Question about GE JVM1350BW/WW/AW/SY Microwave Oven
Need replacement handle for GE Profile Spacesaver # JVM1350BW 002
MicrowaveSvc
  • 9098 Answers
SOURCE: Instructions for replacing door handle on JVM1350BW02 Microwave
You may have to rotate and pull the handle once the top screw is removed.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 06, 2008
stonephoenix
  • 563 Answers
SOURCE: GE Profile Microwave will not heat
Unfortunately, there is no way to tell which part the microwave needs without opening it up for examination. There are a few parts that, if defective, would prevent the oven from heating.
  • a high voltage transformer which passes energy to the magnetron
  • a magnetron which converts high-voltage electric energy to microwave radiation
  • a magnetron control circuit (usually with a microcontroller)
This is NOT a repair that you would want to attempt yourself. The labor for the repair would cost a minimum of $50 and shouldn't exceed $100. You'll also have to pay for the necessary part if it's still available from the manufacture or their parts distributor.
Posted on Feb 04, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: jvm1350ww 002 Handle broken
The handle part number is WB15X335 and is available from a number of sources online. You can replace the handle alone, but you need to take the inside door panel off to get at the screws. It's been too long since I've worked on a GE to remember if you need any special tools (some ovens have security screws holding things together).
Posted on Apr 01, 2009
  • 10865 Answers
SOURCE: The door handle on my GE Profile ADvantium 120 Microwave is broke
You may consider using epoxy to "glue" the handle back into place. The epoxy will be stronger than the handle itself. If you do this get the one minute epoxy
Posted on Apr 27, 2009
jsrock516
  • 5911 Answers
SOURCE: replacing door handle on microwave ge profile
You will need to access the door handle mounting screws and remove them to replace the door handle. To access these screws on MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. This can be easily be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful microwaves.
With the inner panel removed, the door handle screws are visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
You can view an exploded view diagram of your microwave at pcappliancerepair.com for reference. Just type in your model number and locate the parts listing for the door. If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Nov 17, 2009
Problem with the GE JVM1350BW/WW/AW/SY Microwave Oven The handle broke off completely. Can it be replaced? Doesn't look like there is way to get back of door off to replace/repair handle.
The inner plastic ring has to be removed. That WIDE ring is called the choke. Use a flat bladed screwdriver and a knife blade to get it free. It has tabs on the inner side and the outside that have to be unlatched. Once the choke ring is free you will have access to the screws.
See this video:
Sep 24, 2011 | GE JVM1350BW/WW/AW/SY Microwave Oven
My GE Profile Spacemaker XL (JVM1350BW 002) microwave's fan runs when you open the door.
This is going to be related to one of the 3 door switches around the corner behind the control board. One of them is either burnt, shorted, or not being activated correctly.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 30, 2011 | Microwave Ovens
Ge Model JVM1350BW 002 turns on when door is closed or on it's own
If "F3" is appearing on the display, then you have shorted membrane keypad.
If this is the case, the keypad is no longer available and the oven would have to be scrapped.
Otherwise, I would suspect a bad door switch or door switch mount, which are usually pretty easy to fix. See our file here.
You can find links to helpful exploded view diagrams and other part ordering help here. Enter your model number as "JVM1350BW02".
I'd recommend that your bookmark this link to your favorites.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Once that's off, the switches are easy to get to.
Feb 09, 2010 | GE JVM1350BW/WW/AW/SY Microwave Oven
Need to replace handle on micro wave can not
I HAVE A GE PROFILE SPACESAVER 2.0 OVER THE RANGE MICRO WAVE, CRACKED HANDLE, WOULD LIKE TO KNOW HOW TO REMOVE HANDLE AND INSTALL NEW ONE.
Dec 18, 2009 | Jenn-Air M439 Microwave Oven
I have a GE Profile Spacemaker XL Sensor Mod # JVM 1350AW 02 Microwave oven. How do I replace the door assembly? Is there a danger of elecrical shock involved?
You're usually better off just replacing the bad parts instead of the whole door.
If so, you can separate the door panels (as shown in the attached photo) then you can replace separate parts.
You can't remove the handle without doing this.
You can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Oct 09, 2009 | GE JVM1350BW/WW/AW/SY Microwave Oven
Jvm1350ww 002 Handle broken
Apr 01, 2009 | GE JVM1350BW/WW/AW/SY Microwave Oven
GE Handle replacement
The handle is part number WB15X335 and you can find it online from several sources. You can replace the handle alone. You do have to remove the door inner panel to get to the handle screws.
Jan 27, 2009 | GE JVM1350BW/WW/AW/SY Microwave Oven
Sep 04, 2008 | GE JVM1350BW/WW/AW/SY Microwave Oven
GE JVM1350BW/WW/AW/SY Microwave Oven Logo
631 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
