Question about Intel Motherboard
Looking for motherboard diagram for model of GA-81945GMH-RH. I got problem to connect "power SW" and " reset SW ". I appreciate your help.
    President:
  • 2,992 Answers
You can download the whole manual for this board from Gigabyte here. Here is the front panel connector page from the manual:
Hope this helps. Thanks for using Fixya!
Posted on Sep 30, 2010
    Brigadier General:
  • 10,406 Answers
Take a magnifying-glass and a strong flashlight, and take a close look at the silk-screening labelling near that "grid" of pins.
Look for 'PWR' or 'PWR SW', and for 'RST' or 'RST SW',
and for "outlines" around 2 pins.
Or, access 'www.gigabyte.com' and search for your model-number, and download the picture of the motherboard, or the PDF-version of the manual for your motherboard.
4 Suggested Answers
SOURCE: Intel D845WN motherboard
www.premioinc.com/pc/manuals/mb/845si/845si.pdf page 95.
Posted on Oct 06, 2007
ljisdi
  • 24 Answers
SOURCE: power sw, reset sw, HDD led motherboard connectors
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
97
Posted on Mar 13, 2009
How to connect wires power Led+ & power Led-, Hdd LED, Reset SW, power SW in Gigabyte GA-81865GME-775 Dual Core Motherboard
You can download a manual from this WEB site.
http://freemanualonline.blogspot.com/2011/04/gigabyte-ga-8i865gme-775-rh-manual-user.html
Jul 09, 2011 | Computers & Internet
I have a GA-81865GME-775-RH motherboard, which i put into my box, made all the connections, but have no power once I switch the box on. I suspect it has something to do with the wiring loom running from...
Hello julian_ad681
I will tell you how wire your case front panel, but before that lets test the motherboard to make sure the problem is not the board itself.
Remove all the wire connections to the front panel.
Turn the power on and with a small screw driver or anything that is metal short (touch) the two pins that are the PWR SW. (look at the list of pins I have put at the end)
If the computer turns on then it means the board is ok.
The following information is also availabe in the motherboard manual available from the gogabyte web site download section
On the motherboard next to the battery is the front panel header pins. it looks like
0 0 0 0 0 0 0 0 i also write them as numbers as well to make it easy for you)
0 0 0 0 0
1 2 3 4 0 0 0 0
5 6 7 8
1 and 2 are message LED. you don't need any connection to this.
3 and 4 are the power switch connections no polarity, just connect the wires
5 and 6 are the hard disk LED. 5 is the positive side (usually red)
7 and 8 are the reset switch. no polarity, just connect the wires.
Next to the message LED there is a three pin connection. This is for the power LED.
hope this has helped you.
please leave comment, vote if the helped
Feb 10, 2011 | Intel Motherboard
Please I need a picture or pictures of how you connect the cables from the cabinet in this motherboard GA-G31M-ES2L. the office that I'm trying to enjoy the positive it has entered a msg on the board and...
> HDD LED == hard-disk drive Light Emitting Diode (a "lamp" that lights-up when you are reading/writing files to/from your disk-drive)
> RST SW == the (optional) "reset" switch/button on the face-plate
> SPK == the internal PC loudspeaker
> PW SW == the power on/off switch/button on the face-plate
First, connect the "PWR SW", so that the ON/OFF button works.
It's much less important that the other wires be connected.
For example, if you never press the RESET button on the face-plate, you don't need to connect that button to the motherboard.
Oct 22, 2010 | Gigabyte GA-G31M-ES2L Motherboard
Hi.unfortunately I disconnected all wires from motherboard and on the end I have problem because I don't really know in which pin I should connect the power sw wire and reset sw wire
hi, heres a tip, you will need a diagram of your motherboard. if you have one, then you can start looking for the wires where it should be put. if none then you can search in the web for a diagram, you should know the exact model of your motherboard when searching for precise schematics.
Feb 23, 2010 | Computers & Internet
Configuring motherboard powerswitch leds reset
u will find front pannel connection pins on mother board. its in 2 lines. in onle row there is one pin slot idle. next to that vacant pin slot u insert reset sw, next to it insert hdd led, behind hdd led insert power led, next to power led (behind reset sw) insert power sw. thats it done
Jan 06, 2010 | Dell Dimension 2350 PC Desktop
Where are the places of each jack??
Below is a link to the Manual for this Motherboard. Page 24 contains a diagram of where to plug in the front side led's and switches..
http://www.gigabyte.com.tw/Support/Motherboard/Manual_DownloadFile.aspx?FileType=Manual&FileID=15447
Pick any location except for the American server, it doesn't seem to want to download properly.
There you go, thank you for choosing Fixya!
Mar 20, 2009 | Gigabyte GA-6OX Motherboard
Jumper connections
Is this your actual motherboard:
8VM533M-RZ (GA-8VM533M-RZ)
Thanks,sometimes our category selector isn't all that thorough and this is what I see regarding your motherboard.
The actual version is in the center of your motherboard.
Regards,
Worldvet
Aug 05, 2008 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Pinout diagram
Mail sent.
For anyone else.. Visit the motherboard's online manual via their website.
Nov 13, 2007 | Gigabyte GA-7IXE4 (GA-71XE4) Motherboard
Intel Motherboard Logo
1,835 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
