Question about Kodak EasyShare M575 Digital Camera
Camera battery is dead .. plugged it in and light does not blink indicating chargering ? tried another computer as well as wall outlet.. it is m575 .. newly bought.. any suggestions...
Sorry i can't give a solution I have the same problem and I was wondering if you eventually found a solution?
Posted on Feb 09, 2011
  • Blah Blah Blah Sep 24, 2011
    I had the very same problem. I discovered that if I pushed on the battery and held it, the light would flash steadily indicating a charge. Apparently there were bad contacts between the battery and the camera.
    I put a wad of paper between the battery and its' cover, to force the battery in farther. So far the light is steadily flashing, indicating the battery is finally charging.
    What a poor way to work with a piece of new digital equipment the cost of this one and bearing the Kodak name.
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Charger not working
When the red light is on it is to indicate that the charger is getting power from the wall outlet. If there is a second light that normally comes on Green when charging pay close attention to it when you first plug the charger in. See if it blinks even once then turns off. If it does that means the charger is not seeing any battery voltage at the plug that goes into the chair. If the green light does not blink at all then it usually means the charger is defective. Also most wheelchair battery chargers will not charge the batteries if the chair is to dead to even turn on.
Apr 12, 2015 | Health & Beauty
Light does not flash when charging battery
Please try this:
1) Make sure camera is OFF.
2) Plug Charger into the wall (not into camera)
3) Last think plug charger into the camera
Oct 15, 2014 | Nikon Coolpix S3000 Digital Camera
My Kodak Easyshare M575 digital camera will not turn on. It turns on okay without the battery while plugged to an electrical outlet. I've tried charging the battery and that doesn't work. The...
If unused for any length of time, rechargeable batteries lose their ability to retain a charge. Try it with a brand new, fully-charged battery. FWIW, I recharge all my camera and flashgun batteries monthly.
Nov 07, 2017 | Kodak EasyShare M575 Digital Camera
Bought a Nikon Coolpix S3000 (orange) for my daughter after Christmas. It just stopped working one day; wouldn't charge, no lights or come on. The battery it came with is a Nikon lithium ION Battery...
Read page 16 of the manual. Do not use any other charger with this camera. Are you sure you have the battery inserted correctly? When trying to charge, does the green light blink? If so, when it stops blinking and turns off, the battery should be fully charged. Do not attempt to turn the camera on while the charger is trying to charge the battery.
Aug 17, 2011 | Nikon Coolpix S3000 Digital Camera
My camera is a vivitar pink (MID0050609) and it wont turn on, unless i plug it it to my charger and when i do the light on the left is red and it just blinks then flash a blue screen turns on that says...
MSDC is not a problem code. It is normal, the camera is informing you that it's connected to a computer. At this point you should see a new "drive" show up in my computer to transfer pictures.
Have you tried turning the camera on when plugged into a wall charger? If it turns on using the wall charger it might need a charge over night. If the camera will still not turn on after a charge the battery is dead and needs to be replaced.
Mar 12, 2011 | Cameras
Re: Battery Charger BC-45W I just purchased a Fuji JZ500 and the battery needed to be charged. When I plugged the charger into the power outlet, the indicator light (yellow) turned on but after a few...
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Dec 23, 2010 | FUJIFILM BC45W Rapid Travel Battery...
On my camera the battery charger light is blinking and the battery is not charging
Before you get creative and directly plug your batter into an AC adapter, try something much easier first. I have the same problem with my Olympus 770SW batteries. As silly as it sounds, the charger will only work in a select few outlets in my house that I found by trial an error, actually pure frustration. I suggest, go around your house and plug the blinking charger in all the outlets and see if you find one that works. That sounds a lot less shocking than solution 1 and 2 now doesn't it? Good luck!
May 23, 2008 | Cameras
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Kodak EasyShare M575 Digital Camera Logo
114 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
