Question about HP Photosmart C3150 Printer
Need to open the c3150 to remove incorrectly inserted cartridge
  • HP Master
  • 5,165 Answers
With the unit on, open the cartridge door on the front below the scanner and above the paper tray. If the carriage doesn't move to the right, turn the printer off and then back on. When the carriage is on the right, press down lightly on the cartridge to release it and then pull it out. (I don't know if an improperly inserted cartridge will come out as easily but do not use a lot of force. Too much force could damage the carriage and you would need to replace the print head.)
If the carriage is not moving, check for foreign objects in the path.
I hope this helps.
Posted on Sep 30, 2010
The ink cartridges that were inserted can't be removed.
They will come out but you have to work at it. BTW, it's almost impossible to install them incorrectly.
Feb 28, 2014 | Epson WorkForce WF-2540 All-in-One Inkjet...
My hp photosmart c3150 just prints blank pages what do i do
Turn the printer on and off. Disconnect the usb connections and restart your PC.
Turn the printer on and try printing.
Check the cartridges.They maybe low on ink or even dry.
If the cartridges are fine,remove the black cartridge from its slot on the right and check its nozzles for damages.Make sure the plastic tape usually on it when new has been fully removed.Slide the cartridge back into the slot and push it forward till it clicks.Please do the same with the other cartridge.
Remember to replace any used cartridges.
Hope this helps.Thanks!
Oct 12, 2011 | HP Photosmart C3150 Printer
CANNOT INSERT A NEW INK CARTRIDGE- HOW DO I INSERT A NEW CARTRIDGE
Hi
I have put a PDF files on my website for you to download.
Hp C3180 Manual-C3100-C3110-C3125-C3135-C3140-C3150 -C3180.pdf
Just click on the links it will download for you.
It got all you need to know in this file,
Click LINK= http://www.4all2sell.com/pdf/Manual-C3100-C3110-C3125-C3135-C3140-C3150 -C3180.pdf
You will need adobe reader to see this file If you not got a Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Fills on my website are only there for a limited time and will be deleted Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 11, 2010 | HP Photosmart C3180 All-In-One InkJet...
Need to change cartridge but cannot open to reach
Your computer came with software that should be installed in your computer. Look for this software and there should be an option that will align the cartridges so you can replace the old one. If you do nota have this software installed, install it. If you do not have the CD with this software, download it from your printer's manufacturer site.
Aug 26, 2009 | HP Photosmart C3150 Printer
The printer tell me incert black printer cartidge in right stall. or photo cartidge. I've install the cartide but print does not reconized the installation.
HP Officejet 7200, 7300, and 7400 All-in-One Series - 'Incorrect Print Cartridge' or 'Insert Print Cartridge in...Stall' Message Displays on the All-in-One After Installing a Cartridge Issue After installing a cartridge, the error message Incorrect Print Cartridge or Insert [Black or Photo / Tri-color] print cartridge in [right / left] stall appears on the product control panel. Solution Follow these steps to resolve the issue. Step one: Remove, inspect, and reseat the cartridge The cartridge might not have full electrical contact with the product. Removing and reinstalling the cartridge might help. NOTE: HP cannot guarantee the quality of remanufactured or refilled cartridges. Use genuine HP cartridges to ensure good quality.
  1. Make sure that the product is turned on. NOTE: Press the power button (c00636182.gif ) to turn on the product.
  2. Open the product cover and wait until the carriage is idle and silent.
  3. Open the cartridge latch.
    1. Press down lightly on top of the latch.
    2. Pull out the bottom of the latch to unhook it.
  4. Slide the cartridge out and inspect it. Figure 1: Open the cartridge latch c00211535.gif Open the cartridge latch Figure 2: Slide out the cartridge c00211536.gif Slide out the cartridge CAUTION: Do not touch the copper electrical contacts or the ink nozzles. Figure 3: Copper electrical contacts and ink nozzles c00211537.gif 1 - Copper electrical contacts 2 - Ink nozzles Electrical contacts and ink nozzles
    1. Check the copper electrical contacts for debris. If any debris is evident, proceed to "Step two: Clean the cartridge and carriage contacts."
    2. Make sure that the clear nozzle protective tape has been removed. Figure 4: Remove the clear nozzle protective tape c00211538.gif 1 - The clear nozzle protective tape Remove the clear protective tape CAUTION: Do not try to remove the copper electrical strip.
    3. Look at the number on the cartridge label and make sure it is compatible with the product. Compatible cartridges are listed in the product user guide.
  5. If the cartridge is not compatible, obtain the correct cartridge, and then go to "Step five: Replace the cartridge." If the cartridge is compatible, reinstall it in the product:
    1. Hold the cartridge with the nozzles down and the copper electrical contacts facing the product, and then slide the cartridge into the carriage.
      • Cartridges marked with a triangle go into the left carriage slot.
      • Cartridges marked with a square or pentagon go into the right carriage slot.
      Figure 5: Insert the cartridge into the correct slot c00211539.jpg Insert the cartridge into the correct slot
    2. Push down on the cartridge latch until it snaps closed.
    Figure 6: Slide the cartridge c00211540.gif Slide the cartridge into the slot Figure 7: Close the latch c00211541.gif Close the cartridge latch
  6. Close the product cover.
If the issue continues, get back with me there is a few more options we can try. Have a good day
Jun 24, 2009 | HP Officejet 7210 All-In-One InkJet...
C3150 print cartridge
  • Remove the cartridges.
  • Turn off the printer.
  • If the cartridges are leaking, put the print head on some tissue, so it can extract the excess ink. With a dry cloth, clean your scanner. Look inside the printer. If there is ink in there too, clean it. Use a lot of tissue or toilet paper. Might put some gloves on too.
  • When you make sure that the cartridges are not leaking anymore, gently wipe the electric contacts on them, and clean the ones on the cartridge carrier.
  • Turn the printer on.
  • Try printing.
  • If the cartridge light keeps flashing:
  1. If a computer message indicates a specific cartridge, that is the problem cartridge.
  2. If there is no computer message, look at the Start Copy lights - if the Black Start Copy light is blinking, the cartridge on the right is the problem cartridge.
  3. If the Color Start Copy light is blinking, the cartridge on the left is the problem cartridge.
If you find out which cartridge is the problem, you will need to replace it.
Unfortunately, the ink that has leaked inside, might have damaged your printer.
Dec 31, 2008 | HP Photosmart C3150 Printer
HP C3150 error flashing....not printing!
You may have got a bad ink cartridge, I would try changing it again to see if that helps!!
Jun 19, 2008 | HP Photosmart C3150 Printer
Cartridge cradle stuck
Hey chips 53 Very simple, Go to the market and purchase a set of screw driver of long sleek neck (for star screw). and open the four screw present four different side in the printer. After open the screw, open that door, from where you insert the cartridge. insert your hand into the printer and lift the portion upside. Remember you have to lift equally (but slowly-slowly) if you see that the upper body is separating, you have to concentrate to lift the portion from right side because wires has been attached left side. After removing the upper portion you can easily move the carriage. And do what you want
Sep 12, 2007 | HP PSC 1610 All-In-One InkJet Printer
HP Photosmart C3150 Printer Logo
75 people viewed this question
Seeker5211
Seeker5211
