Question about Harman Kardon Audio Players & Recorders
My AVR1550 got power up with no sound at all. pls help. What should I check first.
    President:
  • Harman Kardon Master
  • 1,114 Answers
First thing to check is the speaker A/B switch on the front of the receiver. Generally a small button on the receiver. You will see A/B on the LCD display. Next, check your input selection for audio. This will be on the main setup menu. Choices should be Coax, Digital, Analog and Auto. Auto is the easiest. if you still have an issue,post a comment and I will help you dig further. Hope this helps
Posted on Sep 30, 2010
Hi I'm Wayne. Pls help me with my GA13DS engine
Check for a bad rocker arm and correct valve adjustment. Make sure cam timing is correct. Never try to retard or advance the cam timing.
May 16, 2017 | Cars & Trucks
I have to kick start my 2000 ducati st4 bought a new batt fully charged it thats not the prob although its sounds and acts like it now it just makes a ticking sound as if the batt was dead pls help
Check the terminals are clean and tight on the new battery
depending on where the ticking sound is coming from it could be the solenoid or the starter motor.
use a multi meter to check if power is getting to the starter motor when the buttons depressed.
If it gets power, could mean the starter needs brushes, if it doesnt get power more likely the solenoid is bad
Jun 06, 2011 | 2000 Ducati ST4
Our amplifare of model number-AVR1550 has a problem that when the power is switched on, within few seconds it gets switch off by its own
Try disconnecting the speaker wiring in the back of the unit, and then testing it. If it turns on and stays on without the speaker wiring disconnected, then reconnect one speaker at the time until the condition repeats itself, and then you'll be able to find the problem wire.
What's most likely happening is that one of the speaker wires has become shorted, either by being disconnected at the speaker end, or not being cleanly connected at the receiver's end. It happens all the time.
Oct 17, 2010 | Audio Players & Recorders
Lost sound on my home computer after kids were fiddling around. all speakers connected and powered on. pls help
plz check in device manger the sound driver is installed or not, if there is yellow question or explanation mark then you have to reinstall the driver for the sound, if there is no mark in the device manger then check the volume controller if it is muted. post back if required
Aug 06, 2010 | Dell Dimension 3100 PC Desktop
Sound not working
Please check that your audio cable from speaker to CPU is connected properly or not ,if not pls connect .If still sound not coming then pls check the sound card is enable or not in your system BIOS.If not pls enable it and login through administrator and check ,If still sound not coming then pls check the sound driver is installed or not if not pls install it and check .if still issue not resolved pls check your speaker is working or not by connect with another system.If still not resolved then problem with your sound card in the Mothaeboard get it repaired by Vendor.
Nov 16, 2009 | Acer Aspire™ T180 PC Desktop
No sound from the recevier
Hi there.It sounds like maybe a fuse on the main board is blown.You'll have to remove the top and investigate.If you find there is not bad fuse then the main circuit for sound control is blown.You can sometimes see them if you look at the top of the diodes and there not flat.They'll be bubble up.I hope this helps you..
Mar 31, 2009 | Harman Kardon AVR 210 Receiver
Sound card
hello sir,
board is energy p3 pls check ur soung card model, to check ur sound card model in run command type dxdiag.exe and check sound detail if u found ur sound card detail go to google page type ur model of sound card and download .
Thanks for calling to us have a nice day
Aug 02, 2008 | Computers & Internet
No picture
hi!
you can download the power dvd player.
because other computer you can play and hear the sound but no picture.
PS:
pls rate if is invaluable solution rate me fixya.
thx
May 22, 2008 | Toshiba SD-P1400 Portable DVD Player
Macbook NO sound
Sound settings are controlled in the System Preferences, have you checked there?
Feb 29, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Speaker has sound when powered .
Hi , open the control panel /select to classic view,select add hardware to locate some drivers cyber acoustics speaker just follow the instruction to connect the speaker.
check also the device maneger the connection of the device.
Jan 11, 2008 | Cyber Acoustics CA-3000 Computer Speakers
63 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
