cycle for approximately 1 minute, and "F" appears and the washing machine stops. Is there a reset switch or does this require a service visit?
    Sergeant:
    Champion:
  • 351 Answers
I don't have code for kenmore.is it getting water i
Posted on Sep 30, 2010
Hi I also have the cabrio wtw5500xw0. It flashes sensing, wash, done as the code. In normal cycle it will wash not rinse or spin. Sometimes I can get it to spin in the drain and spin cycle. Thanks
There are several ways to fix a machine that will not spin or drain:
Step 1: Perform a master reset
This is the first thing a person should try. Unplug the washing machine, and leave it this way for about 1 minute. Plug the machine back in, and close the machine door six times in 12 seconds to send a message to the computer to reset everything. It may not work on all washing machines, so consult the repair guide to see if it will work for this particular machine.
Step 2: Fix the lid switch
If the lid switch has become defective, it is necessary to remove it from the machine. Consult the machine's repair guide to see where it is located and how to take it out. See if the switch works when it is used to open and close the machine door. If it does not, the lid switch needs to be replaced.
Step 3: Check the water level control if the machine isn't spinning
Open the control panel, and look for the water level valve. If the plastic tube attached to it appears clogged, vinegar can clear it up. If the switch itself appears corroded, it may be necessary to replace it.
Nov 16, 2016 | Washing Machines
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    How do I stop my Hotpoint washing machine WMF740 which has been going for 7hours and is stuck on 1 minute
    Is there a way to manually advance the cycle or is it all digital control panel? Do you see a reset button anywhere? Check the link I'm sending you on the manual.
    Hotpoint Washing Machine Instructions For Use ManualsOnline com
    Nov 24, 2014 | Hotpoint Washing Machines
    Washer stops during normal wash cycle for a minute or more, and then continues. Would replacing the timer fix it?
    If it actually goes on and finishes the cycle and that really bothers you replace it. If not leave it alone and allow a little more time to complete its cycle. The lid switch only keeps the spin cycle from going with the top open.
    May 23, 2014 | Whirlpool Washing Machines
    How to approximate a soak cycle?
    no need just hit the pause or cancel button after 4 hours push the start and your good to go
    Jan 18, 2014 | Ariston Technologies AL128D Margherita...
    LG dishwasher model LDF6920WW 1 1/2 years old approximately. Suddenly stops a minute or so into cycle (it drains remaining water and fills with new water then get LE error). When I open the door at the...
    The manufacturer has assigned this error or fault code to indicate a problem with the water circulation pump motor. Turn the appliance off for 30 minutes to allow it to cool. Then, restart the cycle. If the error code returns check the wiring to the pump motor. Also, if the wash impeller is broken this error can appear. If the impeller and wire harness check out, and the code keeps returning, you will probably need to replace the pump and motor assembly.
    Aug 06, 2017 | Dishwashers
    GE dishwasher with tactile board. Worked fine until special fingers caused issue? Now only the CANCEL and timer light-up when CANCEL pressed. Pump runs to drain for 2 minutes. Stops. NOTHING. Dont see...
    This should help: PDW8000 series: press the resetbutton once. This will cancel the washing cycle and pump the water out of themachine. PDW9000 series: open the door aninch and wait for the machine to stop. Touch the reset button to cancel thewashing cycle and reboot the panel.
    According to the GE Owner's Manual for the PDW9000 series only: If the"start/reset" light is flashing, close the door until the water pumpsout (this takes approximately 2 minutes) and the light stops flashing. When thelight stops flashing, the dishwasher can be reprogrammed and restarted. If the machine is unresponsive, killthe power to the machine by turning it off on the wall switch (if applicable)or turning the circuit breaker off. Leave the power off for 30 seconds,then turn the power back on. If thatdoes not work here is the repair info: Get into the service mode by pressingkeypads #8 and #4 for 3 seconds. Then reset from service mode. LINK to SCHEMATIC
    Mar 28, 2011 | Dishwashers
    Hi, my switch keeps going around and around without stopping
    Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
    regards
    Michelle
    Jan 24, 2009 | Indesit W 123 Front Load Washer
    Open Questions:
    See all Kenmore Oasis HE 27062 Top Load Washer Questions
    Kenmore Oasis HE 27062 Top Load Washer Logo
    27 people viewed this question
    Sal DeAngelo
    fordexpert
    Ed Mac
