Question about Sony CDX-F7710 Car Audio Stereo CD MP3 Player Flip-down detachable aluminium CD Player
Player will not come back on after about 1 year of good service, only shows a speaker with an x across it, wont come on , take a cd or anything.
  • 1badvw Oct 01, 2010
    thanks anyway, weve installed another unit and all is working fine so the unit is in need of repair i would also say. thanks again
    President:
  • Sony Master
  • 1,114 Answers
You have a shorted speaker wire and the unit is protecting itself from damage. Fastest way to confirm is to disconnect the speakers at the unit. If it powers back up, add 1 speaker at a time back on. it will cut back out when you find the bad wire or shorted speaker. If you still have an issue, post a comment and I can help you further.
Posted on Sep 30, 2010
  • 1badvw Sep 30, 2010
    has problem even wit speakers disconnected at unit.
  • Frank Fulton
    Frank Fulton Sep 30, 2010
    Then you will need to get it to a shop and have it bench tested, More than likely it has an output IC chip problem. Get an estimate first. Sorry for the bad news!
My cd player wont take cd
CD players do a little POST before they show you the disc contents. The disc first spins up then the laser head skips across to read the index with is generally on the inside track near the center. If the CD doesn't spin or the head doesn't move the CD player will auto-eject the CD. I'd have that player serviced or replaced.
Jan 17, 2015 | 2004 Nissan Maxima
Speakers wont work
try going through the wirering.... that wont probably make it work but you got to start somewere to find your solution
Sep 03, 2012 | Pioneer DEH-P7600MP CD Player
Hi. Hope you can help me out here. Some1 is offering to sell me his NAD C521i CD player. Its been with him for 5 years. Is it wise to get it since it is already 5 years old (at least that i what the guy is...
This cd player sound great but have in mind it is fitted with NE5532 op amps in linedriver stage, but single trafo supply, and this player is a standard production line cd player. I owned one, i liked the NAD sound, and i think if you pay something like $100-$130 you will be happy. Also you ask if you shall be aware of something, in older nad cd player displays is sometimes defect, but easy to fix. Also the laser need to be adjusted often. (as in most cd players.)
Step from track 1 to the last traack fast and back to track 1 again, listen to music parts from track 1, track 4, track 10 track xx.
If the sounud is not choppy, if there are coming sound in both speakers and otherwise it sounds good then i think you can buy it without expecting major problems.
Oct 03, 2011 | NAD C521 CD Player
2004 Chevy Cavalier I have a regular stock radio that the display works, you can change the channel, work the CD player but there is no sound output.
To diagnose this you need to remove the cd player. Then check that the wiring looks good. Then check your speakers themselves. If this fails to find anything, you need to check the wiring to the speakers. Remove the harness from the back of the cd player. Now use a multimeter set to continuity test to probe the speaker wire at the harness and at the other end where the speaker is (with speaker unhooked). If there is continuity from pos. to pos. and neg. to neg. the wiring to the speakers is good. But if probing for instance the positive of the front left speaker at the harness and speaker area you notice both the wires down at the speaker have continuity, you have short circuited speaker wires. This would cause at least the speaker hooked to those wires to not work. It may even cause none to work. Check all the speaker wires for proper continuity. If you still don't find anything I would guess that you need a new cd player. I know that cavaliers had some sort of antitheft in the cd player but I'd assume if it was the problem the cd player would just not function at all.
Sep 19, 2011 | Car Audio & Video
LMy JVC CD player reads PROTECT across the screen even after resetting the cd player it still reads PROTECT, I'm so lost now because I don't have amps or anything attached just regular car...
Try checking your speakers and speaker wires for shorts and/or grounds. Make sure none of your speaker wires have any bare spots. If your speakers and speaker wires are fine, you may have a bad internal output ic inside of the deck.
Jul 14, 2011 | JVC AM FM CD DET FACE CAR STEREO
I have a panasonic cd player..CQ-DF602U and its shows a code across the screen CD-E1...what does this mean and it wont play cds
E1 = Disk is dirty, or is upside down. Also the disk may have a format that the player cannot read. If this occurs with all your disks, move to the next step.
Try one of those CD lens cleaning kits. They are just typically a CD with a little brush attached to the underside of the disk to try gently and wipe the lens. You could also try re-setting the whole deck by removing it from the dashboard. The jiggling might knock something back into place. (Don't forget to disconnect it first and make sure the power is off!).
If you still receive the error code or the cd ejects automatically briefly after being inserted, the head unit needs to be repaired or replaced.
Jun 20, 2011 | Car Audio & Video
I just got the aiwa cdc-x227 and the mute is on.how do you unmute it?
check for a logo that shows a speaker with a cross(X) across. just switch this back. this is also available on the remote. You could normally find this on the top side so as to mute easily when in a traffic junction. Check if this button is jammed. Also check if the display shows a mute , if not the sound reduction could be a different issue related to the audio output. check if any speaker connections are short, or speakers connections touching the body. Chek on the wiring once again with a multimeter , for any shorting, correct positve voltage and good ground. hope this helps. Good day
Jul 07, 2010 | Aiwa CDC-X227 CD Player
BEO2300 CD not playing and LH speaker inop
I am sorry that your cd player must have a weak laser output, the optiical headd is defective if you have tried to clean and not had any result. clean one again to confirm. Now the next thing you must do is to put your set on for another 24-48 hours. let the electronics within get charged up. try it out after 12 hours, 24 hours and so on. If this wont clear then your Cd optical needs a change. Now regarding your L channel , it is important to see if the speaker connections are tight if your L speaker works in the R side then the speaker is fine. if not check if your speaker is faulty and replace. if not check within the amp for a faulty L output amp circuit. I hope the set will power on after some time. Good day
Jun 26, 2010 | Electronics - Others
My Phase Linear CD PLayer was working in the morning then I got in the car hours later and everytime I put a cd in the screen read Error 1. So I took the face of the player off and blew in it. I put it...
only thing you can do is send it into the manufacture and pay them to fix something like that but it would be alot easier and cheaper to buy a new stereo.
Oct 27, 2008 | Car Audio & Video
Pm228
Make sure your power wire is secure. Do you get a display? Is the speaker wiring still good? Any corrosion around terminals at the back?
Feb 12, 2008 | Kenwood KDC-MP228 CD Player
62 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
