Question about Car APS997A Two-Way Remote Start and Security System
On my remote the unlock is the only thing that works. my lock and remote start doesnt work. everything used to work before i got my transmission fixed and when i got it back nothing worked and i have been messing with it and finally got the unlock to work but nothing else?
  • joekennedy84 Sep 30, 2010
    well thanks i didnt know how to program it. its getting closer but stll doesnt work. the lock still doesnt work, but the remote start is now makeing noises from the key set. but make the noise it used to make when it would shut off.
  • Audiovox Master
  • 625 Answers
You could try reprogramming the remote: ignition on, press and release programming switch 3 times, you will hear one chirp( channel 1),press the lock button, press and release the switch 1 time ( two chirps, channel 2), press the unlock button, press and release switch 1 time ( three chirps) press green remote start button,press and release switch 1 time ( 4 chirps) press option button. Turn ignition off. test. If this doesn't work, try disconnecting the unit's power for about ten seconds, then reconnect and test.
Posted on Sep 30, 2010
    thanks i didnt know how to reprogram it. it is getting closer but still is not working. the lock still does not work but the remote start is now making noises out of the keyless remote. exept it makes the noise it used to make when it would shut off.
  • Larry Spears
    Larry Spears Dec 01, 2010
    If the remote is making the noise that it normally make when shutting down, it will probably also say "inhibit" on the remote. You have two inhibit or shutdown wires. One is the brake and the other is the hood pin switch. If you had recent mechanical work, check the hood pin switch first. Try holding the hood pin switch down with one hand and remote starting the vehicle with the remote. If the vehicle starts, adjust the pin switch so that it makes contact with the hood when closed. If it's the brake shutdown wire, then the remote starter is reading 12 volts from that source. There could be a bad brake switch or it's connected to the wrong wire.
03 Lincoln Navigator - No Door Locks, Auto Lights - Already used process of elimination - missing something - Help!
Simple fix; bring the vehicle to the dealership and let them reprogram the system!
Feb 21, 2017 | Ford Cars & Trucks
Remote starts the car but doesnt unlock/lock doors
You must first get a bypass module to sync the factory with the afterm
Aug 08, 2014 | AviStart 4400 2-Way Security / Remote...
Viper 5101 no longer starts
are your brake lights functioning properly? remote starts sometimes use this as a fail safe, or a bent hood pin switch? Also It may need the tach reprogrammed if used. there may be a seperate fuse for the starter.
here is the link to the installation manual: http://www.directeddealers.com/manuals/ig/viper/n4102v_2008_09_web.pdf
and the page regarding this issue: • The remote start will activate, but the starter never engages.
1. Check for voltage on the purple starter wire two seconds after the remote
start becomes active. If there is voltage present, skip to Step 4. If there is
not voltage present, advance to Step 2.
2. Check the 30A fuses.
3. If the gray/black wait-to-start wire is detecting ground upon activation, the
starter will not crank.
4. Make sure the purple starter wire is connected on the starter side of the
optional starter kill/anti-grind relay.
5. Does the vehicle have an immobilizer? Some immobilizer systems will not
allow the vehicle to crank if active.
6. Check connections. The heavy gauge remote start input wires on the
heavy gauge 10-pin connector should have a solid connection. "T-taps"
or "scotch locks" are not recommended for any high current heavy gauge
wiring.
good luck.
Apr 17, 2014 | Remote Start System
Car dies when I use my remote start and press the lock or unlock button
This is most likely caused by the car's anti-theft system. Most newer cards require a separate module to be installed to override the anti-theft system while the remote start is in use. Otherwise, when the anti-theft system detects an anomaly, it will immobilize the vehicle.
DEI makes a 556H module for this purpose. The link shows the instrall manual for this device.
DEI 556H Module Info
Dec 12, 2013 | 2002 Honda Civic
Immobiliser problems ?
Use the key to lock and unlock door or truck, this is the same as using the remote. go to a door or the trunk and lock and unlock and then try to start the car, let me know the outcome. good day.
Apr 26, 2012 | 2003 Seat Ibiza
My car is a 1997 audi a4 and doesnt have remote locking but does have central locking. used to work fine but now the key only unlocks the drivers door. the other doors will not unlock. however if i unlock...
I would start with driver door lock , not the lock cyllinder , but lock assembly which is inside the door and have switches build in to it.
Jun 22, 2010 | 1997 Audi A4
2006 bmw 325i remote only unlocks driverside door. will not unlock all doors when you lock it from the inside. have to use key in remote to open door. also central button to unlock doors is inop
fuse 56 and 57 control central locking,the issue is caused by surges typically in the front door lock actuators, normally at a dealer they would replace fuse 56 and 57 with a 20a mini fuse and if still occuring repl the door lock(s) that dont work or typically both front, first replace fuse 56 and 57 with 20a fuses as were too small from factory and than operate ten to 15 times, if it doesnt work at first dont panic,let the car go to sleep which takes about 16 min and than try again this problem has nothing to do with the key fob or the lock unlock button inside,also the fuses are located behind the glove box just rere the access panel and they are found at lower left section
Jul 23, 2009 | 2006 BMW 3 Series
Door locks quit working
check battery in the remote
May 10, 2009 | 2006 Chevrolet Tahoe
I can't disable my anti theft device on my chevy malibu 2004 and my car will not start
This usually works.Lock the doors with the remote.Press lock twice sounding the alarm.Then press the unlock button twice.Your car should start now.If that doesnt work try this,Lock the car again with the remote once.Go over to the passenger side door and use the key to unlock the door then press in the door unlock all doors.Hopefully by now it worked.Now if none of these work your security probably malfunctioned and theres only two things that will work,One is disconnecting the battery for 5 mins then reconnecting.unlock doors.the start.If that doesnt work you'll have to take it to the dealer to get the security reset or replaced.The steps I have wrot you are the diagnostics to reset it.I hope these work for you and good luck.See ya had have a great day..
Mar 31, 2009 | 2004 Chevrolet Malibu
System thelf light on car wont start 1996 chevy
Sounds like your security is staying on.Try locking the car with the remote keys then unlocking If that doesnt work lock car again and unlock it with key in passenger side door..These should solve your problems if not tell me what you got after doing those things..
Mar 28, 2009 | 1996 Chevrolet Cavalier
Car APS997A Two-Way Remote Start and Security System Logo
351 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
