Question about Panasonic PT-52LCX65 44" HDTV
We started seeing some red, blue and green dots appear here and there, so we decided to replace the lamp. Now the TV has several blue green and red dots all over it, and white has turned yellow. Mainly when the program has a 'reflection' ...like on a boating scene the water is yellow, or when the sun reflects off a car. On some shows it changes the color completely and we can see the pixels shifting. What can we do?
  • shaun Aug 20, 2012
    DId you by any chance get your TV fixed yet?
    did you by any chance fix your TV?
  • Panasonic Master
  • 5,138 Answers
Replace optical block/light engine
Encompass Parts 1-800-638-3328
Posted on Sep 30, 2010
AFTER REPLACING THE LAMP, I HAD TO PUT THE COVER ON AND NOW THE SCREEN HAS TINY BLUE DOTS AND THE POWER LIGHT STAYS GREEN. THE LAMP LIGH IS NOW ON AND RED
The blue dots are due to a failing optic block. The lamp is only making them show up more obviously. The TV is probably failing as the blue dots will get larger and eventually take over the screen.
Sep 12, 2015 | Panasonic PT-61LCX65 61" Rear Projection...
My zenith tv model SR2075DT had this continous Red tint. I have tried fixing it through settings and NOTHING works. Someone please help me
It is likey the blue lamp has failed.
They are relatively cheap to replace and you can buy them online.
There are dangerous voltages inside the cabinet.
If you can see the lamps through any of the vents, you may be able to see the lamps. Check to see if blue or green are not working. There should be three separate lamps. Red Blue & Green. This is assuming the colour is like that on all sources.
If it is only on one source, check the component cables in the back of the TV.
Oct 20, 2013 | Televison & Video
Yellow to green tent screen to hitachi tv 42v715
You have some reason to believe it will not?
Some history for you---several years ago Hitachi began along with others to have issues with the optical light engines.
With a mix of high heat from a lamp into the engine (it has a blue,green and red section inside---guess what? BLUE is the first place that gets the heat and is damaged----minus blue and you have red and green which equals YELLOW.
Several of their sets made about 6 years ago (research 50v500) had exact same issues and were settled in a class action lawsuit.
The issue can but does not always affect the entire screen.
The question really is: This set really worth the part and labor cost for the repair?
On that earlier model I replaced under warranty over 40 of the engines. Also Sony and others have had similar issues some of which were settled in court.
HOPE IT WORKS OUT FOR YOU.
Jun 11, 2012 | Hitachi 42V715 42" HDTV
I have a sony kds 55A2000 and my lamp went out so i replaced it. and it startes up fan goes on and off . and tv shuts down light still blinks red? My optical block is getting a light green yellow tint but...
Lamp Fan should not cut off and on it should run at all times when TV is Turned on.Lamp Fan is designed to run when set is turned on to Keep Lamp Cool otherwise Lamp will burn up.
Yes Bad optical unit block could also cause set to shut down.But most of them will Play but with Dots,Green yellow tinit or Big blue Spots
Jun 23, 2011 | Sony KDS55A2000 55" HDTV
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
My screen has little dots appearing sometimes red sometimes blues behind the picture i just replaced the lamp bulb as i thought it would cure the problem
the projection tube needs to be adjust for color alignment, each tube (red, green, blue) must be aligned so you there would be no color smear appear on screen. if it is aligned try to set up the color balance, hue etc.
Feb 06, 2011 | Samsung Televison & Video
I have green and blue dots. Then at times the entire picture is Very red and blue like looking through 3d glasses. I replaced the lamp recently. There was a few dots before and they did not go away after...
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 22, 2010 | Televison & Video
Red, blue and green dots appear on screen like snow
ask ur service provider and ask him to change ur revolution or ask him to change ur sreen
May 21, 2009 | Philips 42PF5331 42 in. Plasma Television
Blue dots in KDF-60WF655
Yes, your optical block ( light engine) is bad. Heat generated by the lamp circuit with its poorly designed ventilation system, cause the LCD panels inside the light engine to fail. They are the size of a postage stamp. There are 3 LCDs, for red, blue, and green. The heat causes them to warp and de-laminate.
Sony has systematically downed played the scope of this issue. It appears however that virtually every LCD projector they make can develop damage in the light engine which is extremely expensive to fix.
I suggest contacting Sony and your state's attorney general's office of consumer complaints asking for action on this.
michtech
Feb 01, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Red & green lamps shutting off leaving a blue screen
Could you show a picture of the distended cover you mentioned?
Were the light blue lines you were referring to, diagonal, or truly horizontal?
Oct 15, 2007 | Sony KP-57WS500 57" Rear Projection...
Panasonic PT-52LCX65 44" HDTV Logo
251 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
