Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
The control panel is cut off and the oven wont work but the eyes will work.
    Sergeant:
    Champion:
  • 351 Answers
Control bad
Posted on Sep 30, 2010
I have a stove built in oven and had a power cut and it keep flashing 8888 and wont work
Hi.
After power cuts most ovens need resetting, for this reason 00:00 is flashing. The operation is described in the specific model's user manual. Most ovens reset either pressing or holding down for few seconds a Clear or On button, or holding down the main control knob.
Aug 06, 2011 | Ovens
Both the bake and broil oven elements do not heat up / they are unresponsive. I can set the oven temp but on the control panel and it appears that everything is OK there I've replaced both elements and...
Must check the the voltage of 240 coming in to the oven sometime there is 120 volts which will light up the control panel but not enough to turn on the heat elements also check the wiring diagram some times there are cut off switches between the control panel and heat elements those can be bad too!
Appliancetek
www.astrepairs.com
Jan 14, 2011 | Ovens
On my viking oven i get a FO on the panel. The oven wont cut on.
hi
f0 error is either an E.C.R. (electronic range control) or that it is the keypad and it would probly be about 300 buuucks to fix
Jan 09, 2011 | Viking VGS0166 Stainless Steel Gas Single...
Amana AEW4530DDS cancel button the only button to beep or work on control panel. Time of day lights up. oven wont work . before oven went t/u had it on broil with the door open a bit. did this fry the...
A qualified technician needs to troubleshoot the unit and determine if the bubble-keypad has broken or the control board that 'controls' it. The control board would be my guess, and would also cost the most.
Mar 16, 2010 | Amana AEW4530DDS Electric Single Oven
One eye on my oven won't heat..could this be the fuse or element
This could be caused by the eye control switch,the eye itself is bad,or the electrical block where the eye itself plugs in.These can be checked with a volt/ohm meter.Also a wire could have burnt under the stove top.Hope this helps. Gregg
Jun 05, 2009 | Whirlpool RBS275PD Electric Single Oven
GE mod.JDS27G0P2BG Oven Wont start
You have a bad electronic control board.
No repair.
It must be replaced.
Feb 21, 2009 | GE Profile JTP18 Electric Single Oven
Whirlpool Double Oven RBD305 Display doesn't show, oven wont work
Most definitely a bad control board and/or soldered components. (The part about cutting power to the oven was a dead giveaway)
There are low and high temperature solders, but usually solder melts at 370° F. If the oven is improperly insulated or ventilated you will have continued heat stress to the control board.
Mar 31, 2017 | Whirlpool RBD305PD Electric Double Oven
Amana Convection Wall Oven Model AOCS3040 Does Not Heat in any Mode
sure its possible, sounds like you've blown an over limit thermostat behind stove, gets too hot and for safety reasons cuts off unit untill replaced
Feb 11, 2008 | Amana AOCS3040 Electric Single Oven
Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Dec 06, 2007 | Whirlpool RBD245PRS Stainless Steel Oven
AEGB1180-4 overheating/cutting out
It is not the control unit. Remove oven from housing, switch power off and remove either the top panel or the back of the oven You will see two wires going to a thermal overload cut out, looks likse a round thermostat. Join the 2 wires togther bypassing the toc, it will now work okay
Jul 09, 2007 | AEG B1180-4 Electric Single Oven
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
37 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
