Question about Maytag MSD2454G Side by Side Refrigerator
How can i change a filter , I don't know where is it..
There might not b a filter but normally its under the doors in the front or in the back by the water inlet
Posted on Sep 30, 2010
I have a 1996 ford Taurus 24valve V6 oil is reading full..but oil light keeps coming on and has a slight knocking sound..don't know where to start
First off,when did you last change the oil? Did you change the filter?
Sounds like an oil pressure drop,or a serious engine problem.
If the oil could stand changing,go with a heavier viscosity,like 10W30 or 10W40 if necessary.
ALWAYS change the filter when the oil is changed. don-ohio (:^)
Sep 03, 2015 | Ford Cars & Trucks
If I don't change the filter on my Honda cbr F4.
you could tilt the bike over on its side at around 45degrees and remove without losing any oil
Jul 15, 2013 | Motorcycles
Alero shakes when idling
How about wires,coils,fuel filter,air filter.
May 06, 2013 | 2001 Oldsmobile Alero
Fuel filter 1996 buick 3800
Sounds more like a worn out fuel pump that binds up
The fuel filter if totally clogged, would drop pressure
& it would be slow to get from 20 to 50 mph,not the
problem I don't think.
You do not change parts to see if that will solve something
You surely know if the filter is over 4 years old
Your Exhaust Conveter if origninal ,problem or not
is totally shot,they only last 12 to 14 years.
You have to check the TPS Sensor & may other things
I hope you don't just go years until your break down,
because the car has been good to you
That makes diagnosing things more time consuming, as you
have no preventative maintenance history
l
I would have a fuel pressure gauge put on it
Aug 03, 2012 | Buick Park Avenue Cars & Trucks
Why is my 1995 3.4 liter 6 cylinder Pontiac firebird less fuel efficient than it was 2 months ago and how do i change the fuel pump
I don't know why its not fuel efficient. But the fuel pump is inside the fuel tank. you should not attempt to replace it yourself, and don't change it on a whim. prove that's its bad, its an expensive guess.
Aug 26, 2011 | 1995 Pontiac Firebird
What part number for the filter
call your auto parts store, we don't know if it's the air filter, fuel filter, oil filter, cabin filter, pvc system filter, transmission filter, p/s filter, don't know what kind of car, size of engine, need to know more information that I NEED A FILTER.
Jun 24, 2011 | Chevrolet Impala Cars & Trucks
Check engine light came on and car has trouble starting then when it starts and i take off it keeps jerking like it doesnt want to change gears
This could be as simple as replacing the fuel filter, when last time had service? Not oil change, slot of times if you don't make sure on oil change , places will only replace oil filter. I would change fuel filter and possibly air filter. Let me know, and bynthe way, fuel filter is cheap, there under 15 bucks most likely at napa, schucks , etc... Dealer a lot more $$ let me know, glad to help more if that does not solve issue, mike
Jun 08, 2011 | 2004 Dodge Neon
Describe what is needed for a tune up, 165000 miles on it and never has had plugs, etc. replaced!
For the plugs- use A/C Delco 41-103 Our I6 engine loves these, a little more per plug, but will idle better than other brands.
Air Filter
Fuel Filter
Clean your throttle body (you'll notice the biggest difference with a clean throttle body).
Transmission flush and change the filter (Use GM's new Dextron 6, it's used in all 2010 vehicles and newer now, supposedly a big improvement over the Dextron 3)
Differential oil should be changed
If 4x4, and you use it a lot, change the transfer case fluid also.
Check your serpentine belt and replace if needed.
With that many miles on it (yeah I should be talking 180k on mine!) you should check out all your bushings. If you are hearing any sounds or squeaks, let me know, I know what they are.
I wouldn't worry about your timing chain, ours is bullet proof, don't know any TB owners that have needed to change them, even at 200k +.
These are just the basics, if you have any other questions, don't hesitate to ask me. Good luck!
May 16, 2011 | 2005 Chevrolet TrailBlazer
Engine light on
Knowing what year, make and model would help, but... If there hasn't been a change in how the auto is running, you don't really have to feel it's a four alarm fire to get it to a shop. Don't fuel the auto while it's running, this will cause the light to come on too. Disconnect the ground on your battery and that should reset the computer, this doesn't always work for newer models. Have you serviced the auto; change oil, air filter(s), fuel filter? Not doing those can cause lots of issues too.
May 01, 2011 | Chevrolet Impala Cars & Trucks
Pls i need to know where is transmision oil filter and fuel filter to change them car don,t run more than 30 miles, i,ve changed speed out sensor thanks in advance
The fuel filter is located just below and to the right of the master brake cylinder. You may need to remove the air cleaner assembly to get to it.
The 2001 Elantra does not have a transmission filter. Previous years had a spin-on filter on the top of the transmission.
Jan 02, 2010 | 2001 Hyundai Elantra
Maytag MSD2454G Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
